Relocating Garage HomeLink to somewhere else ideas?
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, Sep 5, 2024.
  1. Sep 5, 2024 at 5:54 AM
    brkncly
    brkncly [OP] New Member
    Oregon
    I'd like to relocate my garage HomeLink pad to somewhere else so I can install a Wolfbox rear mirror. Wolfbox doesn't make one with HomeLink, wish they did. I believe that the Wolfbox would block access or make it difficult to push the factory HomeLink. Has anybody relocated their garage HomeLink pad? I would like to relocate it to underside of the driver side sun visor.
  2. Sep 5, 2024 at 6:10 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    You can probably swap in a sun visor that will fit that has homelink built in instead of retrofitting yours. That’s what I’d do. Quick google search shows older avalons have it along with others
    Echo5Golf likes this.
  3. Sep 6, 2024 at 4:32 AM
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
  4. Jan 2, 2025 at 11:31 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Did you ever get the Wolfbox installed and what year is your Tundra?
    Can anybody confirm why the OEM bracket that Wolfbox sells only shows compatibility for '07-'16?
    Is it because of the Homelink? Was it introduced in '17? I would think the mounting bracket should be the same, right? :confused:
  5. Feb 3, 2025 at 9:02 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    hello all. was thinking of installing the wolfbox as well on my '16. regarding the homelink, i found a real easy solution for a diyer. was looking at one button clicker and found this review which was super helpful and you just need to solder two wires and add a button to the overhead light panel. looks pretty easy to do. this throwing it out there as an option. cheers
    tin
    Link for one button clicker: LINKY
    And the helpful review on the site that sold me. :)
    panicman and TacomaTRD4x402 like this.
