3” TRD Lift Stop Sale
Discussion in '3rd Gen Tundras (2022+)' started by jduffy192, Jun 5, 2024.
  1. Jan 22, 2025 at 6:52 PM
    #151
    jtweezy
    jtweezy New Member
    Jeffrey
    I don't get it. The whole point of all the additional parts (aside from just the shocks, springs and upper control arms) is to correct the geometry and get the alignment back in spec with the new height.
  2. Jan 22, 2025 at 6:52 PM
    #152
    sudobash
    sudobash New Member
    Just because they "correct" it, doesn't mean the tech is aligning it well or that the machine has the most up to date alignment specs.
  3. Jan 23, 2025 at 7:17 AM
    #153
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    This would be my guess. The particular alignment rack is out of date or not calibrated correctly
  4. Jan 23, 2025 at 8:38 AM
    #154
    Libagui
    Libagui New Member
    Librado
    2024 midnight black Toyota Tundra Limited, TRD offroad
  5. Jan 23, 2025 at 8:41 AM
    #155
    lapoolboy
    lapoolboy New Member
    sudobash likes this.
  6. Jan 23, 2025 at 9:23 AM
    #156
    LohssaToy
    LohssaToy New Member
  7. Jan 23, 2025 at 9:30 AM
    #157
    lapoolboy
    Uhhh, thanks Sherlock. I was telling the other dude he was wrong.
  8. Jan 23, 2025 at 9:31 AM
    #158
    LohssaToy
    Sorry dude, I thought I quoted him...
  9. Jan 23, 2025 at 10:22 AM
    #159
    KuehnMK
    KuehnMK New Member
    2023 Tundra Crewmax 4X4 Platinum
    I've had my TRD lift kit now for a month, and I can attest that my alignment is perfect! LOVE the way it rides and drives now! Totally different truck now compared to the stock platinum suspension. With that said, the Tech that put my suspension in, was very knowledgeable, mainly only does lifts of all kinds at my Toyota dealer.
  10. Jan 23, 2025 at 1:02 PM
    #160
    Libagui
    Libagui New Member
    Librado
    Weird, it doesn't show as close when I see it. My badyes is close.
  11. Jan 23, 2025 at 1:06 PM
    #161
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    says closed for me too
  12. Jan 23, 2025 at 1:07 PM
    #162
    Libagui
    Libagui New Member
    Librado
  13. Jan 23, 2025 at 1:10 PM
    #163
    lapoolboy
    Also, just because you see it listed for sale on these sites does not mean you can order it/will get it. You may be able to order and then they will cancel on you.
    Libagui and eddiefromcali like this.
  14. Jan 23, 2025 at 1:11 PM
    #164
    eddiefromcali
    Eddie
    100% Stock
    they might let you go through the purchase but they cancel it after
    M3Tundra-JK and Libagui[QUOTED] like this.
  15. Jan 23, 2025 at 1:19 PM
    #165
    LionsFan20
    Josh
    24 Tundra
  16. Jan 23, 2025 at 1:27 PM
    #166
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I've experienced this quite a bit when trying to order body panels and other items through some dealers. And it will just be cancelled, no explanation why unless you call and ask.
    eddiefromcali[QUOTED] likes this.
  17. Jan 23, 2025 at 2:46 PM
    #167
    MSPlatty
    MSPlatty New Member
    Harris
    2024 Metallic Gray Platinum iForceMax
    How is the ride compared to the platinum suspension? That's my only hold up on this, I really like the ride of the platinum.
  18. Jan 23, 2025 at 3:36 PM
    #168
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
  19. Jan 23, 2025 at 3:44 PM
    #169
    KuehnMK
    KuehnMK New Member
    From a stop or rolling, initial turns, steering feel feels smoother and easier! My guess from having 3" of more front suspension. My Platinum had the infamous pano sunroof rattle between the panels....It was the worst noise when driving 20-30MPH on like residential roads....pop pop pop, creak creak creak....AFTER the 3" TRD lift....NOISE IS GONE. That right their (hopefully correct use of their LMFAO) was worth it and shows how much more isolating the TRD lift is....Going over speed bumps feels about the same...Over all it just rides smoother if that makes sense! Plus having the higher ride height and the hood doesn't tilt down anymore, so the truck feels different overall.... LOVE IT!
