Turbo Charging A Tundra!
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Jan 17, 2025 at 4:04 PM
    #1501
    centex
    centex New Member
    Sounds like the system was left armed and the controller somehow failed and turned the pump on.
  2. Jan 17, 2025 at 4:12 PM
    #1502
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    Some are suggesting syphoning, I'm just saying I've never had that issue. What I do know is that the truck and the system have never been in 11* overnight, so ????
    I wish there was some symptom aside from a low fluid indicator I noticed a few minutes before failure.
  3. Jan 17, 2025 at 4:15 PM
    #1503
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Is that what happened? So the pump kicked in and pumped all the liquid (a gallon or less) into the intake?
    That is messed up! Hate to hear that for sure. The next thing is how to make a safety net so it does not happen again!?
    On a good note,,,,, those guys in Florida will give you a special motor. :)
    Man THAT SUCKS!!!!! That is some S;:/!!! Did you hit something last time you drove it when you were getting out??
    bflooks[OP] likes this.
  4. Jan 17, 2025 at 4:19 PM
    #1504
    bflooks
    Metrowest MA
    I have no proof it was the pump, the controller or perhaps even a frozen line that could have opened the check valves. What I can say is that a full 1.15 gallons were drained from one location into another.
    For me, for now, I'm bypassing the kit entirely until the severity of the situations fades a bit. That was a really expensive 1.15 gallons.
  5. Jan 17, 2025 at 4:20 PM
    #1505
    centex
    centex New Member
    I’m purely speculating so don’t take what I say as what happened. Just my experience with water meth has been the system has to be on and armed for it to spray. There is a boost reference for the controller to start spraying and ramp up the volume as boost ramps. No boost, no spray, low boost, low spray, etc. But to dump a gallon in a matter of minutes is full on pump flow so something turned it on full time.
  6. Jan 17, 2025 at 4:22 PM
    #1506
    Black@Blue19
    Ken
    SE Texas
    ^^^^ WOW! I feel your pain!
    Well CRAP!!!! Moving forward I wish you all the BEST!!!
  7. Jan 17, 2025 at 4:22 PM
    #1507
    bflooks
    Metrowest MA
    Negative. I specifically put the controller in an out of reach, hard to get to location and confirmed there is nothing that could have pressed against the knobs or the test button.
  8. Jan 17, 2025 at 4:23 PM
    #1508
    centex
    centex New Member
    If the check valves froze open then I could see the siphoning. System under engine vacuum could draw it down. But I’d expect you to notice the engine pinging or running funny before hand. Methanol is combustible so if it was spraying while the engine was running you should have heard something.
    I always had an LED on my dash to show when the system was actively spraying and the intensity would ramp up the more it was pumping. I’ll probably do that on this.
    bflooks[QUOTED][OP] likes this.
  9. Jan 17, 2025 at 4:25 PM
    #1509
    bflooks
    Metrowest MA
    I feel badly for Jesse on this one. The timing of this absolutely sucks, and I cant foot stomp enough that this was 100% a water/methanol issue and has nothing to do with the turbo side it. I'd be much happier if it was something that happened while I was making a Dragy run.
  10. Jan 17, 2025 at 4:25 PM
    #1510
    koditten
    Kirk
    Midland of the Mitten
    Man! That really blows?^
  11. Jan 17, 2025 at 4:29 PM
    #1511
    bflooks
    Metrowest MA
    Nothing. Of course it was essentially at an idle until I got to the light to leave Dunkin'. So, kudos to the motor for holding strong despite drowning?
    Black@Blue19 likes this.
  12. Jan 17, 2025 at 4:31 PM
    #1512
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh man that sucks! I use the snow controller full flow AEM 500cc nozzle at 9psi. I've read where the AEM controller can be finicky but mostly in the older controllers. I use the aem pump, nozzle and a simple Snow controller.
    The check valve can freeze open the nozzle has a check valve too to prevent siphoning.
    Using 250cc nozzle?
  13. Jan 17, 2025 at 4:35 PM
    #1513
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Sorry for your loss...that sucks. Hopefully you can reuse the block/heads/crank. Do you think a solenoid would have saved it, or did you already have one?
  14. Jan 17, 2025 at 4:37 PM
    #1514
    bflooks
    Metrowest MA
    Yeah... I've got nothing for an actual cause, but def put 1.15gallons from the AEM reservoir into the motor. Overnight or upon startup is unknown. Why now is also not known. Only variable I have is the frigid temps that the kit hasn't seen on my truck before.
    Again, cautionary tale for you and other water/methanol folks. I am running the latest AEM controller, a Snow inline check valve, and the latest AEM nozzle with built in check valve. I thought We had redundancy and safety nets for the safety nets.
    AEM stated they sell the solenoid to prevent syphoning.
    Hope this saves someone else from having to learn this lesson themselves.
