RCD Lift
Discussion in '1st Gen Tundras (2000-2006)' started by Cmoore865, Jan 5, 2025.
  1. Jan 5, 2025 at 2:15 PM
    Cmoore865
    Cmoore865 [OP] New Member
    Cameron
    2006 White Tundra Limited
    4-6” RCD lift, bumpers, winch, lights, camper top
    Hello, I’m new to the group. I have an 06 Tundra Limited Double Cab with the RCD 4-6” lift. This truck came with the lift. I’d actually like to take it down a few inches as well as tire size. It’s just not practical for what I’m wanting to use it for. I love the truck and it runs great, but with the higher suspension and bigger tires, it just doesn’t handle well. I know this is a permanent lift, but has anyone ever taken it down closer to a 2” lift ? I appreciate any advice !
  2. Jan 5, 2025 at 2:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You'll probably be able to sell the drop bracket lift. Lots of people seek em and they are getting harder to find.
    I believe you'll have to weld in a new cross member when you remove the drop bracket.
    Hi06silver likes this.
  3. Jan 6, 2025 at 7:20 AM
    Yes, using the Search function, I was able to find this thread from @Hi06silver where he was able to un-fucker his truck from the very-similar drop bracket setup Tuff Country uses: https://www.tundras.com/threads/hi06silvers-unf-ck-my-tuff-country-lift-thread.90187/
  4. Jan 18, 2025 at 12:43 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I did not drop down in height though. If anything I went up 1/2 an inch, I just did what I did because of the stories I read about the upper ball joint spacer breaking so I eliminated it and refreshed the ol' tired ass suspension components. I'd go down a few inches if it didn't involve welding in a new x-member.
    shifty` likes this.
