  1. Jan 19, 2025 at 5:51 PM
    koditten
    Kirk
    Midland of the Mitten
    What?
    I'm confused. There is still a need for a key. All remotes shut off if the key is not in the ignition when you put your foot on the brake to engage drive.
    Keyless vehicles need the fob nearby to do the same.
    The open the door while truck has been remotely started and truck dies is bull shit!
  2. Jan 19, 2025 at 5:52 PM
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    Well I guess that makes sense. It’s sad that they have to do a CYA at that level. And really I can deal with it. Two snow scrapers, one inside the truck, one out.
    1794TX[QUOTED], AZBaldy and T-Rex266 like this.
  3. Jan 19, 2025 at 6:01 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So the thieves have to smash the window then pull a Bo Duke. :evil:
  4. Jan 19, 2025 at 6:15 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Same with high temps... anything north of 105 just freakn' hot; and there's no such thing as a 'dry heat'!!!!
  5. Jan 19, 2025 at 6:18 PM
    Tripleconpanna
    I had the same issue w/my first gen... couldn't stand the access cab, suicide door, gotta open the front before you can open the back b.s. functionality :frusty:
    Other than that it was super comfortable, almost effortless driving and obviously reliable :thumbsup:
  6. Jan 19, 2025 at 6:19 PM
  7. Jan 19, 2025 at 6:21 PM
    Tripleconpanna
    Depends on the angle of entry.... it appears to have angled toward the sidewall, so if you've got abrasions/scraping on the inner side wall from the tip of the screw and appear to have compromised the sidewall integrity, then I'd say replace it; if on the other hand, the puncture is clean on the inside I'd be okay w/it :thumbsup:
  8. Jan 19, 2025 at 6:27 PM
    Tripleconpanna
    If the inside of the sidewall is clean and you decide to repair, just use what is called a 'performance tire' patch, which is designed for speed rated tires and per industry standards (at least a long time ago) would allow the tire to maintain its speed/performance rating...
    They basically look like a combo plug/patch, so you have redundancy in the repair by having a plug through the hole and a properly installed patch on the inside, if that makes sense...
    First image I could find to give you an idea...
  9. Jan 19, 2025 at 6:29 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Not nearly enough.
    Expanding foam the entire inside of the tire cavity, and then half a tube of silicone over the top just to be sure. (The duct tape won't hurt though.)
    Saw it on TikTok so it must be the right way.
    Seriously, I'd be fine plugging that (done correctly) and wouldn't lose a minute of sleep over it.
  10. Jan 19, 2025 at 6:42 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You know what else is a dry heat? Fire!
  11. Jan 19, 2025 at 7:37 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    Roses are red.
    Violets are red.
    Trees are red.
    Grass is red.
    Oh shit, my yard's on fire!
    JMB, AZBaldy, T-Rex266 and 5 others like this.
  12. Jan 19, 2025 at 7:56 PM
    NWPirate
    Zach
    WA
    That would be sweet, but I'd have to have someone unmount and mount (twss) the tire knowing I'm patching a questionable puncture... :monocle:
  13. Jan 19, 2025 at 7:59 PM
    NWPirate
    Zach
    WA
    Too soon?
    :bananadead:
  14. Jan 19, 2025 at 8:57 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  15. Jan 19, 2025 at 8:57 PM
    Tripleconpanna
    I thought you guys weren't allowed to build fires up there :boink:
    ...or are you just talking about unintentional ones??
    :nuclear:
  16. Jan 19, 2025 at 9:01 PM
    Tripleconpanna
    Good Lord :facepalm:
    Just take it down to your nearest tire shop, and ask them to repair it...
    If they say no, then ask them to just remove the tire from the wheel for you; then take it home and fix it; then take it to a different tire shop and tell them you're putting a full size spare on a wheel you got off FBMP, and have them mount and balance it up.... :thumbsup:
    :nuclear:
  17. Jan 19, 2025 at 9:04 PM
    Tripleconpanna
    That whole rainbow dial thing around the temp display is quite distracting...
    much like trolling this thread and coming across a pic of you standing there in your Sean Johns w/full side nipple in view :eek:
    :nuclear:
    j-utah, AZBaldy, T-Rex266 and 2 others like this.
  18. Jan 19, 2025 at 9:11 PM
    Tripleconpanna
  19. Jan 19, 2025 at 9:16 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    :sadviolin:
    I did send an email to wunderground.com to see if they will take their rainbow dial down because my buddy thought it was offensive.
    they sent me back a link to this.
    https://m.youtube.com/watch?v=gwGqGFzPWQ0
  20. Jan 19, 2025 at 9:16 PM
    NWPirate
    Zach
    WA
    I'll just run a bigger screw in there and call it good
  21. Jan 19, 2025 at 9:31 PM
    Tripleconpanna
    I said 'distracting' not 'offensive'... :evil:
  22. Jan 19, 2025 at 9:40 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Dammit. :frusty::facepalm:
    Now it makes sense why they responded so sarcastically.
  23. Jan 19, 2025 at 9:51 PM
    Dammit. It snowed again :mad:
  24. Jan 19, 2025 at 9:58 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  25. Jan 19, 2025 at 10:00 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Here as well. But not much.
    T-Rex266[QUOTED] and AZBaldy like this.
  26. Jan 20, 2025 at 3:08 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    did someone need "tire damage on a Tesla" advice?
    I'm your man.
    That's a full replacement.
  27. Jan 20, 2025 at 3:26 AM
  28. Jan 20, 2025 at 3:42 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  29. Jan 20, 2025 at 3:50 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    No.
    it's 32 here Houston...and feels like death is right out side my door.
    AZBaldy, OldGuy03, T-Rex266 and 6 others like this.
  30. Jan 20, 2025 at 3:53 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    point of interest:
    apparently, when you reach about ~250lbs...the pneumatic thing in your office chair looses it's pneumatic-ness.
    or so I hear.
    AZBaldy, OldGuy03, T-Rex266 and 4 others like this.