    Black@Blue19 and Mdl[QUOTED] like this.
  15. Jan 17, 2025 at 4:38 PM
    #1515
    bflooks
    Metrowest MA
    Possibly, but I honestly don't know. That's the worst part. A substantial tab for a head scratch.
  16. Jan 17, 2025 at 4:42 PM
    #1516
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Condensation freezing inside map controller. But with no power or the light signaling it's pushing w/m. Did you have an external on/spraying light or just controller light?
  17. Jan 17, 2025 at 4:53 PM
    #1517
    centex
    centex New Member
    What ratio of water/meth were you running? Reason I ask is generic blue windshield washer fluid is 80/20 and is generally good to below freezing. You can even get lower freezing temp versions which is just a higher percent methanol.
  18. Jan 17, 2025 at 4:57 PM
    #1518
    bflooks
    Metrowest MA
    The lighting was bright, so the LED was a bit washed out, but the only indicator I saw was a few minutes before failure it started the 1 delayed flash (low fluid). Once I got off the road and it wouldn't make a sound, I got out and checked and the reservoir was bone dry.
    Only run Boost Juice. 49% methanol
    centex[QUOTED] and Mdl[QUOTED] like this.
  19. Jan 17, 2025 at 5:12 PM
    #1519
    bflooks
    Metrowest MA
    Sorry for not Answering your question. 500cc nozzle
  20. Jan 17, 2025 at 5:31 PM
    #1520
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'd be on the phone with AEM on Monday. Maybe just to get an idea of what was the issue in the system. We know it pumped/siphoned the juice into the intake...
    Not like the old days 4wheelin it in the bogs get hydrolocked, open plugs, drain oil and get going.
    I feel for ya. I had my daughter with me when my engine grenaded. I still hear her saying, is that bad?
  21. Jan 17, 2025 at 5:43 PM
    #1521
    bflooks
    Metrowest MA
    Jesse has already been there with them while I was triaging in my garage hoping to get it to turn over. Not convinced it isn't temp/environmental related. It has a strong vacuum at idle, but again one would think it would have syphoned before if that's what it was. I've decided I can't dwell on what I can't change, but agreed it would be great to know the root cause.
    Mdl likes this.
  22. Jan 17, 2025 at 5:47 PM
    #1522
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Hate to hear it, sorry man! Hell of a way to go out. Need a dislike button on these forums
  23. Jan 17, 2025 at 6:12 PM
    #1523
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    As a man currently replacing 2 engines I truly feel your pain.
    If it makes you feel better, I found a 70k '18 Tundra motor for 4k
    Sorry
  24. Jan 17, 2025 at 6:33 PM
    #1524
    bflooks
    Metrowest MA
    There are few up here locally between 25k and 130k miles for $5k-8.4k. labor costs are the same regardless of what I put in, so I need to take the weekend and decide if the XAT is worth the extra money. I'm leaning towards yes because even if for no other reason that they have been rebuilt. Not a knock on a stock engine. It was my original plan. But here I am at an unplanned fork in the road. Stock would be faster, in theory.
    Oh! And I have been following your motor "opportunities" and I don't envy you at all. It'll all be worth it in the end, right?
    e30cabrio[QUOTED] likes this.
  25. Jan 17, 2025 at 6:45 PM
    #1525
    e30cabrio
  26. Jan 17, 2025 at 7:17 PM
    #1526
    bflooks
    Metrowest MA
    That is the list I'm shopping off of. :) One showed compression at 200 on all cylinders, which I might be inclined to buy and ship to XAT as a core, but IDK. Decisions, decisions. If labor was cheaper I'd 100% roll the dice on transplanting one of these.
    e30cabrio and Mdl like this.
  27. Jan 17, 2025 at 9:37 PM
    #1527
    centex
    centex New Member
    On a positive note, I pinged Jesse and had him upgrade my order to the stage 2 with the injectors and meth. This should hold over my corvette itch for a while.
    Yes Im turning 40 and yes I want a corvette. I’m fine with being a stereotype.
  28. Jan 18, 2025 at 12:39 AM
    #1528
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Haha! I'm in my 50's and fit the bill...I find it funny when I'm sideways around a roundabout/rotary and they see a white bearded man smiling...:p
  29. Jan 18, 2025 at 1:47 AM
    #1529
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Swapping out an engine is not that difficult. If you got the garage space it can be done. In my opinion the hardest part is not dinging the windshield on the install.
  30. Jan 18, 2025 at 3:05 AM
    #1530
    bflooks
    Metrowest MA
    Stage 2 is where it is at. You won't be upset, and it's waaaaày cheaper than a Corvette. Congrats! Eventually @Jego will also have his installed and there will be a good sampling. I know I was going to hit my 5.0s goal and I'm looking forward to seeing what you end up getting out of it.
    e30cabrio likes this.