  20. Jan 23, 2025 at 3:52 PM
    #170
    MSPlatty
    MSPlatty New Member
    Harris
    Absolutely beautiful truck, man. I have the same color and trim. How has the gas mileage been since the lift? Also what tires are you running?
    KuehnMK[QUOTED] likes this.
  21. Jan 23, 2025 at 4:27 PM
    #171
    BPTundraSr5
    BPTundraSr5 New Member
    And what was install price at dealer?
  22. Jan 24, 2025 at 5:24 AM
    #172
    jtweezy
    jtweezy New Member
    Jeffrey
    Yes, there's the paper definition vs how it drives, but at least the additional parts are there to make it possible to get all the measurements in spec. Experienced techs will know the nuances on how each adjustment changes ride and drivability.
  23. Jan 24, 2025 at 10:28 AM
    #173
    KuehnMK
    KuehnMK New Member
    Thanks! Tires are 275/65R20 Nitto Ridge Grapplers, LOVE THEM! Went with those instead of 35's. They are 34.1" X 10.8" and are 4ply. 35's are usually 8ply, so much heaver and stiffer. My MPG dropped from 19 MPG on long trips to 17ish with just the tires. Had those for 6 months before getting the TRD lift put on, and to be honest, my MPG has only dropped maybe 1 more MPG....BUT they kept my front drop down spoiler when they installed the lift, so maybe that's helping?? IDK.... If i drive my Tundra aggressively, hitting turbo every take off, going 10MPH over the speed limit on the freeway, it will easily drop down to 14MPG. If I drive more gingerly and just a little over the speed limit, ill get 16/17MPG....depends on my mood! HAHA!!
    MSPlatty[QUOTED] likes this.
  24. Jan 24, 2025 at 10:57 AM
    #174
    KuehnMK
    KuehnMK New Member
    I paid $2500 for the TRD lift kit and $1400 for the install/alignment. Dealer had mine in stock, it was on hold for MONTHS for a different customer who then backed out.....I just called my local dealer's parts department for you (1/24/2025 @ 1030)....They said there is still issue with the Toyota shock compressor that Toyota sent out, and the kit is still on a stop sale because of this. They were able to put mine in because A) They had it in stock, and B) They have their (hope this is the correct use of THIER @sudobash) own spring compressor tool since they do ALOT of lifts. Hope this info helps!
  25. Jan 24, 2025 at 1:18 PM
    #175
    jduffy192
    jduffy192 [OP] New Member
    2024 Platinum TRD OR standard bed
    Just got off the phone with brand engagement who said she was just told they’re not going to be offering it anymore. Bummer if true
  26. Jan 24, 2025 at 6:42 PM
    #176
    BPTundraSr5
    That was not a bad price at all! Thanks for info and checking w your dealer. My quote (if to happen) is $5163 after tax! $2700 for kit & $2200 install. My dealer tech guy made a bunch of calls today as well and it doesn’t look good he said. So based on price point and no resolution in sight , I’m exploring other options.
  27. Jan 24, 2025 at 11:16 PM
    #177
    TommyTwoFingers
    TommyTwoFingers New Member
    2025 ice cap Tundra
    I called customer engagement too and they said the same. I was previously told that I had a kit in order and install date scheduled, to no avail.
    im going to stop waiting for this kit to rear its head am make other arrangements. Toyota is playing coy and has been pretty misleading about availability, imo.
    jduffy192[OP] and sudobash like this.
  28. Jan 25, 2025 at 7:18 AM
    #178
    sudobash
    sudobash New Member
    That has pretty much always been Toyota's MO.
  29. Jan 25, 2025 at 7:19 AM
    #179
    TommyTwoFingers
    2025 ice cap Tundra
    I’m starting to see that. Still like my truck though.
    sudobash[QUOTED] likes this.
  30. Jan 25, 2025 at 7:59 AM
    #180
    sudobash
    sudobash New Member
    You just get to use to it and know that they aren't always going to be forthright with a lot of things. They do end up making the vast majority of things right for the customer.
