Drill and tail light not working
Discussion in '2nd Gen Tundras (2007-2013)' started by Ian m., Jan 19, 2025.
  1. Jan 19, 2025 at 4:36 PM
    Ian m.
    Ian m. [OP] New Member
    Ian
    So I put new aftermarket headlights in my 2010 tundra 4.6 and resistors because they are LEDS And now my headlights work fine but my DRL’s and tail lights do not turn on my brake lights work when the brake is pressed the turn signals work and do not hyper flash the LED DRL’s in the front Flash if I press the lock button or unlock button on my key fob But not the DRL turn signals and the tail lights flash, but they are dim. I’ve checked fuses. I replaced the flasher relay and triple checked my wiring to the headlights, but still do not have any idea what the problem is if anybody could help, please reach out.
  2. Jan 19, 2025 at 4:44 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    Your post is a little hard to read, a period goes a long way.
    Which AM headlights did you use?
    Do you have a manual for them?
    Which part of your tail lights do not work?
  3. Jan 19, 2025 at 4:47 PM
    Ian m.
    Ian
    @1lowlife
    It did not come with a manual and they are
    07-13 Toyota Tundra LED DRL+Turn Signal Projector Headlights - Smoked / Clear
    SKU: HL-LB-TT07-BK-SM-CL1 from pro tuning labs
    1lowlife likes this.
  4. Jan 20, 2025 at 6:26 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    How about a link from where you bought them
  5. Jan 20, 2025 at 6:30 PM
    Ian m.
    Ian
  6. Jan 20, 2025 at 8:35 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Man, those are ridiculously inexpensive. Nonetheless, there is a ‘Help’ window.
    Get on the phone and ask them what’s going on. Morimoto we’re much more expensive but no
    Resistors etc needed. These guys should be able to just say what you need to do regardless of price.
    Especially since they made for your year and model.
