Weight of 16" OEM Wheel Rim?
Discussion in '1st Gen Tundras (2000-2006)' started by jsvwx, Jan 5, 2025.
  1. Jan 5, 2025 at 3:50 PM
    jsvwx
    jsvwx [OP] New Member
    New York
    2001 AC SR5 V6 5M 4WD
    Does anyone know the confirmed weight of this rim? I looked around and can’t seem to find a consistent weight posted anywhere online. It ranges from 27 to 39 lbs on various sites. This is the stock rim on my 2001. Thanks!
  2. Jan 6, 2025 at 8:58 AM
    Find the part number in the parts catalog. Plug it in at https://www.toyotapartsdeal.com/
    Look at their 'more info' section on the part. It'll give the weight. It's looking like it's somewhere between 26-27lb on those for the part number I Googled on.
    The Black Mamba and jsvwx[OP] like this.
  3. Jan 6, 2025 at 10:43 AM
    jsvwx
    New York
    Thanks @shifty` for the link! It seems light for a steel rim, doesn't it? Most alloys are in that range and the steel wheels are usually in the 30s.
  4. Jan 6, 2025 at 10:51 AM
    26-27lb for a stamped steel 16"-17" wheel? sounds pretty normal to me.
    jsvwx[QUOTED][OP] likes this.
  5. Jan 6, 2025 at 12:35 PM
    jsvwx
    New York
    I was just comparing it to a 17" Black steelies that weight in the '30s.
  6. Jan 7, 2025 at 2:54 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Those wheels are notoriously heavy.
  7. Jan 7, 2025 at 5:40 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    Those Tundra "styled steel wheels" are heavy as hell and strong as hell. Problem is that mud and ice build up in the area between disc and outer rim and they will shake the truck to pieces until you get it cleaned out. Stupid design if you ask me.
    jsvwx[OP] and shifty` like this.
  8. Jan 19, 2025 at 10:44 AM
    jsvwx
    New York
    Finally got around to weighing this wheel and it's 29 lbs.
  9. Jan 19, 2025 at 11:00 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
