“Low Fuel” in the display
Discussion in '2.5 Gen Tundras (2014-2021)' started by Centershot, Jan 24, 2025.
  1. Jan 24, 2025 at 4:17 PM
    Centershot
    Centershot [OP] New Member
    2016 Black Tundra Limited TRD
    The other night on my way home from my 2016 Tundra just died. I coasted to the side of the road and all it would do is crank. It was 10 degrees and I killed the battery. I finally got a chance to start looking at it tonight and found the 10 amp ING fuse was blown. Swapped it out and the truck fired right up. Cleared the ignition code and took it for a ride and it still had Traction Control Off displayed and the button wouldn’t work, it also say Low Fuel when you scroll through. After starting it a couple times the traction control button started working but the low fuel is still on. The guage says i have a little over a quarter tank still which is what i had before the fuse issue. Will this eventually relearn its self or do i need to check further?
  2. Jan 24, 2025 at 4:21 PM
    I wonder what caused that fuse to blow. You could disconnect the battery for a bit and see what happens.
    HulkSmurf14 likes this.
  3. Jan 24, 2025 at 5:40 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Original alternator and battery? Yeah wonder what would cause a blown fuse like that for ignition specifically.
