Bmf and JakeJakes sequoia axle shenanigans
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 24, 2025.
  1. Jan 28, 2025 at 8:11 AM
    #61
    bmf4069 [OP] Michelob Ultra coinesour
    So will the sequoia front diff fit in a Tundra housing? Just the t-case is different? If it doesn't fit, than this is gonna have to get put on hold for a minute. We can still grab the axle, maybe prep it.
    So why not do just gears now? Does it take a whole nother rebuild to do lsds/lockers? How much is that, $1k or so, right?
  2. Jan 28, 2025 at 8:29 AM
    #62
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    A mag base & dial indicator, and a yellow grease pen is cheaper than having someone else install em.
  3. Jan 28, 2025 at 8:34 AM
    #63
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Just my .02 cents. I found the Front to be MUCH more time consuming ( unfamiliar w reverse clambshell) , i went w pull it yard seq front end and I believe Yukon or ECGS 4.30 r&p with air locker in rear. Rear took me 6-7 hours. Front -12-+14 hours to get everything , why they did not add a lip for oil seals is beyond me, i messed that up twice.
    As others have said, I would atleast lock the rear ( prob would skip lsd unless mainly road truck) , just the gears and a true lockable rear greatly enhances these trucks ability to get through stuff. Exspecially bc these old trucks dont flex and like to lift wheels. I personally love my ARB and it is super fun in mud and snow in 2wd ( if you like to slide around) . I went 4.30 as im not going over a 33" tire. Just dont re-gear with-out ditching open diffs ( preferably start w rear) , our IFS is kinda weak (in stock form) for locker in front.
  4. Jan 28, 2025 at 8:42 AM
    #64
    BluegrapeVr6
    J
    Yes. You just need bearing/seal set, back-lash tool , magbase. You are just transferring ring gears. If going air, take time bending copper air-line and be very clean when doing seals and it should never leak air. I used new ring gear bolts , the rear is pretty simple. I found front to be a nightmare. I think i set my backlash at 15. ?? A lil out of spec but my toyota buddy told me to and so far you would not no its even in there. I think it was 15.
    Anyway, like many i did it twice and had ptsd for 2 weeks
  5. Jan 28, 2025 at 9:21 AM
    #65
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  6. Jan 28, 2025 at 9:25 AM
    #66
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    This is what I been trying to tell you since friday... Try $2-3k to install front and rear diffs, plus cost of new gears
  7. Jan 28, 2025 at 9:35 AM
    #67
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Not to be too big of a negative Nellie, but the brakes on my Sequoia aren't any better than the tundra. I'm sure some of that is the weight of the Sequoia, but the brakes on the tundra are really good (01 Sequoia and 01 Tundra). Also, the parking brake job on the sequoia is awful because there's only tiny little holes to access the springs.
    The rear seals leaking so often makes me wonder if it's something with the bearings not being exactly correct. I paid a shop $100 per side in labor, I provided all of the parts and pulled the axles. Or you can grab a lower mileage junkyard axle and new seals.
    Personally, I'd skip the cost of the sequoia axle and spend the money on a locker.
    whodatschrome and des2mtn like this.
  8. Jan 28, 2025 at 9:38 AM
    #68
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So the T3 being 2wd and the fact I provided all the parts, was $1287 to regear and swap LSDs. Plus the price of the 4.10's, bearing kit, and LSD.
    The 4x4 was $4264 for the re-regear. I didn't provide shit but the truck and the busted diffs on it. Thank god the e-locker was unharmed.
    I don't remember how much the first regear on the 4x4 was. I want to say $3k-ish, because I provided everything.
    Which re.inds me, I need to drain and fill the T3 diff sooner than later. Just to check it since it's probably been close to 1k miles on the used gears.
    BroHon and bmf4069[OP] like this.
  9. Jan 28, 2025 at 9:40 AM
    #69
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  10. Jan 28, 2025 at 9:41 AM
    #70
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I have a complete tundra axle for the man, but he's a drum hater.
    My truck has great brakes, and I haven't changed pads or shoes since I've owned it. :thumbsup:
    bmf4069[OP] likes this.
  11. Jan 28, 2025 at 9:42 AM
    #71
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Holy moly. I'm less in for mine F/R including parts, e-locker and REM. Glad I provided my own diff cores.
    FrenchToasty and bmf4069[OP] like this.
  12. Jan 28, 2025 at 9:44 AM
    #72
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yeah it hurt.
  13. Jan 28, 2025 at 9:45 AM
    #73
    des2mtn
    SW
    Tonto cover
    Yeah, I forgot yours included removing and reinstalling the diffs.
  14. Jan 28, 2025 at 10:04 AM
    #74
    So it sounds like pulling mine and sending them to ECGS is a pretty good deal. That would be $1650+shipping to just regear. If the sequoia diff fits, it'll just be the cost of the axle, diff, and Jake's labor to get this done, then I can just lock it at a later date.
