Anyone have experience with these cheapo spacers?
Discussion in '2.5 Gen Tundras (2014-2021)' started by redrum448, Jan 20, 2025.
  1. Jan 20, 2025 at 4:43 AM
    redrum448
    redrum448 [OP] New Member
  2. Jan 20, 2025 at 5:03 AM
    MadMaxCanon and Black Wolf like this.
  3. Jan 20, 2025 at 5:04 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Risk you willing to take?
  4. Jan 20, 2025 at 5:04 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Maybe because if you use the cheapo ones your wheel could come off?
    KNABORES and Black Wolf like this.
  5. Jan 20, 2025 at 5:06 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Understand that it's always a roll of the dice buying no-name Chineseum stuff on AMZ or wherever. The two biggest concerns for me would be metallurgy and fit tolerance.
    Do you want to roll the dice on a component that keeps your wheels from falling off?
    If you're dead set on doing that, (going cheap) stick with a known brand like KSP that has some history.
    For a DD/pavement princess/mall crawler that will rarely if ever do any serious offroading, you'll probably be fine. But then again...you might not.
    I've had good luck with spacers.
    All in street CAR applications with relatively light weight wheel and tire combos and vehicles weighing less than 3500 pounds. So, much less stress than what a full size truck with heavy wheels and tires is going to see.
  6. Jan 20, 2025 at 5:09 AM
    BrandonL812
    Brandon
    If you want quality, get spidertrax spacers. I have 2 sets im willing to sell. 1 months old. Still deciding on what to ask for.
  7. Jan 20, 2025 at 5:21 AM
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Go with the spiderytrax spacers I’ve had good luck with them or Bora spacers either way can’t go wrong
    better safe than sorry
    KNABORES likes this.
