Do you change your own oil in your Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by tstex, Jan 27, 2025.
  1. Jan 31, 2025 at 6:21 PM
    #91
    AZBoatHauler
    So.Arizona
    It’s a street car… but it can also do wheelies.
    LowcountryDave, mayan, Lifer and 2 others like this.
  2. Jan 31, 2025 at 6:40 PM
    #92
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Build yourself a set of these...
    https://azoffroading.com/blog/do-it-yourself-wooden-car-ramps/
    and clearance problems solved :thumbsup:
    kirkb, tstex[QUOTED][OP] and Raven67 like this.
  3. Jan 31, 2025 at 6:44 PM
    #93
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    As I thought. Thanks.
    AZBoatHauler[QUOTED] likes this.
  4. Feb 2, 2025 at 12:59 PM
    #94
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    Raven67 likes this.
  5. Feb 2, 2025 at 9:22 PM
    #95
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Yes, he's obviously flexing. And you know what, I'm assuming he worked for his money and I have no problem if the guy wants to flex a little. I wouldn't do it personally, but I understand. He's proud of what I assumed he worked for. Congrats dude.
    Kerktam likes this.
  6. Feb 3, 2025 at 4:09 AM
    #96
    tstex
    tstex [OP] New Member
    Houston & Colorado County TX
    2024 Silver Tundra TRD
  7. Feb 3, 2025 at 4:10 AM
    #97
    tstex
    went to dealer and instead of $9.xx/filter, i bought a case of 10 for $7.23/filter or $72.30 for 10 + tax. They came in a box so I'll store them in the box until usage.
    Also buying 10 5gal containers of Quaker State 0W-20 Full Synthetic. It's made in same refinery as Pennzoil Ultra Premium and has 2nd lowest NOACK rating only to Pennzoil.
    I know a lot of folks like Mobile 1, which is a PAO where the QS full syn is made from natural gas.(GTL)
    Polyolefin is a good base oil for heat, pulling long hauls or uphill or tough terrain.
    GTL is best for high and low temperatures and also will clean your engine better and also offer better fuel economy. This is my preferred application. Therefore, not going to take the 2 free oil changes, esp at 10K. I'm a 5K change guy at the very least.
  8. Feb 3, 2025 at 5:36 AM
    #98
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    BITOG fan I assume?
    Me too.
    I'm out before thread degeneration into oil preferences. :duel::anonymous:
    Tripleconpanna and Raven67 like this.
  9. Feb 3, 2025 at 5:54 AM
    #99
    tstex
    Yeah, don't want to start an oil war, but was completing the last phase of thread. I used Quaker State 5W-30 Full Synthetic on my Ford F150 Ecoboost snd traded in at 128K and w 25 oil changes. Never had one issue snd Avg 19-20 MPG city & Hwy.
  10. Feb 3, 2025 at 12:30 PM
    #100
    bailey bulldog
    bailey bulldog New Member
    I'm going to try Pennzoil 5w-30 Euro L on my next change and see what happens. I have about 2200 miles left before I swap. I read good stuff about Euro L, so hopefully she don't blow lol.
  11. Feb 3, 2025 at 12:52 PM
    #101
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    never ever in the 10 plus years of having a FUMOTO valve on any of my trucks has the dealer removed it to drain the oil. I guess it is possible, and a reason to never allow the dealer to change your oil, or do anything else they could F'up and make you pay for.
    by the time I get to the end my free Toyota Care the dealer will have changed my oil zero times. Rotate my tires and check my fluid is all I allow them to do as part of this plan. I do my own oil and let them know when I go in - they record it and that is that. I've got 8600 miles and five months left of my Toyota Care and I've changed my oil two times so far and the next will be at 10k.
    tstex[OP] likes this.
  12. Feb 3, 2025 at 1:10 PM
    #102
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    :thumbsup::mudding:
    Hella Krusty[QUOTED] likes this.
  13. Feb 3, 2025 at 3:19 PM
    #103
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    I followed a lot from Bobistheoilguy.com and used Ford Motorcraft Semi-synthetic when I wasn't too concerned about getting the longest life as possible. Now I use Pennzoil Ultra.
