General Supercharger Thread
  1. Feb 5, 2025 at 8:09 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  2. Feb 5, 2025 at 8:14 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    ARES35, bflooks, HulkSmurf14 and 2 others like this.
  3. Feb 5, 2025 at 8:16 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I'm going to try and make an adapter so I can stick it in the end of the intake tube with the filter element removed. I have some rubber matt that I can cut up, or maybe just tape it shut.
    I tried the cleaner method before and never knew I had those two torn o-rings, so it's not fool-proof. I wanted something more reliable, and if this is what the pro's use, then I need one too.
    ARES35, Mdl and e30cabrio[QUOTED] like this.
  4. Feb 5, 2025 at 8:19 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    They really do help. I have a diy one at home with nichrome wire and a lamp wick, helped a ton when troubleshooting rotten vacuum lines on my wife's LS430.
  5. Feb 5, 2025 at 8:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  6. Feb 5, 2025 at 10:20 AM
    Cruisers & Co.
    Cruisers & Co. New Member
    Johnny
    1997 Turbocharged Lx450, 1978 FJ40
    Alright guys everything on the website updated and group by is live. It can be found here: https://cruisersandcompany.com/collections/toyota-tundra
    Deep cast pan is 10% off with and without tapping of the pan for a temperature sensor
    Valve Body, Cooler Kit, Lock up kit, Analogue temp gauge are part of the group buy
    Most of you are buying valve bodies but the more you buy the more you save.
    Item 1 - 18%
    Item 2 - 20%
    Item 3 - 22 %
    Item 4 - 25%
    Discounts are automatically added to cart and stack so if you buy 4 items is 25% is the discount on everything product (Pan does not count as an item). Only reason we can even do this is the volume you guys have here!
    Huge shout out to @bflooks for reaching out and kicking this off!
    If you have a problem or need help please email info@cruisersandcompany.com or give me a shout @ 720-688-1830
    This will be live until Sunday at midnight!
    Tripleconpanna, Jego, VWTim and 10 others like this.
  7. Feb 5, 2025 at 10:21 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  8. Feb 5, 2025 at 10:42 AM
    HulkSmurf14
    2014 Tundra Limited
    SUCCESS!! Thank you Johnny & Brian! Now, to think of what I'll tell my better half! :monocle:
  9. Feb 5, 2025 at 11:08 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    HulkSmurf14, Mdl and armyoffoo like this.
  10. Feb 5, 2025 at 11:34 AM
    Silver17
    Eastern PA
    I could only bring myself to order the VB, but the order is in! Thanks for getting it together guys! I hope they have a lot of cores to build sitting around. :thumbsup:
  11. Feb 5, 2025 at 11:48 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was just about to call and decided to look for an update...Thanks! Ordered the pan, by far the best deal found online.
  12. Feb 5, 2025 at 11:51 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Dont hate on me for saying...Nothing wrong with a clean catch of oil and filter/strainer can be re-used.
    Silver17 and HulkSmurf14 like this.
  13. Feb 5, 2025 at 11:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Ordered! Thanks!
  14. Feb 5, 2025 at 12:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I know this is on the SC forum and a lot of people are still at work to get VB orders in. Maybe make a post in the general forum for more exposure over weekend?
  15. Feb 5, 2025 at 12:13 PM
    Silver17
    Eastern PA
    Maybe @Jego from the turbo thread wants in on the group buy also.
    Also, I haven’t spent half of what some of you guys have on this truck and I already feel I must be buried in it like @e30cabrio and his sequoia.
    bflooks, ARES35, e30cabrio and 2 others like this.
  16. Feb 5, 2025 at 1:22 PM
    ARES35
    ARES35 New member for life
    Mile high
    Right on! Since you guys are located so close to me can I order and pickup? Thanks!
    HulkSmurf14 likes this.
  17. Feb 5, 2025 at 1:25 PM
    Cruisers & Co.
    Johnny
    Of course!
    HulkSmurf14 and ARES35[QUOTED] like this.
  18. Feb 5, 2025 at 1:29 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Order is in! Thanks again
    HulkSmurf14 and ARES35 like this.
  19. Feb 5, 2025 at 1:32 PM
    ARES35
    Mile high
    10-4 order is in, ill head that way once I receive a confirmation for pickup. Thanks yall!
  20. Feb 5, 2025 at 1:45 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I hadn't even seen this message until just a moment ago, but Johnny's post with all the details is posted over there as well.
  21. Feb 5, 2025 at 1:52 PM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    My order is in as well!
  22. Feb 5, 2025 at 1:52 PM
    bflooks
    bflooks New Member
    Metrowest MA
    So it is captured here...
    Pending responses from @Cruisers & Co. :
    1. Which DexIII trans fluid is recommended?
    2. Results of the group buy so we can all compare notes
    I miss anything?
  23. Feb 5, 2025 at 2:13 PM
    centex
    centex New Member
    Pan and valvebody ordered.
  24. Feb 5, 2025 at 2:25 PM
    Cruisers & Co.
    Johnny
    I shouldve put a box for tundras.com username... not quite sure who everyone is
  25. Feb 5, 2025 at 2:28 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Old man should be ordering today as well. Told him todo the extreme instead
  26. Feb 5, 2025 at 2:29 PM
    centex
    centex New Member
    Shot you a pm.
    HulkSmurf14 and e30cabrio like this.
  27. Feb 5, 2025 at 2:43 PM
    centex
    centex New Member
    So now that we’ve all spent a small fortune, who wants to discuss the notorious pan bolts and how to prevent them from snapping.
  28. Feb 5, 2025 at 2:49 PM
    ARES35
    Mile high
    I'm gonna soak em in PB blaster and go lite on loosening:fingerscrossed:
  29. Feb 5, 2025 at 2:54 PM
    Cruisers & Co.
    Johnny
    In the shop if we have stubborn bolts we will snug them up ever so slightly and then back them out. Or hit the bolt head (along the long axis, not sideways to the bolt head) several times with a brass drift/hammer to send a shockwave through the bolt to hopefully break any corrosion and then try extracting.
  30. Feb 5, 2025 at 3:03 PM
    VWTim
    Corvallis, OR
    Peening helps. Also, if you have access to an induction heat tool, heat them up and let cool before loosening. I can loan mine out, but needs to be face to face in Oregon.
