General Supercharger Thread
  1. Jan 17, 2025 at 6:58 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sniv is the way!
  2. Jan 17, 2025 at 6:59 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Send me your email and I'll send you the datalogging setup I use and then we can go through the logs together, then you can save buying a MPVI if you can. Datalogs can be done and sent to anyone, even if the tune is locked.
    ARES35, HulkSmurf14, Wynnded and 5 others like this.
  3. Jan 17, 2025 at 7:14 AM
    nags
    nags New Member
    Ah, f yea. I didn't know that was possible.
    Mdl, HulkSmurf14, Wynnded and 2 others like this.
  4. Jan 17, 2025 at 7:37 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    With @snivilous , anything is possible
    ARES35, Tripleconpanna, Mdl and 6 others like this.
  5. Jan 17, 2025 at 7:37 AM
    nags
    nags New Member
    Tripleconpanna, Ryuu, Wynnded and 2 others like this.
  6. Jan 17, 2025 at 7:38 AM
    carn_dogg
    Pat
    Eastern Shore MD
  7. Jan 17, 2025 at 7:40 AM
    snivilous
    SW UT
    You guys are making me cringe :rofl: I'm just here to help, no guarantee it'll work, but I'll do everything I can! And looking at datalogs is minimal effort.
  8. Jan 17, 2025 at 7:40 AM
    carn_dogg
    Pat
    Eastern Shore MD
  9. Jan 17, 2025 at 9:13 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I might be dealing with a similar issue AFRs would follow the surging. Throttle relearn fixed it for me before. Truck is in the shop will report back if he sorted the issue out and how.
    Mdl, nags[QUOTED] and e30cabrio like this.
  10. Jan 17, 2025 at 9:23 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    I have some moderate idle oscillating/wandering/surging as well. From my understanding in open mode when you first turn on the Truck the 02 sensors are mostly ignored and the Truck estimates 14.6afr while warming up. Once the Truck believes the 02s are warm switches to closed mode and uses the 02 sensor inputs for fuel/air. This is where the idle issues come into play. In my case I think the main issue is that the long tube headers increase the distance the exhaust gases go. On some vehicles there is a HP Tuners option to change the transport distance. For our vehicles I don’t think there is. I would think if you only had the TVS1900 the stock tune is fine but any changes (injectors/intake/headers/etc) would disrupt the idle some.
    There is a setting that defaults usage of LTFT from 450 to 900rpm (at idle) outside that range it becomes like an open loop again. Which I think this is why you will see the rpm gauge often bounce from 450-900ish.
    Thus from everything I have seen the way to correct the idle is to data record after the truck is in closed loop. Then dial in the MAF table and other relevant tables for the idle conditions (whereas usually the focus is on WOT conditions etc). Trying to get LTFT close to zero likely will mellow out idle.
    Mdl, Saltyhero13, armyoffoo and 3 others like this.
  11. Jan 17, 2025 at 10:32 AM
    snivilous
    SW UT
    On @e30cabrio we raised the idle a little since it was doing something similar as I recall and that made the idle lock in better. Correct me if I'm wrong Stefan.
    ARES35, Mdl, Saltyhero13 and 4 others like this.
  12. Jan 17, 2025 at 10:37 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Can confirm but may not apply. I had a little surge. Nothing concerning and when I bumped up my idle for when my e-fan comes on it went away.
  13. Jan 17, 2025 at 10:54 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hmmm... I'm going to remember to try this for an issue that has cropped up for me. That being, when I added a DW adjustable FPR, after startup, the fuel lines would buzz for about a minute or so then stop. I changed back to the stock FPR but then noticed that occasionally it would still happen, just not as pronounced. After poking around a little and thinking about it, it occurred to me that this wasn't happening before my transmission swap. That got me to thinking that maybe that might be a contributing factor, maybe the lines got disturbed slightly and were now slightly freed up a little and a resonance would get set up for a time.
    After realizing what I think might be going on, I changed back to the DW FPR again and then the next time I had my cat shields off, I would look at some way to make the lines more secure. Just reaching up and placing my hand on the lines would mute the buzzing. But recently, I've also noticed that after a full warm up, when I've gone out about thirty minutes later to start the truck, when it fires, the rpms would flare as normal, but then it would die. Feeding a little throttle a fraction after the flare is enough to keep it running and then it would be fine on it's own.