  14. Feb 3, 2025 at 3:52 PM
    #104
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Today took her in for the 10K service. So it’s the dealers turn to change the oil. I do 5K and the dealer does the other 5K. Luckily I checked the skid plate bolts before leaving. Sure enough one was miss and the plate was flopping around. Told the advisor WTF. They took care of it.
    I’m debating on canceling my service contract. Prepaid up to 85K. Does anyone know how to do that?
  15. Feb 3, 2025 at 5:01 PM
    #105
    tstex
    Has anyone ever changed out the std Toyota 14mm oil pan plug for a magnetic 14mm plug? My weekend ranch tractor is 60 PTO tractor and it has 2 hydraulic filters that both have magnets at the installation interface. Every once in awhile i see some silvery goo, but not much on the tractor.
  16. Feb 4, 2025 at 4:26 AM
    #106
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    Ive had dimple plugs in the past. Haven’t seen any metal on the magnet which is a good thing.
  17. Feb 4, 2025 at 6:21 AM
    #107
    tstex
  18. Feb 4, 2025 at 6:39 AM
    #108
    DRP
    DRP Old Member
    Dave
    tstex[QUOTED][OP] likes this.
  19. Feb 4, 2025 at 7:03 AM
    #109
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  20. Feb 4, 2025 at 11:29 AM
    #110
    tstex
    Thanks DRP & Raven.
    I noted that each of these have "crush" metal washer. Is this a permanent washer or temporary? I bought a case of Toyota oil filters and each filter has a washer with it. Should the toyota OEM oil plug washer be used w the metal crush washer or in place of it?
    Appreciate it.
  21. Feb 4, 2025 at 11:57 AM
    #111
    Raven67
    Kentucky
    The washers are aluminum, so one time use is recommended. I ordered a bag of washers with my drain plug. I never tried the OEM washers, I'm sure they would work fine in place of.
    DRP and tstex[OP] like this.
  22. Feb 4, 2025 at 3:15 PM
    #112
    tstex
    Raven & DRP & others w magnetic oil pan plug. Have you ever collected any metal debris and wondering at what millege did you first start seeing it? My tundra has 4631 miles on it, Thanks
  23. Feb 4, 2025 at 3:52 PM
    #113
    Raven67
    Kentucky
    I haven't on any vehicle. Just very little very fine "dirt" that you wipe off with a rag. All normal.
  24. Feb 4, 2025 at 4:34 PM
    #114
    tstex
    Thank you
  25. Feb 4, 2025 at 4:46 PM
    #115
    DRP
    DRP Old Member
    Dave
    Ditto.
    Have seen a bit on the lower unit of my outboard though........
  26. Feb 9, 2025 at 4:14 PM
    #116
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    I just buy little magnets from HFT, drill the original plug to the depth of the magnet and insert one. It hold there by its power, but i put a little dub of epoxy, just to make sure.
    I do it for years on all my cars, tractors, outboards and all. Motors, transmissions, rear axels. Everything which has oil and a plug without magnet.
    In addition i use larger earth magnets and attach them to the oil filters. I know, it is overkill, buy who cares, as long as my OCD and motors happy
    22whatwedo and Raven67 like this.
  27. Feb 9, 2025 at 5:07 PM
    #117
    Main Lo
    Main Lo New Member
    2023 Tundra CrewMax 4x4 SR5 TSS
    Bought a Gen 3 Tundra that came with lifetime oil changes, but the "service" interval is 10k which is stupid on a TT. I alternate oil changes every 5k between me and the dealership.
    Retroboy1989 and mrlittlejohn like this.
  28. Feb 10, 2025 at 7:10 AM
    #118
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    If you guys are changing your own oil then you probably maintain other things too. Greasing tools and machinery is important and leaking grease guns are a constant annoyance. I can't remember where I stole this grease gun storage idea from but feel free to use it if it works for you.
    I call this my lubrication station.Lol
  29. Feb 10, 2025 at 7:26 AM
    #119
    Main Lo
    Main Lo New Member
    Holy S***... I keep my grease gun in a very large zip lock bag because it leaks. This is a game changer!
    Tripleconpanna and VCheng like this.
  30. Feb 10, 2025 at 6:56 PM
    #120
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    You just gave me another project my friend
