Please Help With Cam Seal Replacement Info
Discussion in '1st Gen Tundras (2000-2006)' started by WaterOp, Jan 30, 2025.
  1. Jan 30, 2025 at 10:38 PM
    WaterOp
    WaterOp [OP] New Member
    So Lake Tahoe, CA
    2005 Tundra Access V-8 Auto 4x4
    I need to replace the cam seals on my 2005 Access Cab V-8. I did a search but somehow I'm not seeing info or links to video on how to do this.
    If anyone could point me toward a link or video, I would appreciate it.
  2. Jan 31, 2025 at 4:11 AM
    bfunke
    bfunke Tundra Curmudgeon
  3. Jan 31, 2025 at 6:04 AM
    You’ll want the FSM. It’s free to download, linked from the sticky community megathread.
    IMPORTANT: DO NOT miss the point about installing the service bolt. I can hand you a 2-dozen page thread of someone pulling their hair out trying to figure out a timing issue, and it all traced back to him failing to install the service bolt to hold things in place while doing the seals.
    Meanwhile, be sure you confirm it’s actually the cam seals (since valve cover leaks are far more common), and if also share that AT-205 quelled my bank 1 cam seal leak after 200-300 miles of application, now I no longer need to do the cam seals. $20 saved me a hell of a lot of pain and $$.
