Slight shaking
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ben89734, Jan 31, 2025.
  1. Jan 31, 2025 at 11:29 AM
    Ben89734
    Ben89734 [OP] New Member
    2021 Tundra
    I recently purchased a 2021 tundra 36k miles, have never driven/ owned a truck. Only previously driving a 2004 4 runner. And the thing likes to shake around 40-50 mph and anything past 70+. There is a lift kit and I believe 35s on it. The shaking isn’t bad but is it something I should be worried about?
  2. Jan 31, 2025 at 11:36 AM
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    I would have alignment checked or tires checked for balance.
    might be more to it now since you got a lift and big tires. Sure more guys will be along to help
    rodm1, AZBoatHauler and Jaypown like this.
  3. Jan 31, 2025 at 1:19 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Probably wheel balance. Tundras are finicky about wheel balance, alignment. Any of them out of whack can induce some shimmy.
    Get the tires rotated and balanced, see where you land.
    rodm1 likes this.
  4. Jan 31, 2025 at 3:10 PM
    DADKILL
    DADKILL New Member
    22 Tundra Limited 4x4
    If you've got BFGoodrich ko2s they've sometimes been known to have balance issues. Either way it's more than likely a wheel balance problem unless you have spacers that could also be causing the problem. Should be a minor fix
  5. Jan 31, 2025 at 5:57 PM
    Ben89734
    2021 Tundra
    Just scheduled to get my tired balanced, alignment checked and a good once over of the truck. Thank y’all
    Northwoods22 and AZBoatHauler like this.
  6. Jan 31, 2025 at 10:31 PM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Switch out those MT to AT tires.
  7. Feb 1, 2025 at 6:55 PM
    rodm1
    rodm1 New Member
    Try to add air 5 to 10 psi and see what happens it fixed my shake.
  8. Feb 2, 2025 at 5:59 AM
    BonesATX
    BonesATX Never enough money
    Adolfo
    Austin
    2017 Tundra SR5
    TRD intake, Icon lift 35’s, stainless works long tube headers, CMC,Tuned
    Check to make sure all tires are good, I had mine shaking and I thought I needed to balance my tires but first look at one of the tires and was told one of them was bad, so swapped the bad tire to the back and it doesn’t shake but at a high speed you can feel it but that’s cause it’s a bad tire
    rodm1 likes this.
