  1. Jan 26, 2025 at 8:59 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Keep up updated on the experience!
    DirkS[QUOTED] and HulkSmurf14 like this.
  2. Jan 26, 2025 at 9:57 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Well Here it is. "Final" build as of now. Will be taking a long break to enjoy and drive this around the North East to snowboard the rest of winter. Wallet is indeed hurting, some might say it's crying. I do rub a little on plastic liner turning going uphill so I do need to trim a little bit more. Will do so this week hopefully. Wheels hum more than I thought they would but doesn't bother me really. Miles per gallon tbd was getting 12.5 on 295/70/r18's. Coming from Fox 2.5 Race Series DSC which I will be selling after I clean them up - same for my old black rhino caprock wheels (18x9.5 +12 offset). In no rush to do anything but enjoy the truck now.
    Loving how it sits and the King Blue.
    As it sits distance from ground to fender -- will wait a week to see where it stands but does lean a little driver side
    Ground to Fender
    FL 41.75 inches
    FR 43
    RL 43.25
    RE 44
    Mods:
    • TVS1900 Supercharger
    • Re-gear to 5.29’s
    • JBA Upper Controls Arms (powder coated)
    • King 3.0 Front Coilovers
    • King 3.0 Rear Triple Bypass
    • Deaver U748 Leaf Springs (with extended brake lines and Timbren bumpstops)
    • Black Rhino Rapid’s 17 inch Wheels
    • Nitto Ridge Grapplers 37x12.5 inch Tires
    • DRT Cab Mount Relocations
    • N-Fab M-RDS Front Bumper
    • Black Oaks led 40 inch dual row 5w light bar
    • Rigid D-XL Pro spot ditch lights
    • Diode Dynamics SS3 Pro fog lights
    • Baja Designs Squadron Pro work/scene in rear bumper
    • ARB Twin Compressor (engine bay mount)
    • Cali Raised Switch Panel for all lights and compressor
    • BakFlip MX4 Tonneau Cover
    • SPD Performance Exhaust - downpipes and muffler
    • Radium Catch Can
    • Katzkin Front Heated/Cooled and Rear Heated Seats
  3. Jan 26, 2025 at 10:00 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    That truck is sweet:thumbsup:
    WinterWarlock21 likes this.
  4. Jan 26, 2025 at 10:27 AM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    Installed Eibach Pro Truck Sport shocks on front, factory springs, lowest notch for stock height. Wasn’t too hard at all. Feels good and smooth so far. Had a driver side leak on factory yellow Bilstein. It’s a touch higher, not sure if anyone knows if it’ll settle more? I tow a camper and liked the stock height as I sat level when loaded.
  5. Jan 26, 2025 at 11:18 AM
    SAGE63
    San Diego County
    Create a build thread and track your fun times in there.... it is a good way to keep your historu in one place
    Tripleconpanna and bulldog93 like this.
  6. Jan 26, 2025 at 11:21 AM
    WinterWarlock21
    South Jersey
    Think I will in the next coming week when I look back at where it started as a stock truck lol.
    bulldog93 and SAGE63[QUOTED] like this.
  7. Jan 26, 2025 at 11:24 AM
    SAGE63
    San Diego County
    That reminds me I need to update mine... lol
  8. Jan 26, 2025 at 11:40 AM
    AthenaOffroad
    AthenaOffroad YouTube wannabe
    Niko
    2014 Blue Ribbon Metallic Tundra DC SR5
    Finally found someone relatively close to me that was selling the same set of 20 inch BBS wheels i have so i can finally have a full size spare! now just sand prime and paint, then get a tire and figure out what to do with the other 3
  9. Jan 26, 2025 at 1:13 PM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Really nice build!
  10. Jan 26, 2025 at 2:32 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Braved the cooler temps to wash the salt off the truck down here in SE. Couldn’t stand it any longer and was slightly warmer today.
    Tripleconpanna, bulldog93 and BR73 like this.
  11. Jan 26, 2025 at 3:50 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Opened up the tailgate to figure out why my power lock wasn't working - thinking it just needed a little grease maybe.
    Discovered the screw holding it in place was missing altogether and that the solenoid was just flopping around (also explains why the handle seemed a bit loose as well).
    Shining a light around down in the tailgate, I found the missing screw was down along the outer cavity by the drain hole. So I made a makeshift magnetic "grabber" with a breaker bar and a couple small rare earth magnets and fished it out. Then put some locktite on the screw before putting it all back together.IMG_3423.jpg
  12. Jan 26, 2025 at 5:10 PM
    Vizsla
    Vizsla 2 = 2.5
    Finished a few projects.
    Maintenance - Motor and differential oil change, new air filter, MAF sensor cleaned, and alignment necessary due to widening front suspension .25” on each side
    Paint - Front bumper and skids repainted (skids painted black instead of gray), rear boxed frame coated internally with Eastwood internal frame coating
    Wiring - Added onboard battery maintainer
    Storage - Installed Rigid toolbox in bed for tools that stay in the truck
    Bumper
    Battery maintainer
    Toolbox
  13. Jan 26, 2025 at 5:22 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    At least it was an easy fix.
    Tripleconpanna likes this.
  14. Jan 26, 2025 at 5:38 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yep.
    And glad the screw was still there and easy to find/retrieve.
    rdiddy5 and bulldog93[QUOTED] like this.
  15. Jan 26, 2025 at 5:40 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What was the Aussies lead time and shipping cost? I emailed about their extreme valve body and haven’t heard back yet.
  16. Jan 26, 2025 at 5:54 PM
    bflooks
    bflooks New Member
    Metrowest MA
    If Rey doesn't know, I can let you know tomorrow. I'm pulling the trigger on the same unit. They were very responsive on Friday so I'm hopeful it will continue.
    ZPhilip[QUOTED] and reywcms like this.
  17. Jan 26, 2025 at 6:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Haven’t ordered the valve body yet. They mentioned those aren’t on much lead time when I spoke to them awhile back but that may have changed. That’ll go in most likely after my planned run due to timing
    ZPhilip[QUOTED] likes this.
  18. Jan 26, 2025 at 8:05 PM
    ZPhilip
    Philip
    West Chester, PA
    Great. That will be helpful. Thanks!
    bflooks[QUOTED] and reywcms like this.
  19. Jan 26, 2025 at 10:57 PM
    Bandade
    Bandade New Member
    2021 SR5 TRD SPORT
    Yes sir, they are. They came with the truck stock. I can take pics if you need them. PM me
  20. Jan 27, 2025 at 7:30 AM
    Florida AF
    Logan
    North Florida
    Ended up on a second concrete pad and was able to finish wiring in the SS gifted fog lights. Noticeably dimmer than the illegal white ones, but now... legal! I found my Aux switch today, so I may wire that up this week so the deer spotters on bottom are back online. That is TBD as I am tired of being on the ground... damn I need to finish my barn and buy a lift....
    Headlights only:
    Headlights and fogs:
    I love that I can see the sides better, I am actually shocked there wasnt a deer in this photo.. these damn things are everywhere.
  21. Jan 27, 2025 at 7:31 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Looks good and plenty of light. Cruising around knowing you could be pulled over by a bored or concerned police is not fun, being able to see and not get pulled over for it sounds like a win!
  22. Jan 27, 2025 at 8:24 AM
    attillatundra
    attillatundra New Member
    Been looking at those shocks. Curious how they are feeling for daily use and so you have any pics to show how it sits now just for comparison? Also, how do they compare to the Bilsteins? TIA
    BR73 likes this.
  23. Jan 27, 2025 at 8:43 AM
    Florida AF
    Logan
    North Florida
    Amen to that! They do the job well and I think they look damn good inside the bumper too. So it is a win/win across the board. My SS nailed this one.
    woods[QUOTED] likes this.
  24. Jan 27, 2025 at 10:29 AM
    Geodude82
    Geodude82 New Member
    I took it out into the Pennsylvania wilds last week, it did great! I had to stop to take some pics and thought I'd share :). I'm slowly making some mods and upgrades, otherwise, just really enjoying the truck.
  25. Jan 27, 2025 at 10:30 AM
    Bergy24
    Bergy24 New Member
    Pictures did not post. Where exactly are the "Wilds"
    French Avocado and 23Tundy like this.
  26. Jan 27, 2025 at 10:52 AM
    Geodude82
    The Wilds are several counties in the northcentral part of the state. Remote and amazing. I highly recommend anyone who is into hiking and camping to go out. (I see the photos, but i'll try to repost or something)
  27. Jan 27, 2025 at 10:54 AM
    Bergy24
    Bergy24 New Member
    They are showing now. Looks like a cool place to visit (No Pun intended)
    I am from south east Pa, and will need to check this place out sometime.
    23Tundy and RobertD like this.
  28. Jan 27, 2025 at 12:41 PM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    Hello, here is a pic from today, day 2, very close to level ground, empty bed, 1/2 tank of gas. High speed compressions are insanely softer, smooth, supportive and more controlled. This would be normal stuff on freeways and over 40 on streets with pot holes, railroads, etc. Highspeed rebound would say is medium as it lifts you back up controlled and ready for next compression. Low speed compressions, and rebound, are medium to firm, again much better than before feeling overall more controlled. At the lowest notch for stock height, at sag when parked, you are deeper in the shocks range of travel and might be why it is slightly higher. Overall, very happy!
  29. Jan 27, 2025 at 12:51 PM
    attillatundra
    Thanks for the update. It looks very good and to my eye almost level but i would expect it will settle a bit and you will get some rake back. It is nice to hear that the ride is good and more controlled. I mostly don't want the harsh impacts that some shocks give with small road imperfections. Plus i want more control than stock shocks.
    caboj[QUOTED] likes this.
  30. Jan 27, 2025 at 2:40 PM
    23Tundy
    23Tundy New Member
    SE Pa
    19 SR5 Cement crewmax
    5100s,Diode Dyn fogs, ARE topper, AJT interior chrome delete, meso lights/vleds, RC neoprene seat covers.
