Brake pad info
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Jan 21, 2025.
  1. Jan 21, 2025 at 12:54 PM
    eagleguy
    eagleguy [OP] New Member
    It appears at 32K I need to replace the brake pads for my 21 Tundra SR5 2WD Crew Cab. I tow things on occasion like small boats, campers and utility trailers but otherwise nothing crazy. What is everyone liking for brake pads lately?
  2. Jan 21, 2025 at 1:33 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    OEM is the way to go. Here's all the part numbers
    Front Rotors 43512-0C020
    Front Pads 04465-02440
    Front Shim Kit 04945-0C040
    Front Pad Fit kit 04947-0C030
    Front Pad Pin 90240-06024
    Front Pad Pin Clip 90016-AS903
    Rear Rotors 42431-0C011
    Rear Pads 04466-02340
    Rear Shim Kit 04946-02110
    Rear Fit Kit 04948-02140
  3. Jan 21, 2025 at 2:12 PM
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    While we on the subject, what tool is needed for retracting the rear caliper pistons, is it a standard cross pattern?
  4. Jan 21, 2025 at 2:18 PM
    Joe333x
    Joe333x Member
    Boston
    I just use a big c-clamp and and old brake pad the rear is easy but the front can be a little challenging but I got it done.
    Bayou Spartan likes this.
  5. Jan 21, 2025 at 3:29 PM
    Tundra family
    Tundra family New Member
  6. Jan 21, 2025 at 4:09 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Do you have to remove your rims to see your current tread depth?
  7. Jan 22, 2025 at 10:23 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Thanks for this. I'm approaching 80k miles and am noticing a little bit of warped rotors. So thinking i will replace all the brakes at 100k.
    Question are all these parts the same for the 2018/2021 2wd or 4x4 ect. Ect. Like all the trucks made in 2021 use all the same parts?
    AZBoatHauler likes this.
  8. Jan 22, 2025 at 10:46 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    TundraLuvr2017 and AZBoatHauler like this.
  9. Jan 22, 2025 at 12:09 PM
    AZBoatHauler
    So.Arizona
    To see clearly - yes.
  10. Jan 22, 2025 at 1:43 PM
    Joe333x
    Joe333x Member
    Boston
    2014-2021 are the same trucks with some minor differences through the years but all maintenance parts are the same.
  11. Jan 22, 2025 at 1:58 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    There was a change in front & rear brake pad part numbers for the 2018 model year. The rear shim kit and rear fit kit were updated as well.
  12. Jan 22, 2025 at 2:39 PM
    Joe333x
    Joe333x Member
    Boston
    Interesting, didn't know that, wondering what the difference is and if they are interchangeable
  13. Jan 22, 2025 at 2:49 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Pad dimensions are the same, so I would assume they are interchangeable. My guess has been the 2018+ version has less copper and other metallic content to satisfy government requirements.
  14. Jan 22, 2025 at 6:08 PM
    DCLarston13
    Tundra family[QUOTED] likes this.
  15. Jan 22, 2025 at 6:11 PM
    DCLarston13
    Only if you are also checking the bumper hydraulic fluid. If not the shop will have to break down the tires so tread depth it can be measured without load on the tire. If the tire is loaded up the bottom will be flatter than the top of the tire thereby distorting your readings.
  16. Jan 22, 2025 at 7:56 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    I'm talking about removing the rims to check brake pad life. Not sure why I said tread depth haha.
    ATV25 and AZBoatHauler like this.
  17. Jan 22, 2025 at 8:04 PM
    yakeng
    yakeng 3URFE Apologist
  18. Jan 22, 2025 at 8:39 PM
    Tundra family
    Both front and rear get shoved back in, no threading. Some folks just use an old pad and a screwdriver to get it done.
  19. Jan 23, 2025 at 7:06 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I just replaced my front pads at 49,000 miles. I went with the Hawk Super Duty pads. They have good bite, low brake dust, and no noise whatsoever. I tow often and these pads work great. The entire job was about 40 minutes. Pop the master cylinder and use the old pads to push the pistons in. Easy job even for someone with minimal mechanical experience like myself.
    ATV25 likes this.
  20. Jan 31, 2025 at 6:08 AM
    DCLarston13
    Joe333x and yakeng[QUOTED] like this.
  21. Jan 31, 2025 at 6:49 AM
    yakeng
    Lisle makes good stuff. I have their hand vacuum pump also that I use to bleed brakes, test for vacuum leaks and what not. It has a ton of uses.
    Tundra family likes this.
  22. Apr 10, 2025 at 6:58 PM
    Noob here
    Noob here New Member
    thanks for this list Joe. Looks like theres a copy and paste error.
    The Front Shim Kit is actually 04945-0C040
    (looks like you pasted the rears for the rear and front) no biggie, figured anyone else finding this page could find this helpful.
    thx!
    Joe333x[QUOTED] likes this.
  23. Apr 10, 2025 at 8:01 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Appreciate the list. I used a similar list last year to purchase all the parts I'll need for my first brake job. Can you add the quantity needed for each part#? Like I know the front shim kit is quantity 1 that covers both front left and right, the pins would be quantity 4, etc.
    I'm guessing the rear shim kit would also be quantity 1. What quantity would I need for the "rear fit kit"? 1 or 2?
    This past weekend I changed out just the front brake pads and reused the pins but installed new shims(all OEM). Rear pads had a good 80% life on them still so I left those on. I got new front and rear pads on order right now with new shims(25% sale). Glad I saw your post though as I didn't think to order the rear shims and clips so I'll have to get those ordered now.
  24. Apr 10, 2025 at 9:36 PM
    Joe333x
    Joe333x Member
    Boston
    Thanks! I'll fix the post in case someone else uses it
  25. Apr 11, 2025 at 2:58 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    Thanks for this thread. I have to get hot in changing mines as well
    ordered the rotors but they have not arrived yet and called and called and ended up cancelling the order with jegs.
  26. Apr 11, 2025 at 4:11 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I use a telescoping inspection mirror for checking pads without removing wheels..Honestly never used the OEM pad shims when replacing, but always went with non OEM pads...I use a large pair of channel lock pliers and an old pad to push the pistons in or a large mechanics pry bar...
  27. Apr 11, 2025 at 5:02 AM
    Crack the bleeder screw when compressing the brake caliper pistons. The fluid in the calipers gets pretty nasty with water intrusion and sometimes even dirt and brake dust that gets past the seals. Opening the bleeder will send that nasty fluid out instead of forcing it back into your brake lines / ABS / Master cylinder. I usually do a brake bleed / fluid exchange when brakes are due, but that’s usually 60-80k miles and many years for me.
    Mdl likes this.
  28. Apr 11, 2025 at 6:19 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Rear rotors will not come off
    I thought after the caliper it should have slid off
  29. Apr 11, 2025 at 6:48 AM
    Joe333x
    Joe333x Member
    Boston
    Sometimes they are just stuck, I forget the size but I'm sure you can find it online, it's the same size as Subaru but there are holes two holes in the rotors opposite of each other, you can screw a bolt into each and turn each one alternating and it will pop right off. Also be sure you don't have the parking brake on. A rubber mallet can also work sometimes.
    ATV25 likes this.
  30. Apr 11, 2025 at 6:49 AM
    Tundra family
    Did you remove the retention screw? I can't remember if our trucks have 1 or 2 but I never put them back in after removal anyway. The holes with the arrows are what @Joe333x was talking about threading into to pry the rotor off
