Rear differential w/LSD rebuild options
Discussion in '1st Gen Tundras (2000-2006)' started by googlydoodle, Sep 16, 2014.
  1. Sep 16, 2014 at 12:12 PM
    googlydoodle
    googlydoodle [OP] New Member
    Geoffrey
    Lucy
    100% stock
    So I am getting a little frustrated with the available options I have and I need some advice. I am going to rebuild/upgrade my rear differential LSD clutch assembly. I have done some research and found almost ZERO rebuild kits for my rear differential. I'm not too concerned with replacing the bearings and seals since none are making noise or leaking and they are pretty simple to replace. However I have found that my LSD rear differential is not quite up to par as I would like it to be. I can be on loose gravel and the rear LSD diff acts like an open diff setup. The LSD function seems to not work at all. I tried putting in new fluid with the friction modifier additive and no change. There is not any excessive debris or burnt smell either. The only thing I can find is to install factory plates and clutches, shim the carrier assembly, set backlash and reinstall. I was hoping to find maybe a tougher spring, stronger clutches, ETC... I dont want to go all out with a whole locker (spartan, detroit, arb, ETC) setup, I just want to improve on the factory setup if possible.
    Any advice on what's the best root to take would be much appreciated.
    -Thanks
    • COMP.pdf
      File size:
      93.1 KB
      281
    JakeJake and speedtre like this.
  2. Jan 30, 2025 at 5:52 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Get a fresh lsd from the yard. I see them in a lot of 4runners
  3. Jan 30, 2025 at 5:55 PM
  4. Jan 30, 2025 at 5:57 PM
  5. Jan 30, 2025 at 5:57 PM
    This could be a new record…..
  6. Jan 30, 2025 at 5:59 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    The poor bastard has been waiting at his computer over a decade for an answer. I figured I'd help him out
  7. Jan 30, 2025 at 6:03 PM
  8. Jan 30, 2025 at 6:13 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    lol!
  9. Jan 30, 2025 at 6:14 PM
    One time for funsies when I was bored, I found the oldest thread on the forum and responded to it to see how if it would come back to life. It worked that time too.
    whodatschrome, Bmktw2 and G_unit3000 like this.
  10. Jan 31, 2025 at 6:27 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    This is why we always ask folks to search first before posting a new thread with the same question. @Bmktw2 did what he was supposed to do.
    shifty` and Bmktw2 like this.
