Excited to Join (2006 1GT RC 2WD)
Discussion in 'New Member Introductions' started by MooreKen, Jan 17, 2025.
  1. Jan 17, 2025 at 1:29 AM
    MooreKen
    MooreKen [OP] New Member
    Ken
    1GT RC V8/2WD
    Been wanting for an older Tundra for sometime now to go with my 2023 4Runner. I really needed a truck that I could throw straw , top soil , manure, etc in with out having my OCD kick in and drive me nuts. (Nothing worse than a 4Runner filled w/ loose straw.) Anyway…. Now that Toyota has succumbed to EPA requirements causing all sorts of issues in their trucking division getting an older Tundra became very important. I had my eye on this particular Tundra for over a year and with its pedigree I was willing to spend a lil extra in getting it. Purchased for $6000 and have already put an additional $3000-4000 into it. Where else can you get such a solid truck for $10K. Truck has 174,000 miles on it and has zero rust. Engine pers like a kitten and all I could find was minuscule amount of oil on right side valve cover gasket area. My $3000-4000 immediate preventative maintenance items were: new K02 white letter tires, new Toyota SSL antifreeze, Mobil1 oil change w/ genuine Toyota filter, new AISIN timing belt kit w/ water pump, from Rock Auto, new Denso Radiator, new LBJ (not sure if he is going to install Moog or Toyota but he knows I prefer factory vs Moog, new battery, new tail gate latch, headlight restoration kit and I’m having the o2 sensors deleted so they won’t be triggering the CEL anymore. I think that’s it. I can’t wait to get it back from the shop but thought I’d go ahead and post for now.*** Update***At you guy’s behest, I verified that the Lower Ball Joints will be Toyota OEM not Moog. Thanks for the input.IMG_2055.jpg
  2. Jan 17, 2025 at 4:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    MooreKen[OP] likes this.
  3. Jan 17, 2025 at 4:39 AM
    Florida AF
    Logan
    North Florida
    Welcome from North Florida and excellent find!
  4. Jan 17, 2025 at 5:06 AM
    Call him back. Insist on OEM for the LBJ.
    OEM OR DIE
  5. Jan 17, 2025 at 5:14 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Welcome to the Forum, we want to see you start off in a good position. Don't let him install moog or you'll be having the job done again in the next 5-10k.
    What's the plan here? This isn't a common thing around here. Usually just replace sensors and move on.
    MooreKen[QUOTED][OP] likes this.
  6. Jan 17, 2025 at 5:16 AM
    Welcome from NY.
  7. Jan 17, 2025 at 6:24 AM
    MooreKen
    Ken
    1GT RC V8/2WD
    If ends up needing the secondary air pump and O2 sensors he said he could delete the O2 sensors altogether - I think via a dummy load to make the computer think the sensors are fine. Here in Oklahoma we have no inspections and aren’t real big on saving our environment. In fact, if the price is right you can come inject your waste water from fracking and cause millions of dollars worth of earthquake damage.
  8. Jan 17, 2025 at 6:31 AM
    MooreKen
    Ken
    1GT RC V8/2WD
    Just texted him and received confirmation- He will be using Toyota OEM LBJs….not Moog.
    NickB_01TRD and FrenchToasty like this.
  9. Jan 21, 2025 at 12:31 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  10. Feb 14, 2025 at 11:57 PM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD DC 4.7 V8 AT 2WD
    Welcome from NC :hattip:
