New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Jan 26, 2025 at 5:58 PM
    #721
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    A couple reasons,
    Its fun to go to the junk yard
    I'm able to have the part right away
    It's like-new
    It's environmentally friendly
    It's cheap
    And if you look at what I got, it has all the brackets, bolts, attachments, all the stuff a new hose wouldn't come with. Those parts were rusted/missing from my truck which caused the hoses to be hanging unsupported causing the problem from occuring.
    Hope this helps
    AresEsMaLo, chunk, bmf4069 and 3 others like this.
  2. Jan 26, 2025 at 6:07 PM
    #722
    Like new how? At best it’s 19 years old now. And 24 years old if picked from your year model.
    Bmktw2[QUOTED][OP] likes this.
  3. Jan 26, 2025 at 6:08 PM
    #723
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The thread is called "New to me...":rofl:
    AresEsMaLo and chunk like this.
  4. Jan 26, 2025 at 6:11 PM
    #724
    Solid metal parts like control arms, sway bars, braces, brake shields, bumpers etc. I could see finding some “like new” condition ones. Rubber parts? For these model years, they are all old as hell. Time for actually new bits for hoses and such.
    Bmktw2[OP] likes this.
  5. Jan 26, 2025 at 6:14 PM
    #725
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I get what you're saying and you're probably right. But there's something sweet about getting it out of the junk yard and it working just fine that I find pleasure in. It will be fine, I'll clean it up and put some armor all in it
    AresEsMaLo, chunk, Kimosabe and 2 others like this.
  6. Jan 26, 2025 at 6:17 PM
    #726
    I'm with you on this one.
    If the original lasted this long, and it would've lasted even longer had it not been for the corrosion and other issues, and the one you found is in great shape, hell yeah. I bet that OEM part runs just as long as many of the aftermarket versions, even with 15-20 years on it.
  7. Jan 26, 2025 at 6:20 PM
    #727
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Glad to see your thread pop up again!
    Do you know where this photo was taken? That place looks quite familiar to a small town in Colorado I've been to a couple times.
  8. Jan 26, 2025 at 6:23 PM
    #728
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Thanks!
    That was in TELLURIDE, CO. a beautiful town
  9. Jan 26, 2025 at 6:30 PM
    #729
    FiatRunner
    Jack
    No way, really!!?? It's been 4 or 5 years since I've been there- but a family friend of mine lives just down the street from where that photo was taken. I'm pretty sure.
    You're right, that's some beautiful country around there. Need to go back in my Tundra someday.
  10. Jan 26, 2025 at 6:35 PM
    #730
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    It's right in town when you come down off the tom boy trail. The tomboy trail takes you up the side of the mountain where I slept that night. It's was memorable for sure and worth the trip with the Tundra!
    FiatRunner[QUOTED] likes this.
  11. Jan 26, 2025 at 6:39 PM
    #731
    FiatRunner
    Jack
    Yup, I know exactly where you're talking about. What a coincidence! Did you do Imogene pass? That's the one that connects to that trail, right?
  12. Jan 26, 2025 at 6:45 PM
    #732
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Things got hairy on tomboy trail and dark started setting in so I was not able to make it all the way. I had to use the 4x4 to get as far as I did and with it getting dark I decided to camp and play it safe. Only spent the night in Telluride and then moved on. The trail was a bit advanced for a stock truck but the Tundra did very well regardless. Would like to return someday.
    JasonC. and FiatRunner[QUOTED] like this.
  13. Jan 27, 2025 at 2:42 PM
    #733
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I'm about to pull the trigger on this recommendation from Shifty. Is there any reason why I should not?
  14. Jan 27, 2025 at 3:05 PM
    #734
    What's the goal?
  15. Jan 27, 2025 at 3:17 PM
    #735
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    The truck bottoms out going over small bumps in the road even when unloaded. I want to have the topper on the truck and the suspension not squat lower in the rear than the front... The OEM rear leafs are way too soft and the back of the truck squats
  16. Jan 27, 2025 at 3:39 PM
    #736
    I added the 5 leaf HD springs to mine and it still sags a bit in the back. It does better with a trailer than it did, but I could use another 1/2” or so of lift in the back to be level. I’d like to add RAS, but it’s $600. So I wait.
  17. Jan 27, 2025 at 3:46 PM
    #737
    splicnfiber
    splicnfiber New Member
    Kevin
    OKC
    2003 AC 4.7 2wd SR5
    I agree with this also. I enjoy pulling my own parts plus you never know what else you will find.
  18. Jan 27, 2025 at 4:05 PM
    #738
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    RAS?
  19. Jan 27, 2025 at 4:12 PM
    #739
  20. Jan 27, 2025 at 4:13 PM
    #740
    If I could go back, I would keep my stock rear leafs and just add the RAS HD kit.
