Removing bed bolt with broken torx teeth
Discussion in '2.5 Gen Tundras (2014-2021)' started by PNWtundrite, Feb 2, 2025.
  1. Feb 2, 2025 at 6:12 PM
    PNWtundrite
    PNWtundrite [OP] New Member
    2010 Tundra TRD rock warrior black
    Demello front number with winch and lights, Bilstein 5100 Eibach spring 3" front lift and 5100 rear 2" lift, Android auto stereo with front camera
    Tried to get my bed bolts out tonight and the teeth cracked on the bolt itself. Any ideas?
  2. Feb 2, 2025 at 7:35 PM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Is there a flat head that can fit end to end?
    chugs likes this.
  3. Feb 2, 2025 at 7:40 PM
    French Avocado
    Utah / Wyo
    Vicegrips
    rjls, yakeng and PNWtundrite[OP] like this.
  4. Feb 2, 2025 at 7:41 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
  5. Feb 2, 2025 at 8:15 PM
    It may come to welding a nut on top. I wish more manufacturers would bolt the bed from underneath and actually use standard ASE size bolt heads.
  6. Feb 2, 2025 at 8:23 PM
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    I second Avocado's suggestion of vice grips. Have used them with success in the past for similar issues.
    French Avocado likes this.
  7. Feb 2, 2025 at 8:26 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Might wanna blow torch that guy first whatever you do. Then yeah my thought is giant vice grips and put a breaker bar over the grip end if possible.
  8. Feb 2, 2025 at 8:27 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Vise grips would be tough being it's sunken down a bit.
    I'd spray it good with Kroil, another penetrating oil, or at least WD-40 and let it sit over night.
    Perhaps try hammering the next biggest-size torx bit in the hole and turn it out.
    If anything maybe a left twist drill bit.
    ToyoMafia and French Avocado like this.
  9. Feb 2, 2025 at 8:30 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Actually thinking on this more I would (blow torch for a minute) then use a big pipe wrench, add breaker bar as needed.
    PNWtundrite[OP] likes this.
  10. Feb 2, 2025 at 8:46 PM
    PNWtundrite
    Bro this s*** is tight no flatheads going to do that job.
  11. Feb 2, 2025 at 8:47 PM
    PNWtundrite
    I think I'm going to try this before I cut the head of the bolt to make a bolt that I can use a socket on
  12. Feb 2, 2025 at 8:48 PM
    PNWtundrite
  13. Feb 2, 2025 at 8:51 PM
    PNWtundrite
    I was also thinking of welding a bolt to it
    AxelsHumanDad likes this.
  14. Feb 3, 2025 at 5:26 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Another option is to drill the head off. If you weld a bolt on and the weld fails as you try to take it off, you won’t be able to drill it afterwards because the bolt becomes case hardened. In the future, to prevent them from messing up, make sure the torx head is clean of debris, use a knew torx bit or one that you know is not worn, place the torx bit in the bolt and strike it with a hammer a few times. Use an impact and not a ratchet to remove. The hammering of the impact will help loosen the bolt.
  15. Feb 3, 2025 at 5:49 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
  16. Feb 3, 2025 at 7:03 AM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Get a hand held electric engraver and put the tip in the center of the bolt head, then let do its thing for a couple of minutes. It's like a mini jackhammer and can help losen bolts
  17. Feb 3, 2025 at 7:15 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    100% this. I've done it with head bolts where they have the head head and it strips. Threaded shaft should just turn by hand as soon as tension is broken
    Ruggybuggy[QUOTED] likes this.
  18. Feb 3, 2025 at 7:20 AM
    seydou
    seydou Distinguished Member
    Screw/bolt extractor.
    ToyoMafia, denon28, BlackNBlu and 2 others like this.
  19. Feb 3, 2025 at 7:35 AM
    PNWtundrite
    True but there is some corrosion had to use a 24" bar to get em loose
  20. Feb 3, 2025 at 7:39 AM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    I just solved this issue a week ago on my Father in Laws new Tundra. Use a rubber band between the driver and screw. Push in and slowly turn. Found it in YouTube.
  21. Feb 4, 2025 at 8:25 AM
    BonesATX
    BonesATX Never enough money
    Adolfo
    Austin
    2017 Tundra SR5
    TRD intake, Icon lift 35’s, stainless works long tube headers, CMC,Tuned
    Will this work with the bolts for the tie down anchors on the corners of the bed? Trying to remove them and the threads are stripped was doing this while changing out my bed bolts was only able to swap out three the other three are tight!
  22. Feb 4, 2025 at 8:29 AM
    seydou
    Don't see why the wouldn't work. Apply a penetrating oil per instructions to make it easier.
  23. Feb 4, 2025 at 8:38 AM
    BonesATX
    Adolfo
    Austin
    2017 Tundra SR5
    Just ordered it, trying to install the total chaos bed stiffeners and that’s been the issue trying to remove them, and hopefully I can remove the other bed bolts
  24. Feb 4, 2025 at 11:01 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    As others have mentioned, penetrating oil (maybe a few treatments over a few hours from underneath) then extraction bits. Might be worth hitting it with an air hammer from above and below too to help vibrate things loose too.
  25. Feb 4, 2025 at 11:08 AM
    BonesATX
    Adolfo
    Austin
    2017 Tundra SR5
    I’ll give that a shot for sure, several of them were rusted
  26. Feb 4, 2025 at 1:05 PM
    PNWtundrite
    Pipe wrench for the win
  27. Feb 4, 2025 at 1:23 PM
    BonesATX
    Adolfo
    Austin
    2017 Tundra SR5
    Nice I got a pipe wrench but need something to extend it to get leverage
  28. Feb 4, 2025 at 4:17 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    A little harsh language usually helps too.
    ZappBrannigan, kirkb and WILLINH like this.
  29. Feb 4, 2025 at 7:26 PM
    French Avocado
    Utah / Wyo
    Especially when the wrench slips off!
    kirkb likes this.
  30. Feb 4, 2025 at 8:01 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Now the question is, do you plan on reusing it?
    NewImprovedRon likes this.
