Installation of Prinsu Roof Rack
Discussion in '3rd Gen Tundras (2022+)' started by WhiteDevil1978, Mar 25, 2023.
  1. Mar 25, 2023 at 9:02 PM
    WhiteDevil1978
    WhiteDevil1978 [OP] Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    Hey everyone! In a couple days the Prinsu roof rack I ordered should arrive. I have watched a few videos of how to install it on my 2023 Tundra, but I want to get some advice from anyone who has done it already. I own a construction business and am rather competent mechanically, but drilling holes in the top of a brand new $65k truck has got me a bit nervous! Anyone out there have any tips, tricks or further advice on this installation? I welcome any and all comments, thoughts and ideas, or anything else you may think would be useful information. Thank you in advance!
  2. Mar 25, 2023 at 9:07 PM
    Use a punch to start it, use a drill stop to keep from drilling too deep and hitting airbags.
    I've never done an install, but those are the 2 things I'd make sure of if I did.
  3. Mar 25, 2023 at 10:45 PM
    trailhunters
    trailhunters New Member
    I'd like to know this as well. Sub'd.
    WhiteDevil1978[OP] likes this.
  4. Mar 26, 2023 at 7:55 AM
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    I installed mine. Just followed the video and the install was straight forward. The tough part was actually drilling through some parts of the roof. I went through a ton of titanium and cobalt bits, so just make sure you have several on hand. The rear holes you have to make are really easy. Barely even have to apply any pressure. The toughest parts I found were the front-most holes. What I found to be the most effective was making a small hole (whatever size necessary to fit your step bit in) with a titanium or cobalt bit, and then using a skinny titanium step bit to bring the hole to the required size. Aside from that, install was straightforward. Don’t really have to think about the airbags too much if you use a smaller, shorter bit first and then just use the step bit to enlarge the hole.
    I’d also try to vacuum or something while making the holes. Some of the metal shards made their way down to my passenger seatbelt assembly and jammed it, which was kind of a pain to deal with.
    This is the step bit kit I bought off Amazon and just used the skinny one: https://www.amazon.com/dp/B0177PN6SI
    ReCKzX, Blufin, iiawah808 and 2 others like this.
  5. Mar 27, 2023 at 7:03 AM
    photoguy190
    photoguy190 New Member
    James
    2023 TRD Limited
    I did my a couple of weeks ago.
    The video is a great start! The big thing is to plan on having lots of high quality drill bits and don't let the ease of the back 2 holes trick you in to thinking it will be simple. Start you first hole at 1/8 and then steep at least 2-3 drill sizes to the 3/8.
    The drilling of the front 6 holes was the only issue i had. Putting in the nuts and throwing rack together and then on the truck was easy.
  6. Mar 27, 2023 at 7:28 AM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
  7. Mar 27, 2023 at 8:57 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Mine is coming today, ironically. I've got some time off work coming up in a couple of weeks so I plan to tackle it then. I've got a Prinsu on my Leer cap and the cab rack will finish off the rack system on the roof for me. Looking forward to tackling it.
    Q1: Are you guys really using step bits for the roof as opposed to stepping up via individual bits? Also...highly recommend, anytime you're cutting structural metal - like a roof, to use cutting fluid. It'll help keep you from burning through bits.
    Q2: For those of you who used drill stops...what depth did you set them at? I've watched a few videos from roof rack makers that require drilling. The only one who mentions a depth setting is Victory (I know why...because of their issues) and they recommend a depth setting of 1/2". Is that about right?
    Side note: I'm not too scared of drilling holes in vehicles. I installed a snorkel kit on my 2012 4Runner back in 2017. Drilling a 4" hole in the fender of a $45k truck will get you over the fear hurdle very quickly. hahaha. :rofl:
  8. Mar 27, 2023 at 9:06 AM
    jgoliath
    A half of an inch sounds about right.
    There’s a some space on the back side before you hit anything. You just don’t want to lose it when drilling and let the whole bit fly through like a full inch while still spinning and hit the airbag or any cable harnesses.
    Prinsu at least has a video of the install now. It was a guessing game when I installed it last year.
    https://m.youtube.com/watch?v=rIp_SjEIsdI
  9. Mar 27, 2023 at 11:20 AM
    trailhunters
    Surprised Toyota didn't add factory mounting points for the roof rack. All this work to just add some threads.
  10. Mar 27, 2023 at 11:24 AM
    KroppDuster
    Bilstein 5100s
    I don't think they ever have on their trucks. I know the previous gens also required drilling. I never added a rack to my old Taco, but I'm pretty sure that would've required drilling too.
    The 4R platform has rack holes. I had a Gobi on my 4Runner and the install of that was pretty easy.
  11. Mar 27, 2023 at 11:27 AM
    a_double
    a_double New Member
    With the Trailhunter trim, hopefully all frames will include holes, whether used will depend on the trim.
