  1. Jan 29, 2025 at 8:01 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I'm willing to be told I'm wrong but this is the door I'm looking at
  2. Jan 29, 2025 at 8:31 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I screwed a stirring stick to the tops of two doors so they'd stay up in pairs. Made setup and painting real easy. Took me longer to tape the cement than to paint the doors.
    TaquitoBandito, woods, Blufin and 3 others like this.
  3. Jan 29, 2025 at 8:36 AM
  4. Jan 29, 2025 at 1:39 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Cost of that sub is irrelevant as it’s also a great side table!
  5. Jan 29, 2025 at 1:40 PM
    Florida AF
    Logan
    North Florida
    Maybe mine is turned down compared to yours? Mine has never walked.
  6. Jan 29, 2025 at 1:48 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    I did a bunch of research today and ended up buying some subwoofer isolating feet. I should get them delivered later today. We'll see if it works.
  7. Jan 29, 2025 at 1:49 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    try something like this:
    https://www.amazon.com/Sound-Addict...=&hvlocphy=1018561&hvtargid=pla-2281435178818
    I have an isolation platform on mine and hasn’t moved since the day it was installed. It’s an older svs cylinder sub that will literally rumble the foundation and pressurize the room. I am laid up with the stomach flu at the moment but I will get a picture of my platform when I make it out of bed
    Blufin and TaquitoBandito like this.
  8. Jan 29, 2025 at 2:32 PM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    I'm going to make rubber bottoms for the coasters:bananadance:
    OldGuy03 and TaquitoBandito like this.
  9. Jan 29, 2025 at 4:27 PM
  10. Jan 29, 2025 at 5:36 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Beautiful! Thank you :hattip:
  11. Jan 29, 2025 at 5:38 PM
    U bet. Lmk if u need anything else
    Mater[QUOTED] likes this.
  12. Jan 29, 2025 at 5:39 PM
    TaquitoBandito
    Joel (AKA Bif)
    I've got a few of those around the yard. When I know I'm gonna be outside for a while, I snooze the alerts for certain cameras 30 minutes or a few hours.
  13. Jan 31, 2025 at 12:47 PM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    SVS all the way for me. Dual subs
    Blufin[QUOTED] likes this.
  14. Jan 31, 2025 at 1:29 PM
    shawn474
    MoCo, Maryland
    People who don't know just don't know - there is not a better performing home audio product on the market that can even touch them.....
    here is a picture of the platform
    And the sub (measures 32” tall)
    BlueRibbon4x4, Blufin and HulkSmurf14 like this.
  15. Feb 1, 2025 at 3:10 PM
    Florida AF
    Logan
    North Florida
    Finally got this done. Thankfully I anticipated problems and bought a full rebuild set. The exposed PVC crushed under the cutter almost immediately. Thankfully no branches beat me to this.
  16. Feb 1, 2025 at 4:54 PM
    Blufin
    Bob
    23 Capstone
    100%
    T-Rex266 likes this.
  17. Feb 2, 2025 at 1:54 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Need opinions. Can these walls be saved or is this a tear out, re-sheet, and then re-knockdown job? Cost isn’t an issue; it’s time. Previous owner must have put over 100 drywall anchors in here. Wonder if they ever heard of hitting a stud and using a support bracket?IMG_0456.jpg IMG_0455.jpg IMG_0454.jpg
  18. Feb 2, 2025 at 1:56 PM
    Blufin
    Bob
    23 Capstone
    If the wall is solid I would knock down the anchoring points with a ballpien hammer and 1/8" veneer skim coat.
    JM.02
    TaquitoBandito, woods and Mater like this.
  19. Feb 2, 2025 at 1:57 PM
    I’m no expert, but I’d say fill, sand, then get the spray can of texture whatever and knock down, then paint
  20. Feb 2, 2025 at 1:59 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    I was thinking that too. Time pretty critical here as I only have tonight, wed, and Thursday to get done whatever needs to be done. House will be tented tomorrow AM through Wednesday at noon
  21. Feb 2, 2025 at 2:00 PM
    Are you hosting a circus? Sounds like fun!
  22. Feb 2, 2025 at 2:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What this guy said.
    Patching will take a lot less time than trying to fully mud and texture new rock.
  23. Feb 2, 2025 at 2:15 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Pretty much! Wife is slamming appointments back to back to back - Tommy Emanski style. House gets tented tomorrow and then new carpet in on friday so trying to get everything done prior to carpet getting laid down
  24. Feb 2, 2025 at 5:03 PM
    ZPhilip
    Philip
    West Chester, PA
    I recently had the same scenario. 2 old closet systems left 200 holes. I hit them all with the bottom handle of my mud knife and hit them with mud twice. Quick pole sanding and it came out perfect for a closet. I wouldn’t even bother with the sanding since yours has a knockdown finish.
    TaquitoBandito and Mater[QUOTED] like this.
  25. Feb 2, 2025 at 6:33 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Awesome! Great to hear. Thanks for the input.
    TaquitoBandito likes this.
  26. Feb 4, 2025 at 9:46 AM
    TaquitoBandito
    Joel (AKA Bif)
    Our dryer vents out to a covered side porch which is also my workout room. Bought a new washer & dryer set and now the room has been filling up with dryer lint. I don't know if the old dryer ate lint or was storing it up to burn down the house but that thing ran for eight years and I barely saw dust. This new one has been running for a few months and the shit is covering my workout equipment. And yes, I let it build up. I'd think about it while I was working out and then forget about it until the next time I worked out. I'm old.:burp:
    So I bought a Better Vent indoor vent from Amazon and hooked it up. Hopefully this solves my problem. Now I get to spend the next few days trying to get the lint off of everything...
    Blufin, T-Rex266, Florida AF and 2 others like this.
  27. Feb 4, 2025 at 9:52 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    so i'm guessing you'll have to change that filter alot?
    does it build up in that elbow at the bottom where it turns up?
    i've never seen something like this, so i'm not familiar with them
  28. Feb 4, 2025 at 10:03 AM
    TaquitoBandito
    Joel (AKA Bif)
    It's got a hatch that you can open up with a small screen and a filter.
    There's also a hatch at the top that pops open when 80% of the air flow is blocked.
    Basically, I'll go out once a day (before my workout) and clean the trapped lint. If the blue filter gets crazy, I can toss it or clean it.
    You can buy replacements or pick up a few of those cheap furnace filters and cut your own.
    As far as the elbow, it shouldn't be much different than having one behind the dryer. The total run is super short. I also used a twist lock connector so if it does start getting clogged, it won't be hard to clean it.
  29. Feb 4, 2025 at 10:21 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i was worried about air flow restriction and all if/when it gets clogged. good to know there's a trap door to alleviate it.
    good deal. hope it works for y'all!
  30. Feb 4, 2025 at 10:24 AM
    TaquitoBandito
    Joel (AKA Bif)
    I hope so. I was originally going to reroute it but that was going to be a major construction project and I know better than to tackle that on my own. This seemed like the easiest and cheapest solution.
    Mater and Fotnot[QUOTED] like this.
