  1. Jan 22, 2025 at 5:56 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not enough to even just pigtail the wires? That would be a lot easier than adding a new box.
    Wago are great, I like the lever ones myself.
  2. Jan 22, 2025 at 5:58 AM
    @JMB Wagos are garbage. If you look at them, they have such a small area of contact that a decent amount of amperage will burn them up. I'd get a handful of red/tans from the big box store and add a bit of wire onto what you've got. You can for sure cut in a box to add some length, but I'd just wirenut some wire on first. If you leave joints in a wall I'll find you and punch you directly in the dick.
  3. Jan 22, 2025 at 5:59 AM
  4. Jan 22, 2025 at 6:36 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'm only sparky adjacent, I just rewire in cabinets and low voltage.
    Just for funsies I'll throw in I prefer Propress to soldering for plumbing as well.
  5. Jan 22, 2025 at 7:07 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I would stay away from Wago also. The wire nuts are specified with a number of wires/minimum gauge wire to number of wires/maximum gauge size. It’s on the outside of the package. I also make sure you get enough twist on the nut and wire. I now also wrap the wire nut and wire withe electrical tape.
  6. Jan 22, 2025 at 12:37 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I was able to add some wire to get the circuit up, but the box seems cluttered to me. I'm afraid I'd loosen the wire nuts when I secure the outlet to the box. For now I leave the breaker off except when I need the circuit.
    I really don't know how I managed to connect the GFCI outlet 15 years ago it's so tight.
    Good to know. It's a 20 amp circuit with only a dustbuster charger on it. I use it for high current draw items like my air compressor. I have a second circuit for lights, beer fridge and smaller draw tools.
    I believe that's the route I will go. When it warms up.
  7. Jan 22, 2025 at 1:56 PM
    JMB
    Chesapeake, VA
    No worries on getting dick punched. The question was specific to Wago, I'm totally not familiar with them. If I go the j-box route it will be flush and have a cover.
  8. Jan 22, 2025 at 7:36 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Texture, primer and paint done. Flooring next.
  9. Jan 22, 2025 at 8:01 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Interlock kits are cheapest at around 100$, but your box needs to be a common version that an interlock kit is available for. Then you also need a free double breaker slot for the generator (new breaker is cheap but yours maybe full). The outlet box and wire should be sub 200$. The cord is 100-200$ depending on length. A good generator option is a used Honda EU7000is or EU6500is or EM6500is if you can find one for sub 2k$, those will use about 8 gallons for 24 hours and power most things in your house.
    I have to run dual generators to run my house and separate well shed and often lose power for 3-5 days at a time, makes for fun times haha. Blue dots mean I keep those on when using the generator:
  10. Jan 23, 2025 at 2:25 PM
    Daughter has been complaining her room is too cold. I installed a WiFi (also has remote and screen to adjust) heater so she can set the temp as she feels fit.
  11. Jan 23, 2025 at 2:47 PM
    NWPirate
    Zach
    WA
    No shit? Never heard of those.
    How many watts?
  12. Jan 23, 2025 at 2:48 PM
  13. Jan 23, 2025 at 2:53 PM
    NWPirate
    Zach
    WA
  14. Jan 23, 2025 at 2:54 PM
    Took a whopping 10 mins to install too.
  15. Jan 23, 2025 at 10:18 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    We installed one of these in our daughter's room this winter as well. Different brand but i really like it. I can set a schedule for it for it and adjust the temps from anywhere I am on my phone once's it's connected to the wifi. It's a pretty handy little space heater. https://www.dreo.com/products/wh719...ULAy_E35AHI0_2_U8LWHSIek2XttD2X4aAqhPEALw_wcB
  16. Jan 24, 2025 at 5:53 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I am looking on this site, and they do not list size recommendation on their wall heaters. How the heck are you supposed to know if it will be useful! I've got a message into support, but that's a big question mark. Not even in the faq that I can see. Do you know?
    edit: at 1500w it should work for my space, same size as the one I have down there, but this one spreads the air much better, and mounted on the wall saves space on the floor.
  17. Jan 24, 2025 at 5:56 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    all this heater stuff reminds me of this movie
  18. Jan 24, 2025 at 7:17 AM
    :laugh:
    TaquitoBandito and OldGuy03 like this.
  19. Jan 24, 2025 at 8:06 AM
    We gave our oldest a heated blanket. Problem solved. :rofl:
  20. Jan 24, 2025 at 8:07 AM
    To hell with how many watts, I want to know how many amps!?