  21. Jan 27, 2025 at 8:48 PM
    #741
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    If I were you, I’d look into the regular duty leaf springs and recommend the toyotec or Deaver (same thing) or wheelers off-road add-a-leaf to add in. They are a 3 leaf progressive pack.
    I had the stock leafs and the deaver AAL on my 2003 AC. It gave a little lift, handled extra weight of my topper plus sleeping platform and gear, and allows good suspension travel. I have the same setup on my 06 DC.
    MT-Tundra and Bmktw2[OP] like this.
  22. Jan 30, 2025 at 7:49 AM
    #742
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I seen a post about lights, light bars etc so I decided to share what I whipped out with some lights I had laying around. The lights are mounted to the ac condenser brackets and though they appear to be blocked, the light does shine well and does help when driving on dark roads. I have a switch in the cab I manually operate the lights. If the lights were rectangular in shape they would have shined through the slots in the grill better but I already had these lights so it is what it is now. I'm happy with them so I would recommend if you like the factory original look of the Tundra, this may be a good option for you.
  23. Jan 30, 2025 at 9:43 AM
    #743
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    The thing about the ATS HD (or any similar HD) is the lift. I'm debating this now myself. I think in the end I really do need the HD, but I'd prefer not to go HD. Sounds like you can expect ~1 1/2" of lift, which is a lot. Basically requires that you lift the front of the truck too, unless you want to look silly. Suddenly you've got a jacked up truck, just cause you needed stouter leaf springs.
    I had the HD leaf springs in my Tacoma and I had no complaints about ride, offroad performance and load capacity. But I did end up having to put lift coils on the front to match the height of the back. Didn't want a lift, but ended up with one.
  24. Jan 30, 2025 at 10:00 AM
    #744
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Im with you here... I don't want to deal with a rake on my truck. The RAS system is becoming more and more appealing
  25. Jan 30, 2025 at 10:03 AM
    #745
    RAS will create some lift as well. But it’s adjustable and not that hard to install. So you can crank it up when needed and off when not.
  26. Jan 30, 2025 at 11:54 AM
    #746
    MT-Tundra
    Montana
    I remember you pointing out the RAS system in another thread so I looked into it, hoping it would be the best of both worlds (heavier weight capacity, no lift), but from what I remember, it gives about the same amount of lift as the HD leaf springs.
    Did your HD springs setting much after break-in? I'm leaning more and more toward HD springs and airbags (800+pound slide-in camper, after all), but I'm debating what front coils to get. Want to raise the front a bit, but as little as possible while not having ridiculous rake.
    Far as I can tell, without going custom leaf pack ($$$), there are really no good options for the first gen Tundra to get a heavier-duty rear suspension without getting a lift as a side effect. It's funny cause I see people on the 2nd gen forum complaining that ATS HD springs didn't give them any lift :D
  27. Jan 30, 2025 at 12:07 PM
    #747
    If I had a slide in, I would have airbags.
  28. Jan 30, 2025 at 12:09 PM
    #748
    I gained about an inch in the rear. Have my cap on in both of these. 31.5” tall tires. Since then they haven’t settled much.
    edit: take that back, I went up an inch in tire diameter, so they’ve settled about 1/2” or so.
    Before on Left / after on right
    The Black Mamba and Bmktw2[OP] like this.
  29. Jan 30, 2025 at 12:23 PM
    #749
    MT-Tundra
    Montana
    Cool, thanks. Yeah, even the HD springs say something like "for an additional 500lbs capacity" or something. What I'm thinking...get HDs, get airbags, let the camper ride without using the airbags for a few days..? See if I can't get the lift to settle a bit. Then start using the airbags after that. Maybe avoid going with 2884s in the front, maybe 2883s instead.
    Anyway don't want to hijack this thread.
    KNABORES and Bmktw2[OP] like this.
  30. Jan 30, 2025 at 12:45 PM
    #750
    MT-Tundra
    Montana
    Remember how much lift?
    I'm sure I've just missed it, but I don't see a lot of AAL talk on here. There's people who went inexpensive HD packs, and people who went super expensive or custom packs. The talk I saw about one of the AAL products required removing the overload spring, which kinda defeats the purpose for me. Since my stock leafs are spent, I have to buy new ones anyway. So the options are, for someone who definitely hauls heavy weight (not just topper and gear), and wants as little lift as possible...:
    -HD springs, and either Sumo Springs/Timbrens, or airbags. Will likely get 1 1/2" lift (far more than I'd like, but I'm willing to do it)
    -New stock springs, and either Sumos Springs/Timbrens or airbags. No lift, unloaded performance no better than OEM (maybe a bit worse since travel is limited), but the support is there when needed.
    -New stock springs + AAL.
    The last option I know very little about, and whether it's actually the same thing as HD springs, in the end.
    Now if your stock leafs are still good, the equation is different. But for someone who first and foremost needs new leaf springs, I haven't found a great rundown of all the different options and compromises associated with each.
    Hopefully this is helpful to OP and not a hijack... :)
