  1. Jan 20, 2025 at 4:18 AM
    You know what you’ve done
  2. Jan 20, 2025 at 4:22 AM
    Another Monday, another trip to Tupelo in the FGT. Alright, these ditch pod lights I bought pretty much just suck. Poor light output. I’ve had good luck with Nilight products in general, light bars and such. These just suck. Guess I’ll throw them on the party barge for docking lights. Not spending $400 a pair for pod lights, but I’ll probably step up to a set of Auxbeams.
    Shocks also seem to be worn out, or underperforming at best. I’m sure the E rated meats aren’t helping. Considering OME or Eibach Pros for my next set.
    BroHon likes this.
  3. Jan 20, 2025 at 4:25 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Didn't you just replace those shocks?
  4. Jan 20, 2025 at 4:51 AM
    No, everything but. These 5100s have been on the front for 55k miles (second set) or so and the rears closer to 110k (still on the first set).
  5. Jan 20, 2025 at 6:54 AM
    Setting up some dashboards in OBD Fusion for towing the camper. Still playing around with it. Crazy how low the transmission fluid temp stays when driving. Must not have a thermostat, or it’s wide open all the time for some reason.
    Jack McCarthy and BroHon like this.
  6. Jan 20, 2025 at 7:06 AM
    Is the temp based upon a formula or is it a direct temp sensor measurement? If it’s based upon a formula, maybe you can manipulate/view the actual measured data to see how it responds?
  7. Jan 20, 2025 at 7:07 AM
    It’s actual temp from the sensor. To be fair, it’s 21° outside
  8. Jan 20, 2025 at 7:16 AM
    I think it’s wide open and the cooler works that well. I had a hell of a time getting mine to temp when doing the fluid level check; fluid level check for the 4r w/o cooler took maybe 15 minutes to get to temp
  9. Jan 20, 2025 at 7:20 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  10. Jan 20, 2025 at 7:26 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Our trucks have low washer fluid sensors??
  11. Jan 20, 2025 at 7:26 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah even on long trips in the summer, I never seen mine above 165°F.
    Highest I saw my Tacoma with same transmission was like 215°F when I towed a trailer with concrete culverts for like an hour.
  12. Jan 20, 2025 at 7:28 AM
    You too? :rofl:
    Yep, if you look in the owners manual, there’s a light on the dash for it and it’s not an optional accessory. I only found out 10 years after I bought it new. :facepalm:
  13. Jan 20, 2025 at 7:29 AM
    FiatRunner
    Jack
    Wow. Had no idea. Wonder if mine works.
  14. Jan 20, 2025 at 7:30 AM
    You’d know if you use your washer fluid and it lit up on the dash when it got low. My guess is no.
    FiatRunner[QUOTED] likes this.
  15. Jan 20, 2025 at 7:44 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Yall let your wiper fluid get low? My fuel light has only come on once, and that was on purpose.
  16. Jan 20, 2025 at 7:49 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  17. Jan 20, 2025 at 8:04 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I topped mine off with the winter stuff when i put my skidplate back on.
  18. Jan 20, 2025 at 8:05 AM
    RealTruck
    RealTruck New Member Vendor
    This was an ASMR dream that I didn't know I needed until now... awesome shots of your work!
    oscardog86 and FrenchToasty like this.
  19. Jan 20, 2025 at 8:11 AM
    I can easily go through two gallons of it during the winter here. The past few winters it’s been mild so not so much.
    BroHon and JasonC. like this.
  20. Jan 20, 2025 at 8:17 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I meant to ask if rain-x would make cleaning ice off the windshield easier. Last time i had to scrape it with a gas card or something & decided it wasnt worth the hassle, so i just stayed home.
    bmf4069, BroHon and Kimosabe like this.
  21. Jan 20, 2025 at 8:25 AM
    Some supposedly do, but I've never seen anyone with one. I believe it's built into the housing, and if you don't have it, you just have a 2-wire lead plugging directly to the plastic jug.
  22. Jan 20, 2025 at 8:25 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    Went to the farm and loaded up firewood yesterday. Cypress! Been burning a lot at the house. Had to back down the dry creek to get up next to the pile. (If you haven’t discovered electric chainsaws yet, you are missing out. I was a hater for a long time, but you can store them inside your nice vehicles, they’re good enough for small jobs, and you aren’t always messing with a finicky small engine the first time you need it after sitting a while. I have gas saws too, but for little jobs, I really love this little Ryobi one I picked up.)
    This is enough for the recreational fires we burn in the mornings.
    No pops or squeaks driving up out of the creek and rode like a champ on the way home.
  23. Jan 20, 2025 at 8:26 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    I have the low washer fluid light and it works.
  24. Jan 20, 2025 at 8:31 AM
    You can store them in your vehicle, just be aware: Some of them, like the Homelight I've got (10" or 12" or 14", pretty small), can leak bar & chain oil all over the damn place. Found this out the hard way.
    The translucent oil reservoir on my unit has a slit in it, and the cap to the reservoir is a black rubber bulb. When you need oil on the chain, depress the bulb, the extra pressure pushes oil out the slit in the reservoir.
    Problem is, when that rubber bulb eventually cracks, you lose the seal on the reservoir, and oil naturally dribbles out the slit. It's ultimately a poor design, and a replacement reservoir+bulbcap is only $8 or something, but ... I didn't find out before it stained my garage floor with bar & chain oil.
    But honestly, I haven't used my gas chainsaw in 2 years now, and maybe half a dozen times in the last 10, only when I'm somewhere there's no power outlet or my target is larger than 20" diameter. The electric is too damn convenient!
  25. Jan 20, 2025 at 8:35 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, my hart electric chainsaw will drip a bit. I’ve got a junkyard floormat to sit in on in the truck.
    455h0le_dachshund likes this.
  26. Jan 20, 2025 at 8:44 AM
    That's ultimately what I did too. I had a cheap heavy rubber door mat in the garage to wipe our feet off. I bought a better one for the door, and keep the chainsaw on the cheapie. Its rubber is warped to hell at this point from oil getting into it, but whatever.
  27. Jan 20, 2025 at 8:46 AM
    Yes, it does. Also makes shi**y wipers perform better.
  28. Jan 20, 2025 at 8:52 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, i rain-x my helmet visor.
    bmf4069 and Jack McCarthy like this.
  29. Jan 20, 2025 at 9:51 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    YES. I make sure mine are coated up before winter comes. slightest bit of heat and it comes off like buttah mutha trucka.
  30. Jan 20, 2025 at 10:28 AM
    Getting closer! Only 22,723 miles to go!
    OHwendTrd, JasonC., BroHon and 4 others like this.
