Is this what they mean “lipstick on a pig”?
Discussion in '1st Gen Tundras (2000-2006)' started by Ergo21, Feb 1, 2025.
  1. Feb 1, 2025 at 11:26 AM
    Ergo21
    Ergo21 [OP] New Member
    2018 Toyota Tundra SR
    I found 2006 v8 private seller. Frame looks like it was painted black but needed second opinion before I drive an hour away.
    07bajatundra likes this.
  2. Feb 1, 2025 at 11:35 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    yep, that is spray paint
  3. Feb 1, 2025 at 11:52 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Spray paint or rubber under coating. The brown'ish hue to it in the first pic makes me think its the rubberized undercoat.
    The under hood pix show a lot of oxidation, and the pix are not even good. The frame and axle definitely show a considerable amount of rust. I've seen worse but they definitely tried to hide what it looks like.
  4. Feb 1, 2025 at 11:57 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Middle top of the first photo above the frame does not look good.
  5. Feb 1, 2025 at 12:11 PM
    @Ergo21 You’re looking at the worst and hoping to find a gem. I don’t think it’s going to happen.
    Black Wolf likes this.
  6. Feb 1, 2025 at 12:47 PM
    Griff04
    Griff04 New Member
    Ralph
    Southwest Georgia
    2006 V6/2WD/AC
    None
    It’s hard to tell from the pics but there is does appear to be some substantial rust showing. They actually didn’t do too good of a job hiding it with the spray paint or whatever coating they used. As mentioned, I’ve seen worse but would do a “thorough” inspection if you did make the trip to see it. Personally I’d be a little leery of it but it really depends on where your tolerance level is at. Good luck.
  7. Feb 1, 2025 at 1:41 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    I'd pass. You'll find another. They made several of them. And given the apparent attempts to cover up, I'd take the 'timing belt replaced at 100k' with a grain of salt too.
  8. Feb 1, 2025 at 3:45 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    For only an hour drive, that's worth the trip. Take a ball peen hammer, flat screw driver, and a creeper. Roll around and beat, pry, and inspect everything.
  9. Feb 1, 2025 at 4:30 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
  10. Feb 1, 2025 at 4:35 PM
    Looks like rubberized undercoating was sprayed on the frame.
    This doesn't look too good....
    G_unit3000 likes this.
  11. Feb 1, 2025 at 4:48 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Opinion….seen a pig with better lipstick and sure wouldn’t waste an hour to see that lipstick….JMHO
  12. Feb 1, 2025 at 5:10 PM
    Dsptundra
    Austin TX Area
    Yeah, this is the spot that caught my attention. Not good.
  13. Feb 1, 2025 at 5:17 PM
    07bajatundra
    07bajatundra New Member
    2007 4.7 tundra SR5 4X4
    3" body lift. 3" suspension lift rhino paint job. Gonna tube and change to 4" lift and get 37s
    Check 4wd high low actuator to make sure it's not broken it is made of plastic and is 1500 for the part alone. The mount tabs like to brake
  14. Feb 1, 2025 at 5:21 PM
    Run away.....fast!
  15. Feb 1, 2025 at 6:41 PM
    Ergo21
    You are right. I am just surprised how hard it is to come by a good one
  16. Feb 2, 2025 at 8:54 AM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    Because of people like me who ain't ever getting rid of mine.
