Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Jan 21, 2025 at 10:44 AM
    #3361
    2wheelsforfun
    2wheelsforfun New Member
    Kinda chuckle at you guys complaining about turning radius, try 163" wheelbase, which should be close to a crewmax 6.5? This is about as offroad as I will ever get so turning radius doesn't factor into buying decisions, and as for parking these large radius trucks, you just back into spots and it's nearly as quick and easy as driving your short wheelbase straight in.
    and no my motor isn't recalled (thread content) but I am still interested in this interesting news.
  2. Jan 21, 2025 at 10:50 AM
    #3362
    AZBoatHauler
    So.Arizona
    3rd gen 4x4 Tundra is closer to your turn radius (53’) than it is to the prior gen Tundra…
  3. Jan 21, 2025 at 10:56 AM
    #3363
    Breathing Borla
    Northern Illinois
    damn you .4
    AZBoatHauler[QUOTED] likes this.
  4. Jan 21, 2025 at 11:01 AM
    #3364
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I think his point was, a lift raises the frame and body relative to the axles. The axles are typically the lowest point of ground clearance, especially the rear axle at the differential. If you just do a lift, without larger tires, those lowest points of clearance don't really change.
  5. Jan 21, 2025 at 11:07 AM
    #3365
    AZBoatHauler
    So.Arizona
    ^ can confirm.
  6. Jan 21, 2025 at 11:12 AM
    #3366
    Breathing Borla
    Northern Illinois
    We get that, but…
    he said any ground clearance or off-road abilities , the trd lift certainly improves some things and lowest point of ground clearance doesn’t mean your not gaining clearance elsewhere
    but alas , now we can talk about lifts for 6 pages and .4 turning radius numbers
    interesting news eh? :D
    CringyDad and AZBoatHauler like this.
  7. Jan 21, 2025 at 11:19 AM
    #3367
    Matt2015Tundra
    2023 1794 CrewMax
    To me, any discussion of ground clearance and true 4-wheeling in a pickup is kinda funny. Where I wheel my Jeep, you'll never see a pickup of any kind.
    I believe in most cases, the desire to lift and put large tires on a pickup has more to do with appearance than off-roading functionality. Not all cases, of course.
    mayan, Warreng, cartage1 and 5 others like this.
  8. Jan 21, 2025 at 11:27 AM
    #3368
    A jeep is just a short (ish) wheelbase frame with 2 solid axles under it. Doesn't matter what kind of body it has on it.
  9. Jan 21, 2025 at 11:35 AM
    #3369
    Matt2015Tundra
    2023 1794 CrewMax
    Yes, that was my point. The long wheelbase and large turning radius of a full-sized pickup makes them less than ideal for most hardcore wheeling.
    Heck, I have a 2-track on my property that no full-sized pickup could navigate, but it's fun with my old CJ7.
    mayan and KNABORES[QUOTED] like this.
  10. Jan 21, 2025 at 11:37 AM
    #3370
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    Its simple. 3" of suspension lift doesn't move where the diffs are if tire diameter remains the same. So the lowest point (differentials) remains where they are, and therefore the ground clearance remains unchanged.
    All a lift does is push the body/frame up from the lower control arms (in the front) and the rear axle assembly (in the rear).
    Yes you can generally fit larger diameter tires with a lift, but once you do it's the larger tires that increase ground clearance, not the suspension lift.
    CringyDad and Matt2015Tundra like this.
  11. Jan 21, 2025 at 11:46 AM
    #3371
    AZBoatHauler
    So.Arizona
    I appreciate you qualifying it - conversely I take my truck where majority of jeeps owners wouldn’t touch. I think the saying goes a Jeep will get you there, a Toyota will get you home.
    Hells Revenge anyone?
    Mineral Creek -> Animas Forks -> California Pass -> Corkscrew
    Imogene Pass
  12. Jan 21, 2025 at 11:48 AM
    #3372
    Breathing Borla
    Northern Illinois
    sweet pics hauler
    Raven67 and AZBoatHauler[QUOTED] like this.
  13. Jan 21, 2025 at 11:56 AM
    #3373
    Hella Krusty
    Hella Krusty New Member
  14. Jan 21, 2025 at 12:18 PM
    #3374
    Matt2015Tundra
    2023 1794 CrewMax
    I think that saying was coined sometime after Chrysler started building junk and sticking the "Jeep" name on it.
    I'd love to take you on a few trails that I take my real Jeep on. :thumbsup:
    Beautiful pics, BTW.
  15. Jan 21, 2025 at 12:22 PM
    #3375
    AZBoatHauler
    So.Arizona
    I’d love to do that and thank you.
    :hattip:
    We have a triple locked side by side and I’m at the point I feel my truck is 95% as capable while being 1000x more comfortable and 10x less sketchy. It’s not all cons with the long/wide wheel base.
    Terndrerrr and Breathing Borla like this.
  16. Jan 21, 2025 at 12:36 PM
    #3376
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    :rofl::rofl::rofl::rofl:
    Tunnel vision hurts. You are clearly looking at half the picture. One of two angles. As a suspension lift doesn’t increase the height of the differentials (hence side to side height clearances), it DOES increase the height of the frame in a front to rear aspect. AND is most definitely needed to attain that differential clearance increase with the big tires you obviously NEED to install to gat that super differential to ground clearance.