  21. Jan 24, 2025 at 8:12 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    My 2 year old sleeps in our basement (finished!) and it's only got 1-2 heat output vents from the forced air, keeps it around 64. Wife would like her around 67-68, we have one of those fake fire electric heaters now, and it's okay, but not centrally located and a wall hang can be put anywhere!.
    TaquitoBandito likes this.
  22. Jan 24, 2025 at 8:35 AM
    Our basement is similar. Stays around 65-66 year round. We recently overhauled our A/C systems and turned the downstairs unit into a dual-zone so we can finally heat the ground floor & basement independently, each having its own t-stat.
    What I will say is two things:
    One, we didn’t realize it, but we had something very normal for basements, a humidity issue, and thus mold growth. It was very subtle but was causing breathing problems for our kids when they spent any period of time down there. When I realized this, I put one of those Scientific Oregon temp/humidity weather stations down there and the humidity averaged around 60-65%, which is ripe for mold growth. You ideally want humidity to be around 55% or less. The kids’ asthma/breathing issues stopped after getting that in check. I setup the humidifier to drain via a clean out access port on a shared wall with the basement bathroom so I wasn’t constantly dumping the damn bucket, can share pics if it helps!
    Two, after installing that dehumidifier, which runs far less after sealing our walls, installing drywall and flooring, I finally broke down, for the sake of the family, and spent the coin on an AirThings 2960 View Plus, which monitors for radon, humidity, temp, VOCs, CO2, air quality, etc. It hooks into WiFi and reports wirelessly back to a portal so you can track over time and get alerts etc. I was surprised to see we have some pretty hardcore radon spikes - radon is one of the top causes of lung cancer. I took measures to remediate that while I was at it, but now I gotta wonder how frequent it was spiking that high while I was down there for hundreds of hours in my shop over the years.
  23. Jan 24, 2025 at 9:35 AM
    4.17-8.34
  24. Jan 24, 2025 at 9:47 AM
    all of them
  25. Jan 24, 2025 at 9:48 AM
    She has that, as does my wife with a WiFi control for her blanket and even a heated hoodie lol
  26. Jan 24, 2025 at 9:52 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I keep a dehumidifier on the side that isn't finished, but this has me wondering if I shouldn't add one to their bathroom down there, I most likely should. My house was built in 2018/2019 so the outside is covered in water sealant and has insulation on the outside/under slab and inside. While that doesn't mitigate everything, I empty my dehumidifier much less than in a building we have without all that. I think I might get a little one for their bathroom after reading this, and I am going to look into the air things.
    I appreciate your input on this, my family is important to me!
    edit: getting an air things!
  27. Jan 24, 2025 at 11:02 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    This is exactly why I have the app on my phone. Even after talking to her about max temp settings. So I f with the temps to let her know I'm always watching when it comes to the thermostat.
    TaquitoBandito and Mater like this.
  28. Jan 24, 2025 at 11:07 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    claims it best for 215 sqft spaces or up to 750sqft as a supplemental heating source.
    her room is about 250sqft, and it's the only heating source. Over the last week with the negative temps it was still comfortable.
    On the cycle I kept it at. Does require cleaning the filter every 2 weeks but I'm okay with that. On sale on Amazon right now. https://www.amazon.com/Dreo-Oscilla...ocphy=9028879&hvtargid=pla-2281435180698&th=1
    TaquitoBandito and FrenchToasty like this.
  29. Jan 24, 2025 at 11:34 AM
    We're a 2003/2004 build. It's code here to tar/seal the earth-bound walls of the basement, and they did sheet under the foundation to prevent water from coming up, which is why I thought nothing of it. Like all things, we did have two hairline cracks in our poured walls that would allow outside water to get in, which is what we initially thought was our problem, but even after having a structural engineering company come in and properly drill the crack, then fill the walls with epoxy sealers, the humidity was still above 60%. It must've been like 70% or something prior, or higher during longer rainstorms.
    Hindsight 20/20, I kinda wish we'd hit all the walls and floors with RedGard or similar before finishing ours out, just to seal the interior space. It's fine without, now we have the humidifier in a good spot, and it helps having the bathroom built out down there, now we can run the bathroom fan to exhaust the air out if we hear the humidifier running more than once in a day (it typically goes days without running from October thru April). Anyway, not sure this helps much, but tossing it out there!
    TaquitoBandito and woods[QUOTED] like this.
  30. Jan 24, 2025 at 12:44 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Not mine, but took out my mom's old stove in prep for her getting a new one today. Moved the old one to our house to sell along with the microwave from her place. If I needed a garage oven, it'd be staying. LOL.
