Mpg random change
Discussion in '2.5 Gen Tundras (2014-2021)' started by voodoosports, Jan 28, 2025.
  1. Jan 28, 2025 at 12:10 PM
    voodoosports
    voodoosports [OP] New Member
    vinny
    Tucson Arizona
    2019 sr5 cm
    leveling kit, air horn, bed liner, fuels, body mount mod, running boards, tonnoflip, hooke road front bumper, pod lights
    Hey all
    I've had my 19 cm with aftermarket air filter for 2 years now. Had no problems until the last month or so and only getting 10 to 11 mpg.
    I have no codes, air filters are clean any idea why I'm getting such low mpg?
  2. Jan 28, 2025 at 12:12 PM
    Retired...finally
    You might want to do an oil analysis to check for silica.
  3. Jan 28, 2025 at 12:13 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Dry or oiled air filter?
  4. Jan 28, 2025 at 12:14 PM
    Tundra family
    Tundra family New Member
    Driveline lube lately? Brakes could be dragging also, that was an issue on my taco.
  5. Jan 28, 2025 at 12:30 PM
    voodoosports
    vinny
    Tucson Arizona
    2019 sr5 cm
    Dry air filter no brake or driveline lube lately
    I went from 508 to 401 on a 38g tank of gas
  6. Jan 28, 2025 at 12:36 PM
    Retired...finally
    Is that actual calculations or are you relying on the dashboard readings?
  7. Jan 28, 2025 at 12:39 PM
    voodoosports
    vinny
    Tucson Arizona
    2019 sr5 cm
    My last trip Sunday was 397
  8. Jan 29, 2025 at 1:34 PM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Is it a Flex Fuel tundra? If so get an OBD2 reader and pull your Fuel Alcohol %. Should be 0. When mine spiked I dropped in MPG. There are a few ways to reset it, there's a thread on it.
  9. Jan 29, 2025 at 4:46 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I would hand calculate the miles on a tank and divide by how many gallons you put in. You’re not using 38gal of fuel on a tank.
  10. Jan 29, 2025 at 8:32 PM
    lr172
    lr172 New Member
    07 DC
    Assuming you are not flex fuel and the mpg is calculated by you, the first place I would be looking is the two upstream O2 sensors. They can fail quickly and the mpg can drop like a stone when they do.
    KNABORES likes this.
  11. Jan 29, 2025 at 10:20 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Neighbors stealing your gas??? Jk would try a bottle of sea foam in the gas, clean your MAF sensor with MAF spray, clean the throttle body plate, check for vacuum leaks (computer adds fuel to compensate), replace your pcv valve, check wiring for the purge valve, try a tank of ethanol free to see if the issue is winter blend/local ethanol change.
  12. Jan 30, 2025 at 6:03 AM
    Bergy24
    Bergy24 New Member
    Winter Blend of gas can reduce MPG.
    Since mine is not in the Garage, I let mine warm up a little longer in the winter which also reduces the MPG since I am using gas at idle.
  13. Jan 30, 2025 at 6:46 AM
    DirtyMike5
    DirtyMike5 New Member
    Baton Rouge
    ^^ what Bergy said. Just from idling a few minutes in the morning and running winter gas. Could be small change in tire pressure also due to colder weather. I lose about 1.5-2 mpg during the winter months in Louisiana, I'm sure its a lot worse further up north.
    joseph_womack likes this.
  14. Jan 30, 2025 at 9:41 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I could be wrong but I think my scan tool said I was using .5 gallons fuel per hour while idling.
