  1. Jan 31, 2025 at 11:24 AM
    3rd time got it right. I just had to pay 60% more from NAPA.
    bmf4069, BroHon, JakeJake and 2 others like this.
  2. Jan 31, 2025 at 11:32 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Now go return one of the broken ones to Napa and get your 60% back :rofl:
    shifty`, bmf4069, BroHon and 4 others like this.
  3. Jan 31, 2025 at 1:06 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    He left the sunroof open?
    FiatRunner[QUOTED] likes this.
  4. Jan 31, 2025 at 1:43 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
  5. Jan 31, 2025 at 1:58 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    BroHon[QUOTED] likes this.
  6. Jan 31, 2025 at 2:25 PM
    Dakillacore
    Georgia
    If you have a sunroof, it's more than likely a sunroof drain tube that is clogged. It will back up into the vehicle from the lower portion of the A-Pillers into the floorboards or up into the headliner. This or the drain tube has disconnected. It is 99% always this when there is a water leak and there is a sunroof.
    If you don't have a sunroof then you can check if it's an aftermarket windshield by looking at the stamp on the lower left or right hand side of your windshield. It'll say "Lexus". If it says anything like "PGW" or any other brand then it's been replaced at some point. This would mean that the urethane was not set properly either missed a section or had an air bubble that caused a void. A glass company (NOT SAFELITE) can remove, reapply the urethane, and set it back in. This is risky, though. The windshield will sometimes break upon removal as they are not designed to be removed.
  7. Jan 31, 2025 at 2:51 PM
    Does anyone have plier recommendations for hard to reach radiator hose clamps? I can't get the last one on to save my life.
    I was thinking about trying these. Or these
  8. Jan 31, 2025 at 3:06 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I really wish it was the sunroof drains, unfortunately it’s not. I cleaned out the drains really really good when we got the car, in hopes that it was the issue.
    The windshield has been replaced before with a really nice insulated Pilkington one, but it must’ve been installed incorrectly because there’s rust bubbling around the edges. It’s definitely going to need to be pulled so I can repair the rust.
    I’m just hoping that there’s enough good metal left underneath for me to clean it up, fill any pinholes, and paint. I don’t have access to a welder, or the skills to use one.
    Dakillacore[QUOTED] likes this.
  9. Jan 31, 2025 at 3:07 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    The Black Mamba likes this.
  10. Jan 31, 2025 at 3:09 PM
    bmf4069 Captain wtf
    Thanks shifty!
    shifty`[QUOTED] likes this.
  11. Jan 31, 2025 at 3:10 PM
    Dakillacore
    Georgia
    That sucks, dude. I wish it was the drains as well.
    Lets just hope that the rust isn't that severe and you can slap on some primer and reinstall the glass.
    Although....some Pilkington glass is used as OEM. Care to share a photo of the stamp?
  12. Jan 31, 2025 at 3:15 PM
  13. Jan 31, 2025 at 3:18 PM
    Dakillacore
    Georgia
    I have a tech that welded two scrap pieces of metal to some vice grips.....they work like a dream. If you have a welder and some scrap metal that is.
  14. Jan 31, 2025 at 3:19 PM
    FiatRunner
    Jack
    I’m not near the car right now (away at college), but I’ve looked into the OEM manufacturer of the Lexus glass a bit, and the general consensus is that the Lexus models built in North America like the RX and ES get Pilkington glass. Cars made in Japan like the LS and LX get Asahi glass. My mom’s LS430 with the original windshield says AGW (Asahi Glass Works) on it.
    I really hope that my glass guy can remove and reinstall the windshield without breaking it. Because it’s one of the higher trim levels, the car has insulated glass to lessen road noise, and that is an expensive ass windshield.
  15. Jan 31, 2025 at 3:22 PM
    Dakillacore
    Georgia
    You can always verify the region by the first letter/number of your VIN. If it starts with a J, then its manufactured in Japan. If it starts with a number, then its NA built.
  16. Jan 31, 2025 at 3:30 PM
    JakeJake and The Black Mamba like this.
