What Wheels?
Discussion in 'Wheels & Tires' started by SC SR5, Jan 16, 2025.
  1. Jan 16, 2025 at 12:28 PM
    SC SR5
    SC SR5 [OP] New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    Any wheel company out there that makes close to a factory speck wheel as far as offset? I want new wheels but no poke . I’ve just picked up another tundra, 14 SR5 , any help or ideas would be great , RC 2” leveled coilovers 295/70/18 Mickey Thompsons with no rubbing , should be a fun project, just swapped all white lights to LEDs , looking for some wheel ideas now.
  2. Jan 16, 2025 at 2:24 PM
    scs_vuth
    scs_vuth New Member
    Vuth
    Bay Area
  3. Jan 16, 2025 at 3:24 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Few 18 inch wheels that are close to stock offset. Stock offset is +60.
    Most aftermarket wheels, 18 inch for Tundra are +18 or +25.
    There are a few choices in 18 inch that are +40 or +45, which is close to stock and will not poke the tires. Method wheels makes some in the +40 range, either in black or bronze.
    If you want to keep stock offset, a set of the TRD Off road wheels would look good, or if you want all black, then the TRD Pro wheels.
  4. Jan 16, 2025 at 4:01 PM
    mfranzen89
    mfranzen89 New Member
    Mat
    Kansas City
    2021 Tundra TRD Pro LR
    Agreed. If you don’t want poke, and are going to do a 2” level, I would go with the Pro wheels and 295/70’s. You will need a small spacer since it will rub on the sway bar. I did a 3/8” spacer and 295’s. No rubbing at all with very little if any poke. Was a great set up.
  5. Jan 16, 2025 at 4:02 PM
    mfranzen89
    Mat
    Kansas City
    If you want pro wheels, I just took mine off of my 21 and have the 295/70 ridge grapplers and the spacer. Hit me up.
    SC SR5[OP] likes this.
  6. Jan 16, 2025 at 6:24 PM
    jayhawknavy02
    jayhawknavy02 New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    I'm going through a similar search / effort. You may find this useful.
    https://www.tundras.com/threads/gen...-long-time-listener-first-time-caller.152823/
    SC SR5[QUOTED][OP] likes this.
  7. Jan 21, 2025 at 9:52 AM
    SC SR5
    Does anyone have the Method 318 mounted on their truck that can share a picture
  8. Jan 21, 2025 at 9:56 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
