Bmf and JakeJakes sequoia axle shenanigans
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Jan 24, 2025.
  1. Jan 24, 2025 at 9:28 AM
    bmf4069 [OP] Michelob Ultra coinesour
    After conversing with @JakeJake this morning, the time has come for the sequoia axle swap in Ironman. Fuck those rear brakes and fuck those rear axles seals. We're headed to the PaP next Saturday to grab the axle and booster/MC from a sequoia. While doing this I'm sending my diffs of to be re-geared. I'd like lockers, but it's just to pricey at this point.
    So what other parts are gonna be needed on this? I'm trying to head off any problems at the pass before starting. I know the brake lines are gonna be different, but is there anything else?
    Tagging @des2mtn for the rear brake advice. I forgot who else has rear disks.
  2. Jan 24, 2025 at 9:41 AM
    Can you at least find a Seqouia axle with LSD?
  3. Jan 24, 2025 at 9:46 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    You’re gonna need spring perches, or back half iron man to get some 4 link goodness.
    check the pinion flange. Also, not quite sure what the 3-channel vs 4-channel abs is going to need.
    this is exciting. Got a date planned? Get a plastic intake manifold and big ball lca’s & knuckles while youre at it.
  4. Jan 24, 2025 at 10:06 AM
    Found the perfect donor…..
  5. Jan 24, 2025 at 10:07 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I'll strip and plate the frame, new shock tower crossmember/ relocation, Shave the Sequoia axle, U-bolt eliminator, etc like I did on my truck. Leaf spring mounts, and leafs will remain standard tundra stuff. That part is all well known territory for me and "easy"
    Working brakes seems as easy as going to the larger bore sequoia master, a Wilwood adjustable prop valve, and some plumbing. I'll have to dig more into the ABS side of things
    @bmf4069 Whats the added cost of lockers? Welded rear?:rofl:
  6. Jan 24, 2025 at 10:15 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  7. Jan 24, 2025 at 10:16 AM
    Ohhhhh, I like that!
  8. Jan 24, 2025 at 10:18 AM
    Dual lockers:
    Or, full LSD:
    Open diffs:
  9. Jan 24, 2025 at 10:19 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  10. Jan 24, 2025 at 10:20 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Man just wait til the money is there to regear and lock the rear. It's worth it to buy once and cry once on this.
    noahrexion and The Black Mamba like this.
  11. Jan 24, 2025 at 10:23 AM
    I can do a locker in the rear, but I want, no, NEED both locked!
    Bmktw2 and The Black Mamba like this.
  12. Jan 24, 2025 at 10:27 AM
    We can pull the fuse on the ABS for now. Not like mine works anyways. Do I need to buy the u-bolt eliminator and brake prop valve?
  13. Jan 24, 2025 at 10:35 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    e locker up front, lsd out back. Dont wanna have to turn on your locker for wet grass. Or whatever the equivelent is. Locker diffs are open until theyre not.
  14. Jan 24, 2025 at 10:36 AM
    JakeJake
    2000 Tundra AC 4X4
    Prop valve yes- https://www.amazon.com/Wilwood-Engineering-260-12627-Adjacent-Proportioning/dp/B011B4UX5U
    The u bolt eliminator is 100% fabbed in house, but we do need to talk about what my labor costs will be :rofl:I've got a "homie hook up" price in mind for the week of my time. Call/text me about that.
  15. Jan 24, 2025 at 11:13 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Then wait til the money is right and do it all at once. No use in paying install twice and buying new bearings and stuff twice.
  16. Jan 24, 2025 at 11:24 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I'm telling you as a friend and someone who had had to pay for a total of five re-gears, one LSD and one locker.
    It hurts the wallet really good.
    Also don't let some off-road Toyota shop do it. Make sure an actual diff shop does it
  17. Jan 24, 2025 at 11:44 AM
    Dude, just get the Seqouia front diff, it's Torsen, you can have all-time 4WD!
  18. Jan 24, 2025 at 12:30 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I thought the torsen was in the tcase?
    KNABORES likes this.
  19. Jan 24, 2025 at 12:32 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    see signature.
  20. Jan 24, 2025 at 12:44 PM
    Maybe I'm wrong. But why would they call it a "Torsen diff" if it was in the transfer case? I can't imagine all this is in the transfer case? Although I think this video is invalid claiming it technically "locks"
  21. Jan 24, 2025 at 12:51 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Our stock t-case is basically a spool, replace that spool with an open diff, or torsen, or locker, and get ‘triple locked’.
    the rear driveshaft is direct, the torsen operates the chain.
  22. Jan 24, 2025 at 12:53 PM
    This sounds hot, if only I had a third, uh, member. Yeah, third member applies, right? :rofl:
  23. Jan 24, 2025 at 12:54 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Whats the first member?
    455h0le_dachshund likes this.
  24. Jan 24, 2025 at 12:56 PM
  25. Jan 24, 2025 at 1:02 PM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I can't echo this enough. On my T100, I'm on my 4th rear regear. First a LSD, then 4.10>4.56 LSD, then 4.56 Elocker, now 4.88 Elocker. With the 4.56's I was at least able to find factory front diff's in 4.56, as the T100 uses the same front diff as the '86-95 pickups and 4Runners. But regardless, like others have said, buy once and cry once. Wait until you can do everything you want to. Save your back, and your wallet by only pulling the diffs once and paying for them once.
    This is correct. They have a center torsen diff. Thats why the Sequoias have the 2hi-4free-4hilock-4low transfer cases.
  26. Jan 24, 2025 at 1:11 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    An awd t-case would be cool, but i doubt its worth the effort. With lsd theres not much i cant do in 2hi. 2lo would be cool as a penguins pecker though.
    250000yota and 455h0le_dachshund like this.
  27. Jan 24, 2025 at 1:44 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    The sequoia also has a high clearance rear sway bar. I know that some over landing guys completely delete the front sway bar and install just a rear.
    I’ve had lots and lots of various lockers, LSDs, and gear swaps in my various vehicles over the years. If you can afford it, i’d go with a full selectable both front and rear (either ARB or an E locker). And no one ever complained about going “too deep” when choosing a particular r&p gear ratio.
  28. Jan 24, 2025 at 1:50 PM
    whodatschrome
    lots of dents
    this right here!! I shaved down a pair of Currie 9” axle housings that i used to have in my jeep cj7. I think i gained about 3/4”…which is like stepping up to a tire that’s 1.5” taller. If my tundra was more offroady, i’d do this in a heartbeat to my axle. Heck, maybe sometime in the future when i have the 3rd member removed, i might get motivated to do this.
    The Black Mamba likes this.
  29. Jan 24, 2025 at 1:52 PM
    Oh, I'm just sending my diffs to ECGS and having them re-gear and send me back a built diff.
  30. Jan 24, 2025 at 1:54 PM
    JakeJake
    2000 Tundra AC 4X4
    well shaved as in down to bare tubes without any unnecessary bracketry, although a "real"l 3rd member shave is certainly possible.
