  1. Jan 19, 2025 at 6:22 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
  2. Jan 19, 2025 at 6:29 AM
    NUDRAT[QUOTED] likes this.
  3. Jan 19, 2025 at 6:39 AM
    Im only 23,112 miles away from the big 3 hundo. By my calculations, I’m right behind you. Should roll over around 3.125 years from now.
  4. Jan 19, 2025 at 7:30 AM
    Was topping off windshield washer fluid and decided to pull the strainer…
    Well hello there, who are you? Looks like a sponge of some type.
  5. Jan 19, 2025 at 8:16 AM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I think it's supposed to act like a float level, once you see it, it's full.
  6. Jan 19, 2025 at 8:19 AM
    No, that wasn’t the case here. It’s only 1/4 gal full. I put another 3/4 gallon to fill it after that pic. No movement of the sponge thingy.
  7. Jan 19, 2025 at 8:20 AM
    Although my low washer fluid sensor never worked from the first day I bought it new so…
  8. Jan 19, 2025 at 8:21 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You broke it
  9. Jan 19, 2025 at 8:43 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Funny thing, about a week ago when I topped off all the fleet I noticed that thing for the very first time, and I was like, OH, that's how you tell when its full... that's pretty neat
  10. Jan 19, 2025 at 11:58 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Dropped my skid to reinstall my front swaybar with suspension max endlinks. Touched up some fluid film too, dropped the spare, and lubricated that mech.
    Yesterday we swapped some 5100s into my buddy's 2002. He is happy, but spring compressors suck.
    Question for the group. When I had my skid down, I saw that the check plug on the transmission pan was leaking. If I want to replace the crush washer (I can't see one) can I remove the check plug with the vehicle cold and level without spilling a meaningful amt of transmission fluid?
  11. Jan 19, 2025 at 12:19 PM
    I would make the passenger side of the truck higher to keep the fluid level below the check plug opening and replace it that way.
  12. Jan 19, 2025 at 12:19 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    The immediate problem was just the pulley bearing, so I didn’t have to remove the tensioner itself. Pulled the pulley wheel/bearing and its center bolt, which is reversed (left handed) threads btw. However, your insight wasn’t for nothing. The tensioner did not seem well and recoiled sluggish at best, so I’ll be replacing it soon enough as well.
  13. Jan 19, 2025 at 12:27 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Thanks for the advice!
  14. Jan 19, 2025 at 12:30 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Mine has no crushwash and neither did the donor trans I swapped in. Check the FSE for the torque spec. I remember it being low.
  15. Jan 19, 2025 at 1:05 PM
    Well went out to Harbor Freight and picked up a fastener kit since Lowes didn’t have the right size which is 1/4” for the apron shown below.
    Unfortunately, it’s in the wrong hole. It’s hard to feel around for it in the dark. I’ll have to fix that again if I ever get around to it after the storm.
    oscardog86, BroHon and FrenchToasty like this.
  16. Jan 19, 2025 at 1:10 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Think I'll try a gasket instead of overtorque.
    Straight from the 05/06 FSM:
    Install the overflow plug with a new gasket.
    Torque: 20 N⋅m (205 kgf⋅cm, 15 ft⋅lbf)
    Part No from EPC-Data: 35178-30010
    I think I have a grasp of how this works. Hopefully enough to remove and replace while cold and tilted away from the tube.
  17. Jan 19, 2025 at 3:23 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Yeah I didn’t think about us have different trans.
  18. Jan 19, 2025 at 4:36 PM
    bing5
    bing5 New Member
    New Mexico
    2004 Double Cab. 260k+
    Was foiled by a flare nut on the fuel filter, but did get new TYC headlights installed and 3M-restored the fog lights. headlight2.jpg
    Very happy with the TYCs from RA. Thanks for the mega thread advice.
  19. Jan 19, 2025 at 5:07 PM
  20. Jan 19, 2025 at 5:32 PM
    Quite frankly, the OEM fasteners that are supposed to fit in that hole, they fit like shit and pop out readily. Only seems to be the case with the holes in the strut tower. Why/how is this? Hell if I know, but this has been my [painful] experience.
  21. Jan 19, 2025 at 5:36 PM
    I think the correct hole is elongated like an oval. I’m not sure why but that’s what I felt. Couldn’t get a light on it to confirm unless I wanted to crawl on the ground in my good clothes.
  22. Jan 19, 2025 at 5:48 PM
    Any hole will do
  23. Jan 19, 2025 at 5:51 PM
    bing5
    bing5 New Member
    New Mexico
    Managed to get the foam surrounds in the front cup holders replaced too. If yours look old and ratty like mine did, highly recommend! They cost like $15 and make the interior look so much better. Job took about half an hour.cup.png
  24. Jan 19, 2025 at 5:57 PM
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
  25. Jan 19, 2025 at 6:05 PM
    Just the tip, though.
  26. Jan 19, 2025 at 6:16 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Back when I still did my own fluid changes, I never used crush washers. I've got a ton of em too lol
  27. Jan 19, 2025 at 6:20 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    "While I'll still take any port in a storm." :rofl:
    RUSTYNUTS, BroHon and shifty` like this.
  28. Jan 19, 2025 at 6:21 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    One of these days I need to do this. Where'd you get them?
  29. Jan 19, 2025 at 7:45 PM
    bing5
    bing5 New Member
    New Mexico
    eBay.
  30. Jan 19, 2025 at 9:10 PM
    Wait, what? What did I do?
