Hitch Weight
Discussion in 'Towing & Hauling' started by Chubs, Jan 21, 2025.
  1. Jan 21, 2025 at 4:24 PM
    Chubs
    Chubs [OP] New Member
    2024 Platinum TRD
    What is the maximum hitch weight for a 2024 Tundra Platinum? (Short Bed non Hybrid). Or where can I find it? Thanks in advance for any help.
  2. Jan 21, 2025 at 5:19 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Owners manual should give you the language. That's where it is for the 2/2.5 gen, anyways. It stated something catch-all like "10% of towing capacity" or something. Curious what you find.
  3. Jan 21, 2025 at 7:34 PM
    Max hitch weight will vary depending on whether or not your using a WDH or not.
    mrlittlejohn likes this.
  4. Jan 21, 2025 at 9:53 PM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    2024 Tundra brochure shows your model (in 4x4) has a max tow of 11,050lbs. You need a minimum of 10% of that weight on the tongue. So they are saying it can handle 1105. Max payload is 1665. Leaving 560 for a two people and supplies. I’d say 1105 should be the max.
    Tundra family likes this.
  5. Jan 22, 2025 at 2:50 AM
    not exactly.
    Jaypown, Ruggybuggy and Tundra family like this.
  6. Jan 22, 2025 at 6:23 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    For half ton trucks, tow weight is pretty much meaningless. Dont worry so much about max tow weight.
    Instead, focus on payload/tongue weight. In a half ton truck, in most cases you will run of out payload before you run over "max tow weight"
    Short story- if the tongue weight/payload in within your trucks capacity, you can tow it. Now there are exceptions, especially with longer trailers and such, but for most cases staying under payload capacity will mean a safe tow.
    Dfrink likes this.
  7. Jan 22, 2025 at 6:31 AM
    OP wants to know max tongue weight, or max towable weight I’m assuming. Towable is easy. Look at the hitch and see what its max rating is. Then, look at the shank and ball equipment and see what the max rating is. Use the lower of the two. Then see what the truck is rated for and use the lower of those two. The value will be different if using a WDH.
  8. Jan 23, 2025 at 11:02 AM
    Chubs
    2024 Platinum TRD
    Thanks very much
  9. Jan 29, 2025 at 5:13 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Payload capacity will be in your door jam. On the same sticker with your vin and tire pressure recommendations. That will be your max hitch weight.
  10. Jan 29, 2025 at 6:11 PM
    Payload is not hitch weight.
  11. Jan 29, 2025 at 6:15 PM
    Tundra family
    Tundra family New Member
    Tongue weight should be 10-15 percent of total trailer weight.
    Max towing for my 2wd crewmax is 10k. ymmv
  12. Jan 29, 2025 at 6:23 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Right, but OP is asking for max weight for the truck.
    KNABORES[QUOTED] likes this.
  13. Jan 29, 2025 at 6:41 PM
    Tundra family
    Max GCVW is in the owners manual.
    Max GVWR for the truck will be on the door sticker
    Max trailer GVWR is usually inside a cabinet door somewhere on most travel trailers along with a ton of other trailer specs
  14. Jan 29, 2025 at 6:47 PM
    The max hitch weight (tongue weight) is determined by the manufacturer of the hitch and is specific to the hitch, not the vehicle. It is not a formula from max tow rating of the hitch. It is not the payload of the vehicle the hitch it is attached to. It is different with or without using a WDH. A hitch may be rated for 500# hitch weight without WDH and 1000# with WDH as the hitch carries the weight different with or without the WDH setup. Typically there is a sticker or metal stamping on the hitch itself with that information. The max tongue weight will be the lowest of these ratings - payload, hitch tongue rating, or hitch / shank implement being used.
    If the hitch is rated for 1400# of tongue weight, but the payload rating is only 1250#, then 1250# is your max. Same hitch with a shank only rated for 600# then the max is 600#. If the hitch is only rated for 1000# tongue weight and the payload is 1250#, then the max hitch weight is only 1000#.
  15. Jan 29, 2025 at 7:24 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’m following now. Thank you :hattip::cheers:
