Subwoofer Rattling JBL
Discussion in 'Audio & Video' started by APG, Feb 23, 2022.
  1. Feb 23, 2022 at 7:22 AM
    APG
    APG [OP] New Member
    2007 Green Kevlar Limited CM 5.7 4x4 TRD
    Kevlar Paint AlphaRex LED Headlights Aftermarket tail-lights
    Hello,
    The subwoofer (I think) in the JBL system makes a rattling noise when turning up the radio/aux.
    I have mitigated this in the last few months by reducing the bass to -5 but want to get it fixed. The sound becomes aggressive when the bass is set to +5. Any ideas/experience? Much appreciated.
    Here is a video:
    https://youtu.be/JivEuY-z1Xc
  2. Feb 23, 2022 at 7:37 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    you're barely powering it and it sounds like its blown out. maybe considered just replacing it?
  3. Feb 23, 2022 at 8:03 PM
    APG
    APG [OP] New Member
    Any ideas on how I can decide whether it is a power issue or the subwoofer? Haven't been able to find this issue online.
  4. Feb 23, 2022 at 10:14 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    Sure sounds like the subwoofer is blown. Pull off the grill, check the cone travel. Is it rough,grating, check to see if the cone material is ripped. The travel should be a a smooth transition in to out... If there's any rubbing, grinding, or sticking, replacement time!
    Good luck, let us know what your fix is!
    BoysandHisToys and 1lowlife like this.
  5. Feb 24, 2022 at 7:33 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You take the woofer out and use a woofer testing apparatus to do a rub/buzz test. By that time it would be good to have a replacement on hand anyway.
  6. Feb 24, 2022 at 7:59 AM
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    That sub is toast. You're hearing the voice coil/former grinding every time the cone travels.
    Time to upgrade.
    KK6PD likes this.
  7. Feb 24, 2022 at 10:40 AM
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    Mine did that and it was the surround separated from the cone. I bought a new foam surround from ebay...easy fix and cheap! https://www.ebay.com/itm/302420025327
    Getting ready to do the front doors too.
  8. Jan 14, 2025 at 8:33 PM
    APG
    APG [OP] New Member
    Hello everyone. Over the last few years I have been driving the truck in silence (not my primary vehicle). The problem has grown to encompass not only the sub but now many of the speakers.
    So, I have purchased a set of the 12 OEM JBL speakers and plan to replace all of them. Should be a pretty uneventful install (because they’re the same speakers and should plug and play right in). While I’m in the door panel I’m gonna add some sound deadening (cause why not). I will post a before and after.
    @cran2 thank you for the recommendation. Since I was already going to have to take the door apart I went ahead and just replaced the whole speaker.
    cran2 likes this.
  9. Jan 24, 2025 at 11:36 PM
    APG
    APG [OP] New Member
