Clean, corrosion free batt terminals & Limp mode
Discussion in '2nd Gen Tundras (2007-2013)' started by tmac58star, Jan 17, 2025.
  1. Jan 17, 2025 at 7:46 PM
    tmac58star
    tmac58star [OP] New Member
    Black 1st generation Tundra SR5 Access Cab
    Happened to me with my 2000 1st gen w/4.6L, and recently with my 2007 2nd gen w/4.7L.
    Symptoms: Odd dash lights at start, or suddenly when running, then truck goes into Limp mode.
    Your truck needs batt connectors replaced/upgraded...all corroded cables replaced, and clean/clean/clean & tight connections.Then the corrosion spray...we used a liberal dawb of grease way back when. I was shocked 1st time I checked my batt...expected "truckier" cables rather than small sedan connectors. Hope this helps others..
