Got a Tundra.
Discussion in 'New Member Introductions' started by Redoak, Nov 28, 2024.
  1. Nov 28, 2024 at 12:03 PM
    Redoak
    Redoak [OP] New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Had the Toyota bug since we got a 4 Runner several years ago.
    Found a 2006 Tundra 4X4 with less than 200K miles we picked up this week.
    Everything still works.
    Had it checked at local shop and all they found was needs carrier bearing, axle seal, and a tie rod end.
    I plan to go through it, install new water pump, timing belt, change all fluids, and any other maintenance I can think of.
  2. Nov 28, 2024 at 12:12 PM
    Welcome to the site. Download some pictures when you can.
    Redoak[OP] likes this.
  3. Nov 28, 2024 at 1:50 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Welcome from VA
  4. Nov 28, 2024 at 2:03 PM
    ZHUNTER
    ZHUNTER New Member
    North Georgia
    2020 Quicksand Tundra DC TRD
    Westin Winch mount tray w/ custom light bar, avs hood deflector, 3” lift, badlands winch w/ wireless remote, bed stiffeners, Toyota Predator steps, Husky Floor liners
    Welcome!
  5. Nov 28, 2024 at 2:34 PM
    Redoak
    Dave
    none
    Pretty clean truck for an ‘06.
    I like it.
    Tacoma-Tundra and Fobroader like this.
  6. Nov 28, 2024 at 2:35 PM
    Redoak
    Dave
    none
  7. Nov 28, 2024 at 2:35 PM
    Redoak
    Dave
    none
  8. Nov 28, 2024 at 3:58 PM
    Welcome from NY.
  9. Nov 28, 2024 at 6:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  10. Jan 26, 2025 at 3:26 PM
    Redoak
    Dave
    none
    Couldn’t find exactly when timing belts, water pump etc was replaced so parked it until can change.
    Got parts in and Finally getting around to changing out all the things can find I don’t like looks of.
    Along with timing belt, and water pump kit, Will be changing out all vacuum hoses, coolant lines, idler pulleys, plugs, valve cover gaskets, cam and crank seals.
    Cam seals would probably be okay with some additive, but I’ll already be close by removing valve covers so might as well.
    I won’t lie; last time had my hands on heads, and cams similar to that was about 25 years ago when worked as cylinder head tech in auto machine shop with access to all types tools so just a but on the nervous side to be doing it at home with limited work space, and tools.
    This little thing I bought yesterday been a champ. Used the 1/4” impact drivers for years at work, but since it usually busts the 1/4” drive adapters to bump it up to 3/8 drive sockets bought the actual impact.
    Did good this evening. Had to put one of my high output batteries on it, to have power to remove the harmonic bolt, but it did itIMG_2319.jpg .
  11. Jan 26, 2025 at 4:26 PM
    boatsnbikes
    boatsnbikes New Member
    From the looks of the reflection in the pictures whoever had that truck took care of it. Black is very telling and that looks like a mirror. Should be better in person. Interior shows its age but that’s to be expected. I would not be scared to buy that truck at all. Good find
  12. Jan 26, 2025 at 4:30 PM
    TRD_84
    TRD_84 New Member
    Chad
    Ohio
    2024 Lunar Rock Tundra Limited TRD Off-Road
    Rough Country Vertex 2.5 Leveling Coilovers 1” Cornfed rear spacer 275/65r20 Nitto Terra Grappler G3 WeatherTech Alloy Tonneau Cover Body Armor 4x4 Power Running Boards Bedrug Classic Bed Mat XPEL Prime XR ceramic window tint BeatSonic Amp (Non JBL system) TRD Puddle Lights from MVPAutoSupplies TRD air filters TufSkinz Foam Console Inserts Spigen Screen Protector TRD Pro Grille Swap w/ OEM marker lights TRD Dual Exhaust tips TRD Pro Camo rear bumper and front fog lights cover TRD Pro glovebox trim swap Matte Black interior vent overlays
    Welcome from Ohio!
  13. Jan 26, 2025 at 6:57 PM
    Redoak
    Dave
    none
    Thanks for the welcome everyone.
    Thanks.
    We really like it. Can't wait to get all the parts on it, and start driving it again.
  14. Feb 20, 2025 at 2:45 AM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD DC 4.7 V8 AT 2WD
    Welcome from NC :hattip:nice looking truck. I've made subtle changes to mine. I'm going to paint the side mirrors, but only after I install an alarm system. Keep us posted
