Bilstein 6112s for 1st Gen
Discussion in 'Suspension' started by kharri, Jan 22, 2025.
  1. Jan 22, 2025 at 8:45 PM
    kharri
    kharri [OP] New Member
    '06 Tundra AC TRD 4x4 v8
    Hello, new to the forum and relatively new owner of a 2006 AC TRD 4wd. It is bone stock with ~175K miles on it.
    Questions
    - Is the bilstein 6112 lift chart accurate?
    - Should I upgrade to aftermarket UCA for 1 inch of lift?
    - Did I miss a thread that this has been already discussed for first gens? I have seen Shiftys posted chart that he updated for AC.
    More context below....
    I want to upgrade my suspension to Bilstein 6112. I have scoured high and low on forums, FB, and beyond to try and find any information on if the lift chart that Bilstein provides for 6112s is accurate or if I should expect to get more lift then advertised?
    I was going to go with the #3/#1 Stock, #4/#2 .7 lift, or #5/#3 1 inch lift setting. However, the chart does not make sense to me as that #6/#4 setting would lift a DC 1.3 inches and the AC should weigh less. I understand there is more weight distributed to the front with the AC but every other larger vehicle seems to have more lift.
    In addition, I am trying to keep this mainly stock and did not want to upgrade UCA but could be convinced with a good argument. I would have just gone with OEM spring and 4600s but seems springs are no longer made for TRD so figured I would just spend the money for a nicer ride.
    I planned to swap the backs with 5100s and put in a RAS. I have a Jason hi-rise topper that is always on as well.
  2. Jan 23, 2025 at 5:51 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I swapped in 6112’s and installed both springs on the bottom clip. Stock height, and i love the ride.
    (I did have to rearrange some stuff in the truck to level out the driverside lean.) the truck can float over speedbumps & is planted on rough roads.
  3. Jan 23, 2025 at 7:11 AM
    kharri
    Did you use the stock springs or buy preassembled with a 650LB or 700LB spring?
    Also curious what you mean by move things around?
  4. Jan 23, 2025 at 7:17 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    No, stock springs dont fit the 6112’s, but i bought a kit with 650lb springs unassembled.
    like my tool box, dog platform, fridge, and aux battery are all on the passenger side. I’ve also got a high rise cap on full time.
    i got a new phone, so i dont have the pics i used to. I also added jba UCA’s & removed my sway bar. 6112’s dont have any extra travel (5100 rears have an extra 1/2” or so.) also did my lbj’s & cv axles since i was in there. About 150k miles.