  17. Jan 31, 2025 at 3:35 PM
    bmf4069 Captain wtf
    Crawled around under Donut today to get some part numbers for the o2 sensors, and check my CKS. Took a few pics under there. I need a higher lift jack and taller jack stands. Fuck working on cars w/o a lift. I'm too fat and old.
    Looks like I've got an oil leak somewhere. This will be referenced later in the pics. (It's a surprise tool we'll save for later!)
    Under side of the procharger. You can kinda see where the oil leak is. But that's the tensioner? Maybe it's behind the timing cover.
    Exhaust setup.
    Looks like I have an exhaust leak on the pass side...
    And I'm missing a bolt on the drivers side!
    Next 3 pics are how close the headers are to things. Clutch slave cylinder.
    Steering shaft. If I make a left turn across traffic with the clutch out in gear it rubs the shaft. (Hehehe)
    Starter
    Looks like I'm leaking oil on the back of the pan, or it's blowing back from the front.
    Looks like the diff breather is on the axle tube. Apparently it needs to be lengthened.
    Some rear control arm porn.
    Apparently I have 2 sets of resonators on here. I'm thinking one or both need to go.
    Just some no name muffs. I'm betting they're take offs from a mustang GT.
    Gratuitous engine bay shot.
    So. An interesting thing I just found out. My o2 sensors are called "lambda" sensors. The come off a couple VAG cars. I kinda figured they'd be wideband Haltech sensors or something. It's cool though, $62 vs $150 a piece.
    Apparently my bellhousing is explosion proof.
    And finally, the piece that @JakeJake recommended I look at for my crank/no start. The CKS. It's behind the AC compressor and covered in oil. I'm kinda wondering if this and the o2s aren't the cause of all my problems, except whatever the dbw codes are.
    Damn engineers. Climb over a mountain of virgins to fuck a technician. @MrDirtjumper
    Alrighty, thanks for coming along with me for a guided tour to the underside of a 2011 Ford Crown Vic. We hope you enjoyed your stay!
  18. Jan 31, 2025 at 3:38 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    The long reach are Harbor Freight :thumbsup:
  19. Jan 31, 2025 at 3:49 PM
    Need a heat shield for that starter that close to the headers
  20. Jan 31, 2025 at 3:57 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Yeah, That slave cylinder cant be happy with that much heat either. I remember seeing somebody doing dyno testing with dented headers and the loss is damn near negligible. Id be tempted to to massage some of those areas and put heat shielding on the sensitive bits.
    When are we gonna do a hood/fender exit exhaust? :rofl:
    bmf4069[QUOTED] likes this.
  21. Jan 31, 2025 at 4:03 PM
    Fender exhausts, hood cutouts for straight stacks
    bmf4069 and JakeJake[QUOTED] like this.
  22. Jan 31, 2025 at 4:26 PM
    bmf4069 Captain wtf
    The Black Mamba and BroHon like this.
  23. Jan 31, 2025 at 4:26 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Cable hose clamp pliers.
  24. Jan 31, 2025 at 4:28 PM
    bmf4069 Captain wtf
    You heathens need to stay away from my precious Donut.
    Oh my, that didn't sound right. :rofl:
  25. Jan 31, 2025 at 4:36 PM
    bmf4069 Captain wtf
    However......
  26. Jan 31, 2025 at 4:59 PM
    I have the one on the left. No luck.
    I overlooked that link. Thanks
    Those are cool. Never seen that before.
  27. Jan 31, 2025 at 5:08 PM
    bmf4069[QUOTED] and BroHon like this.
  28. Jan 31, 2025 at 5:09 PM
    Dakillacore
    Georgia
    Found on Reddit.
    bmf4069, 455h0le_dachshund and BroHon like this.
  29. Jan 31, 2025 at 5:39 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I think I have to make an exception in my opinion for this person's truck o_O
    Call it "diversionary flair" or whatever, but they have managed to draw my eye away so much... that this truck looks pretty damn awesome!
    The way has been made.
    bmf4069 and Sirfive like this.
  30. Jan 31, 2025 at 5:42 PM
    Dakillacore
    Georgia
    I'm with you. I did a double take at first. I think that this is the best looking step side that I've seen.
