2018 Tundra Lower Control Arm
Discussion in 'Suspension' started by juan40tundra, Feb 4, 2025.
  1. Feb 4, 2025 at 7:19 AM
    juan40tundra
    juan40tundra [OP] New Member
    Juan
    2018 Toyota Tundra TSS 4wd
    none
    Good afternoon
    Looking to replace lower control arms on my Tundra (2018 - 4WD), having a bit of trouble getting anyone in town to quote OEM. Also wanting to replace all the hardware associated with the control arms. Any guidance will be much appreciated, hopefully the parts listed below are the right parts.
    Lower control arm (LH - RH)
    Alignment Camber Adjusting eccentric (48452-0C020)
    Alignment Camber Adjusting eccentric (48198-0C020)
    Cam Sub-assembly front suspension toe adjust (48409-0C020)
    Cam Assembly Camber Adjust (48190-0C020)
    Bolt with washer (90119-A0204)
    Suspension control arm bolt (90105-A0135)
    Control arm bracket nut (90171-18004)
