Leather seats loudly creaking when sitting back?
Discussion in '3rd Gen Tundras (2022+)' started by RickyBobbysTundra, Feb 9, 2023.
  1. Sep 14, 2024 at 8:24 AM
    #61
    The Dutch Man
    The Dutch Man New Member
    My 23 platinum does this on the driver seat back badly. Any TSB out yet?
  2. Sep 16, 2024 at 11:24 AM
    #62
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
    I had mine in for the driver and passenger seats. The drivers side went first and they ended up using a dry lubricant and it went away. I asked them to do the same on the passenger about a year later. So far it has solved the problem.
  3. Sep 16, 2024 at 7:15 PM
    #63
    The Dutch Man
    Where did they apply the dry lubricant?
  4. Sep 16, 2024 at 7:42 PM
    #64
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    Do you know what dry lubricant they used? Graphite powder maybe?
  5. Sep 17, 2024 at 8:53 AM
    #65
    Spickett78
    Spickett78 New Member
    Seth
    2023 Tundra Crewmax 6.7' Limited TRD OR Premium Magnetic Gray
    3" TRD lift Talon's Garage Steel powder coated transmission skid plate / Cat cover RCI Steel powder coated skid plate Go Rhino D6 steps Nytop front recovery points
    My drivers side seat heater went out and when there I showed this this thread actually and they did the extra wrapping that is someone else shared about and I've not had any more issues. They didn't complain or give me any issues about it but there wasn't anything official. It's of course possible they were more willing to do it since they were already in the seat for a warranty issue.
  6. Sep 17, 2024 at 12:33 PM
    #66
    grnwdjsn
    grnwdjsn New Member
    I read through my service report and they did not specify. Just said "dry lubricant applied"
    pyoung62 likes this.
  7. Jan 25, 2025 at 8:49 PM
    #67
    The Dutch Man
    Toyota released a TSB for this issue in Dec 2024. Here is the TSB link. Mine goes in Tuesday to get the fix. Here is the post from the Tundra Facebook Group:
    There’s a TSB out now. We used to just lube the highest eyelet the seat back “spring” runs through. But now there are redesigned eyelets that get installed. It’s wild to me how oblivious dealerships are. This has been a problem we’ve encountered for quite a long time with our own repair until Toyota addressed the part issue.
    https://dot.report/bulletins/11012758
    Spickett78 likes this.
  8. Jan 26, 2025 at 6:35 AM
    #68
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    If anyone takes theirs in, keep us updated on the length of the repair and how successful it is. Their first attempt to “repair” was unsuccessful with the lube, but it’s not very noticeable in cold weather. So I’ll probably wait until it warms up before taking it in. I can certainly see them denying the work because they couldn’t reproduce the creak.
  9. Jan 26, 2025 at 10:34 AM
    #69
    BossDawg24
    BossDawg24 New Member
    Mark
    Cumming, GA
    2023 Tundra Capstone Blueprint, 2017 1794 Barcelona Red
    None
    Mine did this when I first got it. I noted it to the dealer and they said there was no fix at the time. Seems mine went away after awhile, but this is good to know. Wonder if they would fix mine now that my 2023 has 50,000 miles on it? It was noted on one of my service visits around 10,000 miles.
  10. Jan 26, 2025 at 10:49 AM
    #70
    Breathing Borla
    AZ
    a good dealer would under a good will repair when it’s been noted numerous times under warranty
    shitty dealers will say no just to be dumb
  11. Jan 26, 2025 at 11:13 AM
    #71
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    And really shitty dealers would keep your truck for a few days, do nothing, bill Toyota for the repair, and tell you it was fixed. You'd be none the wiser. Personally, I wouldn't waste my time if I couldn't verify it was done. It's not like it's a safety recall.
  12. Feb 1, 2025 at 6:42 AM
    #72
    The Dutch Man
    So it's been a few days since I posted after have the TSB performed.
    I am proud to say no more creaking. I highly recommend everyone go and complain to their dealer and reference the TSB I posted above.
  13. Feb 1, 2025 at 7:35 AM
    #73
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    How long did it take? And did they do it at the dealership? When I brought mine in for their unsuccessful first crack at it where they just lubed it, they actually took it to a nearby upholstery shop that does their warranty work for seats. Ended up being without the truck for two days.
  14. Feb 1, 2025 at 9:04 AM
    #74
    The Dutch Man
    TSB calls for two new upper clips to be installed on the frame. Dealer did in about an hour
    Spickett78 and Breathing Borla like this.
  15. Feb 2, 2025 at 8:29 AM
    #75
    The Dutch Man
    Here is a copy of the TSB PDF if anyone wants to read up on the repair.
    Pizzanaut, ubybc, Spickett78 and 2 others like this.
  16. Feb 2, 2025 at 2:39 PM
    #76
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    Shit. My dealer took 4 hours to do the 10k service. Basically, that’s an oil change and tire rotation, and they replaced the radio knob. That took 3.5 hours. They gave it back with 5 lug nuts on the right front rounded off. Took another 30 minutes to replace them when I bitched about it. No way in hell I’ll see these clips replaced in one day by these clowns.
  17. Feb 13, 2025 at 6:02 AM
    #77
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    No, I'm not fat.
  18. Feb 22, 2025 at 7:53 PM
    #78
    Spickett78
    Seth
    Ouch. I hope you have another dealer you can start to drive to. I drive to a different town because the one in my town is useless. Gave me my taco back missing a lug nut like you had happen. I bought my tundra somewhere else and it's worth it to go out of my way.
  19. Feb 22, 2025 at 7:54 PM
    #79
    Spickett78
    Seth
    I laughed but I'm not either and had an annoying creak in mine. It would do it just stretching in the seat at a light. Seat heater went out last winter and I showed my dealer the original fixes in the thread and they fixed it at the same time.
  20. Jun 29, 2025 at 6:59 AM
    #80
    tbird462002
    tbird462002 New Member
    2025 Tundra Limited TRD
    Anyone know the actual part number of the clips that need to be replaced?
    Soupbean77 likes this.
  21. Jun 30, 2025 at 4:09 PM
    #81
    ubybc
    ubybc New Member
    2024 Tundra Hybrid Limited
    Nice to know there is TSB on this issue, I was wondering as I noticed the problem recently on my used 2024. Thanks for sharing.
  22. Jul 12, 2025 at 5:35 AM
    #82
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    Nearly two years later and at 16,000 miles. The seat is still quiet.
    Tundrastruck91 and Soupbean77 like this.