    Remember to keep adequate tire pressure, or your differential ground clearance will turn to shit !
    Breathing Borla likes this.
  17. Jan 21, 2025 at 12:43 PM
    #3377
    Breathing Borla
    Northern Illinois
    I was thinking of you out there today man, it was negative fuckin fifteen (-15) this morning, ugh, so done with this shit.
    wife and I talk daily about this, lol. Can't wait, I have oro locked into my weather app
    Azblue and AZBoatHauler[QUOTED] like this.
  18. Jan 21, 2025 at 12:48 PM
    #3378
    AZBoatHauler
    So.Arizona
    It was close to freezing here this morning - it’s no -15 but I’ll be happy when lows are back in the 50s this weekend.
  19. Jan 21, 2025 at 12:51 PM
    #3379
    Red&03Taco
    Red&03Taco YUT
    Jerad
    You were wrong when you questioned my statement about "suspension lifts not increasing ground clearance". I replied with completely accurate and factual information and now you get snarky and try to move the goal posts. I'll refrain from correcting you further as to not waste mine or your time.
  20. Jan 21, 2025 at 12:56 PM
    #3380
    Matt2015Tundra
    2023 1794 CrewMax
    I agree, a long and wide wheelbase can help in certain wheeling situations.
    Not so much if you are navigating 2' tall boulders, super tight trees, or steep approach and departure angles with no space in-between.
  21. Jan 21, 2025 at 1:04 PM
    #3381
    Breathing Borla
    Northern Illinois
    just a question, and a clarification for discussion, not shit talking
    don't you think that all the other points of the truck being raised for more ground clearance is worth something other than just 100% focusing on the lowest measurable point? after all, the pumpkin can bounce off and scrape a hell of a lot more than the rest of the truck can without damage.
    I think that is the disconnect here.
    and you said, "3" lift doesn't do anything for ground clearance or off-road ability"
    I was talking more about the other points of the truck being higher, and the other gains of off-road ability by adding the OEM factory TRD Lift which comes with all kinds of shit, not just 3", the shocks, etc are significantly better for some off-road situations, etc.
    anyways, thats where my mind was when I originally brought this up.
    AZBoatHauler likes this.
  22. Jan 21, 2025 at 1:35 PM
    #3382
    Red&03Taco
    Red&03Taco YUT
    Jerad
    My honest opinion is that a suspension lift alone typically provides almost zero off road benefits by itself. I say that assuming tire size isn't increased. If tire size is increased then everything changes.
    Just lifting bumpers (and other body/frame components) higher off the ground won't change much in my experience. It's far more typical that I bash unsprung components like diffs, control arms, and my rear axle tube (if you bash them bad enough you'll get stuck, or break stuff --> typically not the case when bashing a bumper). And again bigger tires is the only thing that lifts those components higher off the ground.
    The fancy electronics (ATRAC, crawl control, etc) and locking diff absolutely help off-roading ability. Suspension lifts simply do not.
    For the record I'm not trying to argue any Tundra gen is best offroad. Mine is a pavement princess, because I have a 1st Gen Tacoma that absolutely romps
  23. Jan 21, 2025 at 1:36 PM
    #3383
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  24. Jan 21, 2025 at 1:45 PM
    #3384
    Breathing Borla
    Northern Illinois
    if thats your opinion, fine, I'll respect that. I just disagree a bit, which doesn't mean shit either, lol.
    what about the fox shocks with reservoirs, etc, any help at all in your mind? again, the TRD lift come with more than just like a 3" spacer jammed in there
    nice taco, looks lifted, HA :D
    take care!
  25. Jan 21, 2025 at 1:59 PM
    #3385
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I love it when doods on this forum flex 10-15 year old trucks all day long. Rock on peps.
    and goodluck to Borla moving to Arizona- if the scorpions or rattlesnakes don't get you the 130 degrees might.
    just make sure you get one of those lights so you can glow light the little buggers before you go to sleep.
  26. Jan 21, 2025 at 2:01 PM
    #3386
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Maneuvering almost like a midsize is a huge deal on trails and fire service roads. It’s fun to surprise people in 4Runners and GXs with where I can fit. Yes I have had to buff out a few pinstripes, but also a little 18V chainsaw is my friend. :thumbsup:
    Just being honest—163” wheelbase in a half ton is wild to me. If I’m driving something that big, it better come with 4,000 lb of payload. Lol
  27. Jan 21, 2025 at 2:06 PM
    #3387
    Terndrerrr
    Music City
    6UR-FE
    If you just think of a thread like this as a bunch of dudes sitting in a waiting room shooting the breeze, it makes more sense.
    The doc will be out at some point with material information, lol
  28. Jan 21, 2025 at 2:15 PM
    #3388
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    What app do you use to find these places? Nice pics!
  29. Jan 21, 2025 at 2:15 PM
    #3389
    Breathing Borla
    Northern Illinois
    gee thanks.
  30. Jan 21, 2025 at 2:21 PM
    #3390
    Terndrerrr
    Music City
    6UR-FE
    Land Between The Lakes. Recommend not slowing down in this situation :laugh:
    We went up Imogene the “wrong” way (Ouray to Telluride). This is just after the rain and hail stopped. Thankfully, no dents.
    No locker, just ATRAC and the extra clearance from 35.1” tires and the extended travel of the TRD Fox kit. We were never less than absolutely sure-footed. Need to go back soon.
