Strange noise at low speeds, unable to pinpoint source
Discussion in '2.5 Gen Tundras (2014-2021)' started by WhiteSR5, Jan 22, 2025.
  1. Jan 22, 2025 at 4:53 PM
    WhiteSR5
    WhiteSR5 [OP] New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    I noticed an odd noise on my Tundra (March 2021 production) in early December… sounds kind of like something rolling inside a tire at slow speed… like under 10mph. Nothing alarming, just… weird.
    Today I got a better look, eliminated the possibility of a socket or TPMS sensor rolling around inside the tires, checked the driveline, suspension, could not pinpoint this noise!
    Best guess is either a motor mount or sway bar bushing creaking under torsional loads, but I can’t verify 100%.
    Also found minor valve cover/cam tower leaks on both sides. Currently at 66k miles. Did not see those at pre-purchase inspection 5k miles ago lol.
    Wife’s 4Runner (August 2020 production) also makes a lot of odd noises… mostly dashboard rattles.
  2. Jan 22, 2025 at 4:57 PM
    WhiteSR5
    SC
    Are these blue markups on the tie rod ends from the factory?IMG_1817.jpg IMG_1816.jpg
  3. Jan 22, 2025 at 7:00 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    ABS test sequence?
  4. Jan 22, 2025 at 7:26 PM
    WhiteSR5
    SC
    Not the ABS test.
  5. Jan 22, 2025 at 7:53 PM
    yakeng
    yakeng 3URFE Apologist
    Yes, blue marks are from the factory.
    WhiteSR5[OP] likes this.
  6. Jan 23, 2025 at 7:46 AM
    Fergie
    Fergie New Member
    I had a bizarre noise from my front left, only in 2WD. Turned out to be the bearing, so I replaced it w the ECGS bushing and no more noise.
  7. Jan 23, 2025 at 8:12 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    Look for a rock caught behind a brake rotor back plate and the dust cover.
  8. Jan 23, 2025 at 9:35 AM
    WhiteSR5
    SC
    Did that yesterday :thumbsup:
    I had an incident with an intermittent brake noise on the 4Runner… piece of debris caught between rotor and backing plate
  9. Jan 23, 2025 at 9:43 AM
    WhiteSR5
    SC
    Noise description: front of vehicle, dull/muffled, low amplitude, low/irregular frequency
    -most noticeable under 10mph while moving e.g. rolling to/from stop.
    -can be heard stopped, brakes applied, manipulating throttle (loading/unloading) driveline
    -2WD/4H has no affect
    -not present while rolling/braking in neutral (i.e. tied to driveline/suspension loading)
    -position/pressure of tires has no affect
  10. Jan 23, 2025 at 10:03 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Is it more noticeable in cooler temps? I’ve got a similar noise I’ve not been able to pinpoint myself. It’s worse when it’s cold out, in the summer time I really don’t hear it. I notice it when coming to a stop and taking off and the weight shifts front or back and well as the slow maneuvering out of my driveway and parking lot scenarios. Sounds kind of similar to your noise.
  11. Jan 23, 2025 at 10:45 AM
    WhiteSR5
    SC
    I bought the truck in October, but didn’t notice the noise until December, so it could possibly be ambient temperature dependent.
    That would point toward suspension, as the driveline heats up more during use.
    can’t really test that hypothesis for a few more months.
