P2441 Code
Discussion in '2nd Gen Tundras (2007-2013)' started by Striperfishing, Jan 23, 2025.
  1. Jan 23, 2025 at 9:34 AM
    Striperfishing
    Striperfishing [OP] New Member
    This morning I got a check engine light and had it read as a p2441 code. I was wondering if it is safe to drive mechanically and also what the repair cost most likely be having it done at an independent shop. Meant to post this in 2.5 gen as it is a 2014 not sure if that changes anything.
  2. Jan 23, 2025 at 10:58 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Jan 23, 2025 at 8:05 PM
    Striperfishing
    Watched the video on the Hewitt kit and the install looks very straight forward so I ordered one. Now just going to wait for arrival and hope it fixes the issue without having to buy the PSO.
  4. Jan 24, 2025 at 9:16 AM
    Striperfishing
    I’m currently doing the bypass plates on the 4.6l which has the system on the top of the motor not through the wheel wells, I’m having trouble getting the gasket and flange to separate from the actual system does anyone have any tips on how to get it to separate?
