  1. Jan 28, 2025 at 1:06 PM
    I’ve never seen one fail but I haven’t waited longer than 100k miles to change it. It’s got a black foam covering over it so you won’t burn your hands.
    And remember when testing: never suck, always blow.
  2. Jan 28, 2025 at 1:19 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Took the truck for a drive after weighting the LCAs and loosening/tightening the cam bolts. Truck is still sitting 1.5-2 inches high in the front.
    I’m thinking that the LCAs that were on there are the reason and that could also be the reason my Fox coilovers were having to be cranked down so much. I’m going to back them down this evening before I get an alignment.
  3. Jan 28, 2025 at 1:40 PM
    oscardog86
    oscardog86 New Member
    Southern California
    ^Is that the original paint color? Such a good looking color for out trucks
    G_unit3000 and BroHon like this.
  4. Jan 28, 2025 at 2:04 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I didn't even think of that, but I do have a few different keys and I recently switched to a different key ring for no reason. I'll try the old key.
  5. Jan 28, 2025 at 2:14 PM
    Get yourself a can of tri flow
  6. Jan 28, 2025 at 2:27 PM
  7. Jan 28, 2025 at 2:59 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  8. Jan 28, 2025 at 3:29 PM
    No, that’s incorrect. You’re supposed to rip out your rear seat and put a couple of these 18” monsters back there.
  9. Jan 28, 2025 at 3:50 PM
    Baby bumps! I dig it!
  10. Jan 28, 2025 at 3:54 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    It is. I think it’s called blue steel metallic. It’s still in good shape too. Only problem is trying to find color matched used parts. I think it was only on 05/06 tundras.
  11. Jan 28, 2025 at 5:05 PM
    Someone stab the surround while installing the screw?
    Seen that a few times in my career. Shop owner wold literally smack you upside the head if you ever tried to install a sub and not block the surround with your hand in peril's way. Which, ultimately, would make you put your driver thru the surround, which then came out of your paycheck. :rofl:
    bmf4069 likes this.
  12. Jan 28, 2025 at 5:08 PM
    Man, what I wouldn't give to have that much garage walkaround space and high ceilings.
  13. Jan 28, 2025 at 5:18 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes. This came out of a 2nd gen taco. I only want the 1 10 anyway. I’ll eventually do the AC storage to woofer box mod.
    Like you, I have kids. I’m not putting a box in place of the back seat.
  14. Jan 28, 2025 at 5:59 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    I just noticed those garage door panels are WINDOWS! Look at all that natural light, that's bad ass. (If you are in a low crime area... uh, and can keep the space looking presentable hahaha)
    OH, and the camera lens make those tires look FAT/Wide o_O:D
    oscardog86 likes this.
  15. Jan 28, 2025 at 6:23 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
  16. Jan 28, 2025 at 6:25 PM
    Silver Sky rules!
    bmf4069 and FrenchToasty like this.
  17. Jan 28, 2025 at 7:21 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @bmf4069 am I doing it right?
    Toyota blues are awesome 7/10. It's the remaining few Toyota blues that are either too green, too purple, or too navy. I don't care for those as much. I'm a sucker for all the light blues Toyota makes, much like the blue steel metallic. Blues with a bit of white or silver.
    I have a 10" kicker in Penelope and I can confirm, it is plenty, if not too much bass for an AC if you listen to mostly rock. I keep mine at like -4dB
  18. Jan 28, 2025 at 8:28 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    I use this on my uniballs as well as spray it all over my shock bodies/coilovers. It’s a shame they don’t make it anymore. Stuff is incredible
  19. Jan 28, 2025 at 8:45 PM
    KNABORES likes this.
  20. Jan 28, 2025 at 9:53 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Your rear tire looks like a dually?
    oscardog86 and 455h0le_dachshund like this.
  21. Jan 28, 2025 at 10:02 PM
    sportbike37
    sportbike37 New Member
    FL
    I have a 12" Kicker CompVR subwoofer in a Skar SPL enclosure. It sounds great but takes up half the back seat. And the passenger seat holds it in place.
  22. Jan 28, 2025 at 10:20 PM
    805Tundra
    Ben
    Central Coast
    Got around to mounting a switch panel today. Built a custom bracket for the control box
  23. Jan 28, 2025 at 10:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I don't20240206_171921.jpg have any pics of my box. It's a skinny truck style box. I did the rear seat delete and hung a sheet of plywood across the back wall inside the cab. Some day I'm going to sound deaden and carpet the wood. But for now my sub box and fire extinguisher mount are bolted to it.
    Looks good. What all are you using the switch panel for?
    BroHon, oscardog86, bmf4069 and 2 others like this.
  24. Jan 28, 2025 at 10:32 PM
    805Tundra
    Ben
    Central Coast
    I have some pod lights for the bumper I need to wire up as well as build some tabs
  25. Jan 29, 2025 at 6:12 AM
    Probably highly cancerous if that’s the case.
    805Tundra[QUOTED] and JakeJake like this.
  26. Jan 29, 2025 at 6:54 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Sun Valley probably isn't any more low crime than anywhere else, but it's white-collar crime. Finance, corporate crime, all that. :) Don't need to worry so much about your tools.
    Yeah those tires look unnaturally wide.
    Kimosabe, JakeJake and BroHon[QUOTED] like this.
  27. Jan 29, 2025 at 7:02 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    All the good stuff is.
    JasonC., 805Tundra and BroHon like this.
  28. Jan 29, 2025 at 7:48 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    If we all had an evaluation of our livers (and other organs exposure) I bet breathing a few fumes would be the least of our worries :rofl:
    I can vouch for many years of liver Olympics :burp: But it's never too late to get smart :thumbsup:
  29. Jan 29, 2025 at 9:00 AM
    805Tundra
    Ben
    Central Coast
    But man it keeps everything rust free
  30. Jan 29, 2025 at 9:02 AM
    So is the case with most things that work. They always seem to be cancerous.
    JakeJake and 805Tundra[QUOTED] like this.