  12. Mar 27, 2023 at 12:32 PM
    WhiteDevil1978
    Dustin
    Thanks for all the input everyone! I am definitely using drill stops and already have some good rtv silicone on hand as well. Per one of your tidbits of advice, I'll pick up some cutting fluid and will remember to keep the doors closed as I drill. Thank you as well to those who mentioned which holes would be toughest. I feel a bit better knowing more of what's in store. Armed with all the input, it seems like it's a pretty straightforward procedure. A million thanks!!! One last thing...... does anyone recall about how long it took them from start to finish?
  13. Mar 27, 2023 at 3:28 PM
    trailhunters
    My 2018 Tacoma had pre-drilled holes for installation. Was super easy.
  14. Mar 27, 2023 at 3:32 PM
    KroppDuster
    Bilstein 5100s
    Pretty sure my 2005 did not. :)
  15. Mar 27, 2023 at 4:32 PM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    If I didn’t get stuck on the front holes, would’ve taken me like 4 hours total.
  16. Mar 29, 2023 at 8:00 AM
    photoguy190
    James
    2023 TRD Limited
    Yikes! even getting stuck on the front hole and 2 trips to get more bits I was done in like 3 hours
  17. Mar 29, 2023 at 9:46 AM
    Efreet6669
    Efreet6669 New Member
    '07 Limited Red Salsa Pearl,'23 TRD Pro Solar Octane
    UPTOP Tundra Alpha racks are really nice. Unfortunately, I have the glass roof and can't install.....
  18. Mar 29, 2023 at 9:47 AM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    uptop doesn't work with sunroof? I thought they all did
  19. Mar 29, 2023 at 9:48 AM
    Efreet6669
    WAs suggested not to install due to room to open the glass?
  20. Mar 29, 2023 at 3:07 PM
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Lol I spent like an hour on each side with old bits before I finally made a trip to Home Depot. Should’ve set my pride aside way earlier
  21. Apr 11, 2023 at 1:27 PM
    KroppDuster
    Bilstein 5100s
    I installed mine yesterday.
    I won't regurgitate all of the details here. If you're interested, I did a post with pics, tips, & gripes on my build thread. Direct link to the post: Duster's Double Cab Build - The Daily Do-it-All
    Suffice to say, I wouldn't tackle this again. Whatever a shop would charge is 100% worth it.
  22. Apr 11, 2023 at 10:26 PM
    trailhunters
    Jeez now I'm a little timid on getting it.
  23. Apr 12, 2023 at 11:42 PM
    WhiteDevil1978
    Dustin
    I installed my Prinsu rack yesterday myself. Took about 5 hours, and like others have said, it is a PAIN! I went through several brand new cobalt drill bits, even using cutting fluid extensively. Two 3/8 inch Dewalt cobalt bits broke off in the holes near the front. As everyone else agrees, the front holes are dang near impossible to drill. Unless you are relatively young and very able, as well as having all the equipment needed to make this go as smooth as possible, I would NOT recommend doing this on your own! The instruction video on Prinsu's site was extremely well detailed, but this process is not easy to say the least. All said and done though, I LOVE this rack!
  24. Nov 10, 2023 at 8:23 PM
    Mik
    Mik New Member
    Hello new member here...
    I just installed my Prinsu roof rack and it was a bit of a pain but the video online and the manual did help. They could do a better job on with install part and instructions however...
    My two cents -
    • Front cross bar support for wind deflector should be black too
    • The hardware to mount into plusnuts/rivnuts should be stainless and black coated like the rack itself.
    • They should provide the silicone with install kits
    During Install
    • It helps to predrill the holes with a small bit first (I used an 1/8" bit)
    • Most important use stop collars on the drill bit so you don't drill down past the metal into your airbags.(very cheap on Amazon)
    • and yes these should also be included in the install kit.
    I think these should all be included in the install kits but hey they are still selling well without I suppose...
  25. Nov 12, 2023 at 12:31 PM
    Todd34
    Todd34 New Member
    I installed my Prinsu recently as well. It took a while to get it done but I took my time, used collars on the drill bits, cutting fluid and a small magnet to clean out the shavings occasionally. I wouldn't want to do it again but I'm glad I did it.
  26. Jan 12, 2024 at 12:21 PM
    TheCrazyludwig
    TheCrazyludwig New Member
    After reading through this thread a few times I decided not to do it myself. I am 100% happy with this decision and the outcome:
    ReCKzX and Mattedfred like this.
  27. Jan 12, 2024 at 12:50 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    :drool::drool::drool::drool::drool::drool:
  28. Jan 13, 2024 at 8:19 AM
    23LUNATRD
    23LUNATRD New Member
    23 Tundra SR5 TRD Off-road LunaRock
    Same, I could have done it myself but decided to save the stress and time and have a local shop do it. Outcome was phenomenal IMG_20240103_193213_676.jpg 20240104_080447.jpg
    TheCrazyludwig likes this.
  29. Jan 16, 2025 at 2:32 PM
    Tacos89
    Tacos89 New Member
    Roger
    2023 tundra
    Non
    curious how much was it to install it?
