Fumoto valve
Discussion in '3rd Gen Tundras (2022+)' started by kelbro, Aug 22, 2023.
  1. Nov 13, 2024 at 9:47 AM
    #61
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    Just take the entire valve out old school if the adapter gets lost or something.
  2. Nov 13, 2024 at 10:41 AM
    #62
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Yes that is an option. Just seeing if there was another way as well. Appreciate it.
  3. Nov 13, 2024 at 10:49 AM
    #63
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I don't think you can, there is a check ball that needs to be pressed in to drain. I guess you could use a small pick or screwdriver but it will make a mess. I have a spare drain if you need one?
  4. Nov 13, 2024 at 11:58 AM
    #64
    OLV1071571
    Thanks for the offer. I haven't bought one yet. Just considering both brands.
  5. Nov 13, 2024 at 12:15 PM
    #65
    JDAZ
    JDAZ New Member
    NJ
    Having had both, I like the Valvomax. Faster flow. More rugged and compact design. Cap acts as a backup if something were to go wrong with the check valve. The adapter with the built in hose directs the fluid where you want and can start and stop flow by turning the adapter on and off (good for sampling, no advantage over the fumoto)
  6. Nov 29, 2024 at 7:16 AM
    #66
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    For those using a valvomax, I replaced my fumoto with one today. Do you need to use a crush washer to install the vlavomax? I didn’t and have no leaks but just wondering what everyone else is doing……I can add one next oil change if needed.
    Wallygator likes this.
  7. Nov 29, 2024 at 6:16 PM
    #67
    JDAZ
    JDAZ New Member
    NJ
    mine came with a washer
  8. Nov 29, 2024 at 6:51 PM
    #68
    shawn474
    MoCo, Maryland
    mine had a washer already threaded onto the valve; I was wondering if it still needed a crush washer
  9. Nov 29, 2024 at 11:22 PM
    #69
    JDAZ
    JDAZ New Member
    NJ
    The washer is the “crush washer” it’s like the ones on the Allen head plugs on the front differential they just look like a washer
    Wallygator and shawn474[QUOTED] like this.
  10. Nov 30, 2024 at 3:03 AM
    #70
    shawn474
    MoCo, Maryland
    ok great ; thanks so much!
  11. Jan 20, 2025 at 6:58 AM
    #71
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Looking to add a Valvomax, are there any concerns with oil that cannot drain since the threads stick up inside the pan trapping oil?
  12. Jan 20, 2025 at 7:37 AM
    #72
    RobertD
    Robert
    DFW, Texas
    There was a thread recently on this with someone having added photos after dropping the pan, the threads barely extend into the pan and based on the design there is negligible impact.
  13. Jan 20, 2025 at 10:43 PM
    #73
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I broke mine at less than 10 ft lbs.
    I'll see if I can find the pictures.
  14. Jan 21, 2025 at 6:30 AM
    #74
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Maybe I'm just old school? I understand the possible convenience of installing one of these valves, but I only change oil every 5000 miles, I've NEVER had any issues with a plain old drain plug. Unscrew it, drain, then screw it back in. I've just never understood the need for one of these valves.
    Matt2015Tundra likes this.
  15. Jan 21, 2025 at 6:33 AM
    #75
    shawn474
    MoCo, Maryland
    You're right, BUT it makes it soooo much easier and less messy. Don't have to worry about cross threading, overtorquing, etc. Hook a hose up to the valve and drain the oil straight into the recycling container. No need for a drip pan and transfer to another container. I have put one on every car we have and can do an oil change in about 20 minutes on each. I did switch to the valvomax on the tundra.
  16. Jan 21, 2025 at 8:11 AM
    #76
    SilveradoSwap
    For the exact reasons mentioned, well said. Not to mention, no tools required. I can usually turn my filter off by hand.
    Pine_Cone67 likes this.
  17. Jan 21, 2025 at 9:37 AM
    #77
    Raven67
    Kentucky
    I do replace my plugs with magnetic plugs, which for obvious reasons unfortunately might be best for a Tundra. :(
  18. Jan 21, 2025 at 11:24 AM
    #78
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I have a spare hose from a fumoto hose kit I bought. Dont remember if its the straight or 90* elbow that I didnt use but I have it if someone wants to pay for shipping for it...free
  19. Mar 3, 2025 at 9:43 AM
    #79
    eddiefromcali
    Eddie
    100% Stock
    Has anyone replaced the washer the valve comes with? I took the valve off the old engine and now wondering if I should use a Fumoto washer or if the oem one will do.
  20. Mar 3, 2025 at 9:46 AM
    #80
    shawn474
    MoCo, Maryland
    The washer that comes with the fumoto is fine; that's what I used for years and never had an issue
  21. Mar 3, 2025 at 9:55 AM
    #81
    eddiefromcali
    Eddie
    100% Stock
    Yeah, thats what I had used...but I took it off the old engine before I got a new one due to the recall. Now Im wondering if I should order a fumoto washer or just slap an oem one on there.
  22. Mar 3, 2025 at 10:02 AM
    #82
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I am deciding how to play this myself. I am due for an oil change now and that might get me to July when my engine is scheduled to be replaced. So, do I pull the Fumoto this time? Or leave it on and maybe the dealer would swap it over when they change the engine? If I pull it now and the replacement gets delayed then I might have to do another old school messy oil change.
  23. Mar 3, 2025 at 10:02 AM
    #83
    shawn474
    MoCo, Maryland
    Any crush washer will work.....I bought a ten pack for like a $1 on Amazon
    eddiefromcali likes this.
  24. Mar 3, 2025 at 10:04 AM
    #84
    eddiefromcali
    Eddie
    100% Stock
    I pulled mine and just let the oil simmer in there till the recall. Toyota will destroy the old engine anyways. I didnt want to cause the tech any more trouble with the valve swap since the engines come pre-filled with oil.
    Tundrastruck91 likes this.
  25. Mar 3, 2025 at 10:06 AM
    #85
    raylo
    Frederick, MD
    That sounds like a good plan for me, too.
  26. Mar 4, 2025 at 5:45 PM
    #86
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Wow, i found the same valves on Aliexperess for fraction of the price, but this forum does not allow me to post links to them. Funny
  27. Mar 4, 2025 at 5:47 PM
    #87
    JohnF4x4
    JohnF4x4 New Member
    US
  28. Mar 4, 2025 at 5:53 PM
    #88
    lapoolboy
    lapoolboy New Member
    Don't think I'd trust a valve from AliExpress.
    kirkb likes this.
  29. Mar 4, 2025 at 6:01 PM
    #89
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    100%
  30. Mar 4, 2025 at 6:11 PM
    #90
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I don’t have the Fumoto (plan to add), but my last oil change went from a 5k to a 10k interval before the swap :thumbsup:
    Spark Plugs never got done either
