Replacing bed floor panels? (rusted completely through)
Discussion in '1st Gen Tundras (2000-2006)' started by taranovich92, Apr 27, 2020.
  1. Mar 13, 2022 at 9:00 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    All the 05-06 guys bragging about having xyz more horsepower but then have secondary air injection and no free frame replacement. I think the older trucks are a better tradeoff unless you need to tow 24/7.
    G_unit3000 likes this.
  2. Mar 14, 2022 at 1:22 PM
    jamessmith00
    jamessmith00 New Member
    James
    2003 SR5 Tundra V6
    You need a new bed...Just keep asking around and eventually you will find someone who buys them from rust free areas and brings them up to your area for resale! That is what I did and then had the auto body guys do their magic and top it off with fresh paint and a spray in bed liner! 20211023_113559.jpg
    G_unit3000, Jack McCarthy and bmf4069 like this.
  3. Mar 14, 2022 at 1:31 PM
    Bed liner is all fun and games until water finds a way to get under it. Then this happens: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1205#post-2562971
    Owner of that truck confirms, rust started under the spray-in bedliner, and I've seen the same dozens of times before on other people's trucks. It's only a matter of time.
    Like powdercoat, most bedliner is just that: A coating. It doesn't create a impervious bond with the metal. You're basically at the mercy of the person applying and whether they do everything possible to ensure, for the rest of its life, it never gets thin enough to let water inside.
    I will say, you've got just about the nicest damn bed I've ever seen for a 1st gen! Welcome to the forum!
  4. Mar 16, 2022 at 2:15 AM
    jamessmith00
    James
    2003 SR5 Tundra V6
    It's true that nothing lasts forever, but I haul a lot of brush and junk in the back of my truck and I think the bed liner will give me plenty of miles, and for now I get plenty of great comments. Only time will tell if it can withstand the test of time.
  5. Mar 16, 2022 at 6:44 AM
    jefffrazee
    jefffrazee New Member
    2001 Tundra SR5, AC, 4x4, 4.7l
    Yeah, they are life time recalls since it was a safety concern.
  6. Mar 16, 2022 at 6:59 AM
    jefffrazee
    Did you happen to get a chance to get some pictures of those patches?
  7. Mar 16, 2022 at 8:31 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Drop in bedliners shouldn't be made anymore. Worst thing ever for a truck. Dealership should be held responsible for all repairs, if they sold new trucks with them installed.
  8. Mar 16, 2022 at 9:16 AM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    Haven't done the work yet but I will post when I do
  9. Jan 19, 2024 at 10:27 AM
    Buckmiester
    Buckmiester New Member
    2003 silver tundra TRD 4*4
    Ik it’s an old thread, but did you ever happen to see if it worked? I’ve got the same problem with mine and was wondering
  10. Jan 18, 2025 at 9:34 PM
    Kevbev 7
    Kevbev 7 New Member
    05' TRD sr5 limited 4.7 4x4 access stepside
    3.5 frt leveling kit, rear air bags, stainless exhaust
    A few years ago I took my plastic bed liner out to have it line-x'ed and I found similar rust holes by the wheel wells, after evaluating the situation I found out that those 2 center cross supports face each other right over the rear Axl and seems to collect alot of road grim and salt that cannot get out of there after finding its way in.
    I should have repaired mine,
    My method would have been to get some of those metal/ tin studs they use in commercial buildings to replace the 2 rusted ones or any others
    Cut out the rusted areas,
    try to make it look symmetrical or neat and tiddy for the patches to go back in,
    I was going to use a home heating fuel tank for the patches, I find them for free to scrap on Craigslist alot and I think it's about the right thickness,
    Weld them in and grind smooth and prep, primer, paint, and bed liner over it.
    It's not a major visual area, it's more of a form functional space.
    Food for thought