    How I think I'm going to approach this is to first dial back the fuel pressure from the current 50psi down to the stock 43.5psi, or as near as I can get to it. If that doesn't do the trick, I'll experiment with the tune by adding idle rpms in 5 or 10 rpm increments to see if that resolves it.
    Thanks for the idea!:hattip:
  14. Jan 17, 2025 at 10:55 AM
    nags
    nags New Member
    Mine specifically feels like the idle is a tad higher than it used to be when sitting.. And then it'll bump up to like 1200rpm and 'push' me through the brakes a bit and then come back down to 1000, which also seems a tad high. Previously the idle was solid as a rock.
    Mdl and e30cabrio like this.
  15. Jan 17, 2025 at 11:02 AM
    e30cabrio
    You made changes that did not fix it, then raised it a bit & all was well.
    ARES35, Mdl, M3Tundra-JK and 2 others like this.
  16. Jan 17, 2025 at 12:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Ponderosa_Pine I've never had a surge in rpm like that. I do know after getting the MAF and LTFT close to 0 or within 5 of air/fuel it runs pretty well. I just got out of the habit of constantly changing it and giving it time to settle out.
    Ponderosa_Pine likes this.
  17. Jan 17, 2025 at 12:34 PM
    e30cabrio
    Mine wasn't so much surging as dipping to about 700 and coming back to 900 (or so). It was annoying.
    lol
    Mdl likes this.
  18. Jan 17, 2025 at 12:39 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Yeah mine started when I put long tubes on and it’s not super noticeable, mostly just at like stop lights it will dip down slowly then go back up. My plan is to data log and intentionally let it idle to capture that data (after warm up) to let Sniv see if any corrections can be made there. I usually only drive short distances with this thing so forgot about it haha. Hopefully not a vacuum leak or something.
    Oh and going to replace my PCV valve today/check it. Curious if there is any gunk in there. Maybe causing some idle stuff too.
    e30cabrio and Mdl like this.
  19. Jan 17, 2025 at 12:55 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  20. Jan 17, 2025 at 1:03 PM
    carn_dogg
    Pat
    Eastern Shore MD
    NatesNightMare likes this.
  21. Jan 17, 2025 at 3:14 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    It circling around an RPM like that is most likely a bad VE target. Find out what your Lambda is in that area and add or reduce some fuel.
    Mdl likes this.
  22. Jan 17, 2025 at 3:32 PM
    e30cabrio
    Sniv messed with it alot. I'm sure he did all he could.
  23. Jan 17, 2025 at 3:38 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Mine does the same, and I can see the AFR for both banks swinging from rich to lean while it happens, one bank will be rich while the other is lean, and vice versa. The wideband channels look like a double-helix in the logs.
    ARES35, e30cabrio, Mdl and 1 other person like this.
  24. Jan 17, 2025 at 4:06 PM
    koditten
    Kirk
    Midland of the Mitten
    Just got done swapping the starter on my '08. That job blows!
    If installing a SCer is harder than that job, imma gonna skip installing the fucker on my '21 myself.
    I'm definitely using hoses when I install the transmission cooler on the '21. Those rigid transmission cooler lines were a major pain in the ass to work around.
    Tripleconpanna and Mdl like this.
  25. Jan 17, 2025 at 4:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's probably easier:D
    The fuel tank isn't bad as it's made out to be:rolleyes:
    Wynnded and koditten[QUOTED] like this.
  26. Jan 17, 2025 at 4:15 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Figured I'd be proactive and tell y'all to go read up on my shit show of a Thursday. It's in the turbo thread.
    carn_dogg and Mdl like this.
  27. Jan 17, 2025 at 5:49 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Tough break man, shitty day for sure. Another 5.7 down. If you can stomach the wait time and $$, I'd go XAT for round two
  28. Jan 17, 2025 at 5:56 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Agreed, SC install was easier than the starter.
    HulkSmurf14, Mdl[QUOTED] and koditten like this.
  29. Jan 17, 2025 at 6:17 PM
    e30cabrio
    Sorry, bflooks.
    That is why I'm replacing the alternator & starter while the motor is coming out.
    VWTim[QUOTED], Mdl and koditten like this.
  30. Jan 17, 2025 at 6:24 PM
    koditten
    Kirk
    I'm glad to hear this.
    Mdl likes this.
