TRD Skid Plate Hardware Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodl12, Mar 2, 2023.
  1. Mar 2, 2023 at 7:41 AM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I pick up a used TRD skid plate for my 2017 SR5 Tundra. Can someone tell me if I have all the hardware here and if I'm missing anything can I use any of the hardware from the stock skid plate?IMG_5536.jpg IMG_5535.jpg
  2. Mar 2, 2023 at 7:46 AM
    running214
    running214 New Member
    Bilstein 5100's, Morimoto gen 2 XB headlights and fog lights, TRD sway bar and skid plates. Nothing else needed!
    you can use the bolts up front from the stock plate, the rest will be whats shown in your photos. Looks like you're missing two bolts. Should be two in the middle, two at the back, and one in the center that uses the aluminum block.
    MedCityMoto likes this.
  3. Mar 2, 2023 at 8:34 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You might want to go ahead and get a full hardware kit. Pricing varies depending on where you go, but it'll be between $85-120. PT938-34140-HW
    reywcms likes this.
  4. Mar 2, 2023 at 8:52 AM
    rodl12
    Rod
    South Jersey
    I thought of that but it looked like many of the parts in the kit include rivots and some other things that are installed on the plate. I hate to throw away the money if I don't need them.
  5. Mar 2, 2023 at 8:56 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It might be overkill, but you're missing several spacers and bolts that aren't easy to find. Part of that includes the shim/washers that go on top of the rear crossmember. They're angled to match the slop on top of the crossmember and allow you to torque the bolts correctly. I have some of the spacers in my junk box from when I swapped to a fresh hardware kit (I was in the same boat as you, receiving only some of the hardware on a takeoff plate) that I'd be happy to send your way if you want to cover shipping, but you'll still be missing the top of the crossmember hardware.
    reywcms and rodl12[QUOTED][OP] like this.
  6. Mar 2, 2023 at 8:56 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    If you've got the two longer rear bolts, that middle 'brace' box and the little screw that holds it in place, that's all you really need, you can re-use the existing bolts from your stock plate. Someone might notice if they're crawling around under there that they're black and not silver, gasp. But the bolt length is the same regardless, the TRD skidplate's only a little thicker.
    Edit: Ahh yeah I forgot about those spacers to go atop the crossmember. I'd offer you mine if I can ever get ahold of a nut retention plate for my cat shields + TRD skidplate.
    rodl12[QUOTED][OP] likes this.
  7. Mar 2, 2023 at 9:00 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Here's a pic of the underside of mine brand new with the hardware it came with if it helps to visually compare to what you've got.
  8. Mar 2, 2023 at 9:52 AM
    rodl12
    Rod
    South Jersey
    Looks like I need these 2 bolts and sleves.
  9. Mar 2, 2023 at 10:00 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    There are also 2 spacers at the front. I think they're around 1/4" thick.
  10. Mar 2, 2023 at 10:09 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  11. Mar 2, 2023 at 10:41 AM
    rodl12
    Rod
    South Jersey
    The 2 bolts with the thick washers, do they go on the corners?
  12. Mar 2, 2023 at 10:51 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    They go here:
  13. Mar 2, 2023 at 12:54 PM
    rodl12
    Rod
    South Jersey
    Thank you for you help and the pics you posted. They are a big help!
    junior likes this.
  14. Mar 2, 2023 at 12:56 PM
    rodl12
    Rod
    South Jersey
    I did go to the dealer and they want $118 for the hardware kit. I contacted the guy I got the plate from and he is going to look and see if he still has the missing parts. I'm not feeling good about this.
  15. Mar 2, 2023 at 1:08 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I'd take that part number and search online might be able to get it cheaper.
  16. Mar 2, 2023 at 1:18 PM
    rodl12
    Rod
    South Jersey
    I did that but couldn't find anything, thanks though.
  17. Mar 2, 2023 at 1:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  18. Mar 2, 2023 at 1:27 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I can send you those 4 bolts that I posted a pic of. Shoot me a PM if you want em.
  19. Mar 2, 2023 at 2:19 PM
    rodl12
    Rod
    South Jersey
    reywcms[QUOTED] and TRDFerguson like this.
  20. Mar 2, 2023 at 2:21 PM
    MedCityMoto
    Damn, for real I will go take the bolts out of my skidplate and get you measurements so you can just buy local stainless steel ones for $5 at Ace Hardware, there's no need to throw $100 away like that
    OHwendTrd, rodl12[OP] and reywcms like this.
  21. Mar 2, 2023 at 3:19 PM
    rodl12
    Rod
    South Jersey
    I PMed you the pic.
  22. Mar 2, 2023 at 3:25 PM
    rodl12
    Rod
    South Jersey
    Is there a different hardware kit used for Tundras that are lifted? I have a 3.5" Ironman lift on my 2017 SR5.
  23. Mar 3, 2023 at 2:02 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    Sparks Parts discount code for 30% off shipping: ship30
  24. Mar 3, 2023 at 2:04 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Is the ironman lift just a coilover lift? If so you're fine. If it's a bracket lift then no, the TRD plate won't work.
  25. Mar 4, 2023 at 3:19 AM
    rodl12
    Rod
    South Jersey
  26. Jan 16, 2025 at 8:40 AM
    Bayou Spartan
    Bayou Spartan New Member
    Black 2019 TRD PRo
    None
    I ordered this kit
    Awaiting shipment
  27. Jan 18, 2025 at 3:34 AM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    By any chance does anyone know that is the size and thread count for the nut on the two bolts on the rear of the skid plate facing the rear of the vehicle?
    I need a replacement until my back order arrives. i found it was never there.
