Remote Start
Discussion in '3rd Gen Tundras (2022+)' started by waynesel, Jan 20, 2025.
  1. Jan 20, 2025 at 6:17 AM
    waynesel
    waynesel [OP] New Member
    Wayne
    Sierra Vista AZ.
    2024 Tundra Platinum Hybrid
    None
    I can remote start with the fob but truck stops running after about 10 minutes?
  2. Jan 20, 2025 at 6:20 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    That's by design, and has been discussed dozens of times here.
  3. Jan 20, 2025 at 6:32 AM
    waynesel
    Wayne
    Sierra Vista AZ.
    None
    I have read all of the remote start threads and did not see any mention of shutting down before truck is warm inside. Most were not able to start, or shutting off when door opened. I did see Some where the truck was warm and ready to go. I have heat set and steering wheel heat on. I will check with Dealership. Thanks for info it is appreciated.
  4. Jan 20, 2025 at 6:38 AM
    Matt2015Tundra
    2023 1794 CrewMax
  5. Jan 20, 2025 at 7:03 AM
    JerseyGeorge
    JerseyGeorge New Member
    2024 Platinum
    It's been a cold winter in New Hampshire and I am happy with the 10 minute pre heat. Especially the ability to warm it from my phone at distances further than a key fob operates. If I need more time ie to melt ice and snow, I do a second 10 minutes.
    daverxa likes this.
  6. Jan 20, 2025 at 7:15 AM
    waynesel
    Wayne
    Sierra Vista AZ.
    None
    Thank you guys for the info. Matt - Where did you find that info?
  7. Jan 20, 2025 at 7:26 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Google is your friend....I Googled "Toyota remote start and 10 minutes" and literally got hundreds of links that talk about it. I just posted the 2 links that are directly from Toyota's website support section.
  8. Jan 20, 2025 at 11:05 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    I love this is the answer like its magic.
  9. Jan 20, 2025 at 11:40 AM
    Wubbles
    Wubbles New Member
    2023 SR5
    googling it isn't always the answer. I found this thread.. by searching the forums!
    Wish the dealer could reprogram this to run longer.
    -18 here today. had to do 2 remote starts to get it comfortable. I had to set a timer! a modern tragedy to be certain.
