  1. Jan 24, 2025 at 12:46 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Use it for powder coating!
  2. Jan 24, 2025 at 1:23 PM
    NWPirate
    Zach
    WA
    :laugh:
    You can figure out amps if you know the watts. :boink:
  3. Jan 24, 2025 at 1:40 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Question for you guys. Can you easily lift your 2 car, aluminum garage door with one hand when its released from the opener? I tightened up the spring when I installed a new opener but I feel like its still on the heavy side. Doesnt come back down when its at the 90* bend but it does take a bit of strength to get it moving from the closed position. Doesnt fling open by any means, not even close. Spring is the 15yr old original, so Im not surprised its taking a bunch of turns to get it to assist.
  4. Jan 24, 2025 at 1:51 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    If it were electric I would be really considering it.
  5. Jan 24, 2025 at 8:43 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Not a chance
    My fully insulated 10’ wide x 9’ tall doors are about 300lbs each for the four panels combined. Not picking those up without the spring helping.
  6. Jan 24, 2025 at 8:55 PM
    Maybe, but not from the ground up. I dont think the rails would like that since it would technically not be lifted with balance.
  7. Jan 25, 2025 at 9:21 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Shouldn't be terribly difficult to open and should stay in place if you open the door halfway up.
    If it drops they need more tension.
  8. Jan 26, 2025 at 4:07 PM
    Was tired of the basement being completely dark unless the lights were on. Switched out some outlets so there’s walkway lighting in the basement hallway
  9. Jan 26, 2025 at 4:43 PM
    Tundra family
    Tundra family New Member
    Ordered an upgraded maxxfan, pretty stoked about all the cool features. I learned that if you reverse the vent fan it creates a suction that pulls in the canvas as I lower the top, it'll keep me from having to crawl into the loft with the top halfway down to do it manually.
  10. Jan 26, 2025 at 4:45 PM
    They are awesome but I don’t know if they suck hard enough to move canvas. I’ve also read they don’t like voltage irregularities so I put a regulator on mine
  11. Jan 26, 2025 at 4:52 PM
    Tundra family
    Definitely needs a regulator, my current low end model (maxxfan V1) doesn't work on the lower settings unless I'm on shore power.
    OldGuy03 likes this.
  12. Jan 28, 2025 at 8:57 AM
    Tundra family
    Cleaned out the drain trap on the front loader. Supposed to be done every 30 days and this is the 1st time in probably 18 months. I gotta get better at routine maintenance, same with my truck.
    Lifer, Blufin, T-Rex266 and 5 others like this.
  13. Jan 28, 2025 at 9:08 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Can you share the details surrounding your door on the right? I’m looking to make some French closet door and that’s the style I’m shooting for. Except they’ll need to be pretty tall. Wine bar is coming out; closet going in.. unless someone sees any issues with that
  14. Jan 28, 2025 at 10:24 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    For a second there I was wondering "do I have one of those on my tractor??" and then I looked into the background of the photo....
    :smack:
  15. Jan 28, 2025 at 10:42 AM
    Tundra family
    Ya, I realized how I wrote it doing a proofread, but figured "meh whatever" :rofl:
  16. Jan 28, 2025 at 8:01 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    I added a sign to my garage today. Found this sign at a gift shop when I was in Orlando last week.
  17. Jan 28, 2025 at 8:03 PM
    The first door on the right in the hallway? That’s where the furnace and water heater are
    Mater[QUOTED] likes this.
  18. Jan 28, 2025 at 8:08 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Just the height and style of door. Looking for something similar for closet doors. Most closet doors are pretty ugly these days
  19. Jan 28, 2025 at 8:17 PM
    Let me ask the wife tmrw if she knows the style
  20. Jan 28, 2025 at 8:34 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Normally architects are the bane of my existence, but, since I work with them I got you. That is a colonist style door, also can be referred to as a 6-panel colonist. Most residential doors are 80" tall but you can probably find other sizes and I'm 1400miles away from putting a tape measure on @T-Rex266's door :D
  21. Jan 28, 2025 at 10:20 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Installed a Ring flood light. These things are pretty cool. My old flood light in this spot died an early death due to bugs going into the light and shorting it out haha. I haven’t put up my usually hardwired POE cameras at this house so decided to try out this Ring option which just uses the existing electrical and a wifi connection (sub 30min install with basic tools).
    So far so good, downside is monthly subscription but you pay that with an offsite DVR camera backup anyways. The Ring app and camera delay is surprisingly fast. It is annoying to have my phone buzz whenever I walk outside as it “recognizes a human” in about 1 sec. Fighting the T-800s is gonna be brutal in a few years.
  22. Jan 28, 2025 at 10:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    6 panel? Unless I’m seeing a different picture that’s a 2 panel that looks more like this, no?
  23. Jan 29, 2025 at 1:05 AM
    eddiefromcali
    Eddie
    100% Stock
    Did all our doors in 2 panel a few yrs back. Definitely a different look than 6 panel
  24. Jan 29, 2025 at 2:31 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Swapped out the 100 Watt 10" sub woofer, which I thought was really good when watching movies untill this bad Larry showed up...
    1,600 Watts with a 16" driver at 95# and Holy smokes, pictures are falling off the walls on the second floor.
    Man this thing delivers a deep low frequency so low you can barely hear it but your ass rumbles through the couch.
    Best audio addition for the home theater!
  25. Jan 29, 2025 at 4:45 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    that's just a more universal end table :D
  26. Jan 29, 2025 at 6:32 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Gotcha. Another follow-up dumb question. What’s the between a two panel and shaker two panel? Is it just that the shaker has 90* cuts and no beveled edges. Sorry, just a newbie trying to learn over here :D
    TaquitoBandito likes this.
  27. Jan 29, 2025 at 6:34 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Looks great! Definitely something I’m after.
    How are those doors standing upright by themselves? :eek:
    WAtundra4x4 likes this.
  28. Jan 29, 2025 at 7:01 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Question for you and anyone else who has a sub on hard wood or any hard floors. How do you keep the sub from walking away? We've always had carpet so it's never been an issue. In our new house we have LVP flooring and I can't keep my sub from trying to walk half way across the room and then unplugging itself.
  29. Jan 29, 2025 at 7:04 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Have you tried some rubber on the feet?
    https://www.amazon.com/Satin-Silver...e+floor+protectors&qid=1738163036&sr=8-2&th=1
    This product seems okay, but I am sure you can find similar that would be perfect for you.
    HulkSmurf14 and TaquitoBandito like this.
  30. Jan 29, 2025 at 8:00 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    It has really nice rubber or silicone feet the 100 watt one had half dollar sized feet this new one has four 1"X3" rectangular feet and it would definitely need it.
    I still can't believe the sound that comes from it,it is truly remarkable.
    TaquitoBandito, OldGuy03 and woods like this.
