  1. Jan 15, 2025 at 11:16 AM
    Outbound
    Aaron
    Northern Alberta
    I gotta go to 105% and yank the tailgate back and forth. It worked fine before I gave my dad the truck...
    I'll just add it to the list of things I fix or redo in spring. I need to replace the lower ball joints first thing. He had them done a year or so ago, but they used non-OEM parts. I also need to chase down a clunk that's happening. I'm probably do for shocks at some point too.
  2. Jan 15, 2025 at 11:40 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Do shifty's tailgate 2nd gen parts mod. Worked like a dream. Went from doing what you described to a 1 handed smooth operation.
    Outbound[QUOTED] likes this.
  3. Jan 15, 2025 at 11:45 AM
    Outbound
    Aaron
    Northern Alberta
    That's the plan. I need to degrease and re-lube the latches too. My rods are all bent to hell as well so those need to be straightened.
  4. Jan 15, 2025 at 12:23 PM
    You may be able to shorten the OEM rod (by putting a strategic bend somewhere it won't interfere with sliding) to make it engage the latch(es) faster. I've had to do similar swapping out parts into junkyard doors in the past.
    Unless the latchese work on a push system, then you'd need to un-bend some part of the rods. You'll quickly know. Just play with it while the cover panel is off. You'll see pretty quick what the issue is, I'd hope.
  5. Jan 15, 2025 at 2:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Is your access panel caved in?
    I had that problem too. Took a mallet to the panel to flatted it back out. Handle works flawlessly now.
  6. Jan 15, 2025 at 2:59 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    See my reply to Beau above.
  7. Jan 15, 2025 at 5:25 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    What do you coastal guys do for rustproofing? Just moved to Houston recently, no snow but salt air. I was thinking of fluid filming the frame again, anywhere or anything else to do?
  8. Jan 15, 2025 at 5:40 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Tundra got a younger brother. Just picked up the work truck for my new job. It'll fit right in :D
    Problem is, now I've got my Tundra, a recently acquired 99 Subaru as a bang-around-town vehicle, and now the work truck. Feels a bit excessive...but I'm going to roll it for a while and see what I think. Might ditch the Subaru but we'll see.
    NUDRAT, Hutcheson, RealTruck and 7 others like this.
  9. Jan 15, 2025 at 5:50 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I'm not on the coast, but my preferred method especially if you work on your own vehicle is wire wheel, rust remover, rust reformer spray paint, and finish with VHT satin black paint. Lay the spray paints on with some moderate coats. There is absolutely nothing aside from powder coating the frame or a brand new frame that will look as nice. Does it work as well as the other stuff? No idea, but it's sure as hell not as greasy and I haven't noticed anything coming off or rust forming underneath the paint.
  10. Jan 15, 2025 at 5:59 PM
    I’ve heard of people using WD-40 by the gallon to protect against surface rust. People do it a lot around here at least for their chrome wheels during the winter. I’ve used it on exposed metal with good results. It stinks though.
  11. Jan 15, 2025 at 6:24 PM
    I’ve heard of people putting it on arthritic joints, not even kidding
    BroHon and Jack McCarthy[QUOTED] like this.
  12. Jan 15, 2025 at 6:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Get it tuned. You'll be much happier with the turd gen then.
    MT-Tundra[QUOTED] likes this.
  13. Jan 15, 2025 at 6:31 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    My truck has zero rust to start with so I’ll just keep spraying it
  14. Jan 15, 2025 at 6:34 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Nothing.
    Paint bare metal.
    Surface rust ain't shit.
    Wash the undercarriage after driving on the beach.
    KTM_AJ421[QUOTED] likes this.
  15. Jan 15, 2025 at 6:43 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    DMSO
  16. Jan 15, 2025 at 7:13 PM
    Are these the same people who wear the copper magnetic bands for healing power?
    I haven’t tried one but some people swear by them including my ex-boss on a program before he retired.
  17. Jan 15, 2025 at 7:16 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I think those people moved onto the blankets you plug into your house's ground
    JasonC., shifty`, bmf4069 and 2 others like this.
  18. Jan 15, 2025 at 7:19 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
  19. Jan 15, 2025 at 7:26 PM
    455h0le_dachshund likes this.
  20. Jan 15, 2025 at 7:30 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    2nd year/winter with the restored steelies, coated in WD when I mount them. So far no rust.
  21. Jan 15, 2025 at 7:34 PM
    The wheel has inertia built up that includes over coming the weight of the truck. As soon as it's loose of that weight, the built up energy / inertia will make the wheel accelerate beyond the speed of the vehicle. Seen it time and time again.
    FirstGenVol, shifty`, bmf4069 and 3 others like this.
  22. Jan 15, 2025 at 7:35 PM
    How come we didn’t hear it fall off or the drum scraping the pavement? I would think that noise would be deafening at high speed.
  23. Jan 15, 2025 at 7:36 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Physics is cool
  24. Jan 15, 2025 at 7:39 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My issue is that I didn't notice the truck drop to one side when it happened
    Jack McCarthy likes this.
  25. Jan 15, 2025 at 7:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Agreed, didn't even look like it was slowing down to me.
  26. Jan 15, 2025 at 7:40 PM
    My brother lost a wheel on his truck driving down the road and the truck just rolled on with three wheels until he almost came to a stop. 72 C10 long bed was pretty front heavy though. The wheel went rolling past him at high speed, rolled through a ditch, jumped the opposite ditch bank and cleared a fence into a field surrounded by trees. He never found the wheel.
    FirstGenVol, bmf4069, des2mtn and 2 others like this.
  27. Jan 15, 2025 at 7:47 PM
    I just watched it again. That's one bald ass tire. Half shaft came with it, so the wheel didn't fall off, the whole axle came out. Rear axle was sitting on the ground when he was at a complete stop.
    FirstGenVol and FrenchToasty like this.
  28. Jan 15, 2025 at 7:48 PM
    Wow. That’s just kind of hard to believe. I’d have to see it myself.
  29. Jan 15, 2025 at 7:53 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Stumbled on this gem just now, never seen it before. 2023 Ram 1500 4dr Apocalypse. WTAF. It has a leather wrap on the steering wheel with a mushroom cloud on it... :rofl::rofl: Capture.jpg
    G_unit3000 likes this.
  30. Jan 15, 2025 at 7:55 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    $180k for a Dodge Power Wagon with a bunch of ugly BS?:rofl::rofl::rofl::rofl:
