Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Jan 20, 2025 at 9:44 AM
    #3301
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    Have you seen the oil analysis on the 3.4TT thread? Just compared my own analysis to the 5.7s I could find and they are basically identical except for the 2 ppm silver which have been speculated but not confirmed to be related to failure. My truck is part of the recall btw. So if you’re basing your argument for the longevity of the motor on an oil analysis, why does it prove the 5.7 superiority if the results are the same?
  2. Jan 20, 2025 at 9:51 AM
    #3302
    AZBoatHauler
    So.Arizona
    Let’s see
    Terndrerrr and szabo101 like this.
  3. Jan 20, 2025 at 9:51 AM
    #3303
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Moreover, I am basing it on the number of 5.7s that actually fail. The small handful that I've seen have always been neglect.
    Now that 3.4TT on the other hand, hey at least it adds some excitement and spontaneity to your life, some with Turbo lag, some without. Some make it to 100k miles, some to only 40, some shit the bed before making it home from the dealership. Heck, some even do it twice, one even 3 times. Hopefully Toyota is making improvements, but it will never be a trustworthy engine. That's just not something I'm interested in from any of my vehicles.
    WNY PAT likes this.
  4. Jan 20, 2025 at 9:57 AM
    #3304
    What about the camshaft failures. Or the broken valve spring failures.
  5. Jan 20, 2025 at 9:58 AM
    #3305
    FrankG
    FrankG New Member
    Francois
    AZBoatHauler[QUOTED] likes this.
  6. Jan 20, 2025 at 10:03 AM
    #3306
    AZBoatHauler
    So.Arizona
    Definitely the best I’ve seen in a 3rd gen.
    :fistbump:
    Interesting you have such a great result with a low moly oil considering Toyota started bumping moly in the factory fill once the problems started to surface.
  7. Jan 20, 2025 at 10:08 AM
    #3307
    AZBoatHauler
    So.Arizona
    I think there were like 36 camshaft failures. All very early low mileage.
    The valve spring gamble is real - but I think I’ve seen around 10 during my time here. A few survived - a few ate the valve.
    Much more likely to need to tear the intake apart for a coolant valley leak.
    Terndrerrr likes this.
  8. Jan 20, 2025 at 10:08 AM
    #3308
    FrankG
    FrankG New Member
    Francois
    Always had oil changed at Toyota with 0w20. I don’t know what you’re trying to say
  9. Jan 20, 2025 at 10:12 AM
    #3309
    Breathing Borla
    AZ
    my 2010 was trouble free, my 2016 had a few issues
    fuel pump and ecu took a shit, pulley screaming for a bit in cold weather, all were fixed under warranty or extended warranty
    the ge 2 and 2.5 are awesome reliable, but not always perfect, nothing is.
  10. Jan 20, 2025 at 10:30 AM
    #3310
    FrankG
    FrankG New Member
    Francois
    If we compare the universal averages for these engines in the far right column, those aren’t too far apart either. Instead of focusing on our two individual results, maybe tell me why the 5.7 is superior based on those?
    mrlittlejohn likes this.
  11. Jan 20, 2025 at 10:47 AM
    #3311
    szabo101
    szabo101 New Member
    ED
    Seems that those problems were very few.
  12. Jan 20, 2025 at 10:59 AM
    #3312
    AZBoatHauler
    So.Arizona
    I understand your desire to keep the discussion to the numbers on the far right - but the story of the V35 isn’t the universal averages - it’s the number of reports we see that are no where close to those.
    In other words the 3UR is consistent - it is very unlikely to see reports that are a spike from those far right averages.
    Are there a bunch of really good V35 oil reports? You bet. That is what make these ones so troubling and they pop up way more than they should IMO. These were all posted in the same thread of this forum - I didn’t go scouring the internet for the worst reports that aren’t a break-in oil dump.
    IMG_1779.png IMG_1780.jpg IMG_1781.jpg IMG_1783.jpg IMG_1784.jpg IMG_1785.jpg IMG_1786.jpg IMG_1787.jpg
  13. Jan 20, 2025 at 11:24 AM
    #3313
    FrankG
    FrankG New Member
    Francois
    Your premise here is simply untrue and I think we both know it. You seem like an intelligent guy that knows a lot more about engines than I do so I have to assume you did it on purpose to fit your narrative.
    Our individual analysis results are pretty damn close to identical, even the molly content you brought up. In fact, you run 5w30 that should decrease wear. For every result like ours (or 5 or 10 or whatever), there would statistically have to be a result like the ones you reference here for the average to end up where it is and that’s why I believe the universal average is a good comparison.
    We also know from rhetoric on here there is an absolute zero chance of a second gen guy posting a less than stellar result on the 5.7. That doesn’t mean they don’t exist. They have to in order for the averages to be where they are.
  14. Jan 20, 2025 at 11:34 AM
    #3314
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    I agree entirely. And the fact that so many similar analyses looking stellar, is what I base there is not an issue with the design or even a bearing material defect. Or it would be showing up early and on almost all tests of the breakdown.
    We have too many non 3rd gen owners here whom need justification to themself to not jump into a much better designed truck. I didn’t realize all the advances when I bought my 2022 back in October. I have been wowed by how great my truck is. I love driving it, and all non 3rd gen owners need not prove to us they don’t want on. Just don’t buy one!
  15. Jan 20, 2025 at 11:34 AM
    #3315
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    As far as Interesting news goes, just got a call from Santa Fe Toyota. My engine is in, my truck goes in next Monday morning. Fingers crossed.
    22whatwedo, kirkb, obgod3 and 4 others like this.
  16. Jan 20, 2025 at 11:47 AM
    #3316
    AZBaldy
    AZBaldy Bald, James Bald, 000...
    Z
    Kaliforniastan
    2008 SR5 4Runner
    I wish we could have a dedicated "post long block replacement" thread. I see a lot of posts by members saying their engine replacements have been scheduled but not much from anyone who has had it completed. Maybe it's in here but is buried in between all of the other posts. Someone should start that thread so we can follow along with everyone as they go through the process to see what their experience has been.
  17. Jan 20, 2025 at 12:01 PM
    #3317
    OldMotoMan
    OldMotoMan New Member
    2022 Tundra DC SR5
    Got mine back from the motor replacement last week. Only about 200 miles on the new unit so far.
    Took 3 days and when it was returned to me, I was surprised the truck was completely detailed inside and out, as clean or cleaner than the day I purchased it.
    Took a while for the new engine smell to burn off. Rides/drives as before, no rattles, squeaks, etc.. Just running thru the break in process again before tow season starts.
    They gave me a Tundra loaner to drive for the 3 day job...
    mayan, OHwendTrd, 22whatwedo and 14 others like this.
  18. Jan 20, 2025 at 12:02 PM
    #3318
    Breathing Borla
    AZ
    111 pages and we finally have some interesting news. ^
  19. Jan 20, 2025 at 12:06 PM
    #3319
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    You can dream.
    Woodrow bangs likes this.
  20. Jan 20, 2025 at 12:08 PM
    #3320
    BoulderGT3
    Glen
    Great news and good luck.
    Thanks for some real information.
    Sounds like it went to plan.
  21. Jan 20, 2025 at 12:17 PM
    #3321
    So not “always neglect” then
    AZBoatHauler likes this.
  22. Jan 20, 2025 at 12:19 PM
    #3322
    AZBoatHauler
    So.Arizona
    KNABORES likes this.
  23. Jan 20, 2025 at 12:50 PM
    #3323
    AZBaldy
    Z
    Kaliforniastan
    2008 SR5 4Runner
    No thanks. I don't want to be a ringmaster for the 3rd gen circus. I can see people attacking me for not owning one and starting a thread about it. Just saying it would be nice if someone created one so we could see what everyone's experience has been. If they had to go back to the dealership for whatever reason to address any problems etc...
  24. Jan 20, 2025 at 12:55 PM
    #3324
    Mr Rick
    Mr Rick New Member
    There is one. Try this:
    2022 Engine replaced
  25. Jan 20, 2025 at 1:03 PM
    #3325
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I think this is a good idea, I'll start the thread.
  26. Jan 20, 2025 at 1:11 PM
    #3326
    Breathing Borla
    AZ
    its just going to get all shitted up anyways, mark it down
  27. Jan 20, 2025 at 1:22 PM
    #3327
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    Fascinating.
  28. Jan 20, 2025 at 1:30 PM
    #3328
    szabo101
    szabo101 New Member
    ED
    Is it necessary to be that literal? If so, I'll still go with neglect, but I'll be happy to concede the point if you find a documented case that states otherwise. Good luck sir.
  29. Jan 20, 2025 at 1:34 PM
    #3329
    AZBoatHauler
    So.Arizona
    Care to weigh in on Francis’s question? Or was there another point to your post?
    Funny how somehow can quote a person asking a question and other people get mad when they answer like reading this thread is a life chore.
    Raven67 likes this.
  30. Jan 20, 2025 at 1:38 PM
    #3330
    Matt2015Tundra
    2023 1794 CrewMax
    I agree, the universal averages for each engine type are almost identical and clearly don't make a case for one engine being superior to the other.