    Fuck. Those. Drums. 1905 called. They want their brake technology back.
    @BluegrapeVr6 at this point, I'm not sure what's wrong with the seals. Me and five did them EXACTLY like timmy said to do. This isn't for the rear brakes being better necessarily, just to delete the drums in general and get rid off the tundra axle seals. Oh, and to do something new and "groundbreaking".
  15. Jan 28, 2025 at 10:16 AM
    #75
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What's the rush to do the work of pulling and reinstalling front and rear each twice and paying a pro to do the guts twice? I just don't understand why you'd want to throw away your time and money the second time, when you could wait and do it all at once. But I'm starting to feel like broken record. So I'm going to STFU
    assassin10000 and bmf4069[OP] like this.
  16. Jan 28, 2025 at 10:33 AM
    #76
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Wait y'alls axel seals still leaking?
  17. Jan 28, 2025 at 10:41 AM
    #77
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    #77
  18. Jan 28, 2025 at 10:41 AM
    #78
    Yup. Took about a year.
    No no, you're good. I'm just throwing shit out there to get a better understanding. If it's not intake manifolds or subs I'm lost.
  19. Jan 28, 2025 at 10:44 AM
    #79
    Oops, tagged the wrong homie. Meant to tag @rock climber for the axle seals.
  20. Jan 28, 2025 at 11:18 AM
    #80
    FishNinja
    Lee
    06DC2wd
    #80
    FiatRunner[QUOTED] likes this.
  21. Jan 28, 2025 at 11:20 AM
    #81
    FiatRunner
    Jack
    Yeah, there's no way I'd trust some ebay diffs. Not long term. But for $600, it really gets me thinking.
    #81
  22. Jan 28, 2025 at 11:30 AM
    #82
    FishNinja
    Lee
    06DC2wd
    I mean, it's a gamble. That's really it. It could be 100% legit and a steal. But who fucking knows.
    #82
  23. Jan 28, 2025 at 1:33 PM
    #83
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    https://youtube.com/@precisiontransmission?si=4KAVMgirdR-bAwEY
    Get this dude to do a a340 & aw4 rebuild sxs.
    warning: this dude will make you feel like you are capable of rebuilding your own transmission, and it’s complicated. Some folks cant.
    they may build diffs, dunno.
    @bmf they might be able to tweak shiftpoints or stall to make the 3.90’s better.
    455h0le_dachshund likes this.
  24. Jan 28, 2025 at 2:03 PM
    #84
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Sometimes in order to be innovative, new, and ground breaking, costs a lot of money, lots of bloody knuckles, hard work, and sometimes you find the Juice aint worth the squeeze.
    The 14WA calipers with good rotors and pads, and a properly set up set of drums will ABSOLUTELY stop the hell out of these trucks. Like no joke throw you into the steering wheel in comparison to whatever you are running now.
    Sure i understand the seals leaking and you've busted it down multiple times, i would venture to say you gotta axle problem more than you gotta seal problem. I would replace the axle, put on new cylinders, shoes, linkage, adjuster, and rock out. The drums will absolutely work especially when set up right, the 14wa front brakes are a massive change up front too. There is a whole crap ton of work to get that Sequoia axle to work, as you all have talked about in this thread, everythin from the master cylinder, reservoir, LSPV, and all the fab work to get the Sequoia axle going, is going to put you at 5x the labor as swapping in another good working axle and rebuilding the rear brakes on it.
    Just my measly $0.02
  25. Jan 28, 2025 at 3:20 PM
    #85
    FishNinja
    Lee
    06DC2wd
    100%
    I ran these 285/75r17's with both the stock brakes and the 14wa's. 06 DC has the "larger" calipers too. They would NOT stop these worth a shit. I would have to be conscious about speed/braking distance.
    the 14wa's I run now are fucking choice. They allow the ABS to work normal and I have a lloootttt more confidence now on my trucks ability to stop
  26. Jan 28, 2025 at 4:07 PM
    #86
    Can you rock 16” wheels with 14a’s though?
    bmf4069[OP] and des2mtn like this.
  27. Jan 28, 2025 at 4:19 PM
    #87
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Back in the late 90's and even the early 2000's, labor for a r&p swap was right at $200 and end here in the PacNW. I'd just bring in my axle housing (or 3rd member) to the shop and the new gears and bearing kits.
  28. Jan 28, 2025 at 4:54 PM
    #88
    FishNinja
    Lee
    06DC2wd
  29. Jan 28, 2025 at 5:25 PM
    #89
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    #89
  30. Jan 28, 2025 at 5:27 PM
    #90
    FiatRunner
    Jack
    Exactly my thoughts.
