Can anyone help explaining how to re-attach these?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra9880, Jan 15, 2025.
  1. Jan 15, 2025 at 5:50 PM
    Tundra9880
    Tundra9880 [OP] New Member
    2019 Cement CrewMax SR5
    Leveled, wheels and tires, Line X on the grille surround and bulge, Line X in the bed, Retrax rolling Tonneau cover, Flowmaster Outlaw cat back exhaust.
    Hello all, so I recently installed the desert does it seat jackers in my 2019 SR5 Crewmax. I installed them on the driver side only and had to loosen the two back seat bolts in order to lift the front of the driver seat to put the risers. Install went pretty smooth.
    Today, I notice these two parts sticking out of the driver seat track in the back, and cannot figure out how to re-attach them. They seem to be called "lower shields" and have a hook on them. They are attached, but the hook part is sticking out the back just above each seat track. They don't seem broken, just unattached. Any help would be extremely appreciated. Thank you!
  2. Jan 15, 2025 at 6:59 PM
    bflooks and Tundra9880[OP] like this.
  3. Jan 15, 2025 at 7:10 PM
    Tundra9880
    HA! Nope. I did think about cutting them off though. But knowing my luck my seat will collapse or something...
  4. Jan 15, 2025 at 7:13 PM
    Does the passenger seat have them as well? Could just copy the arrangement from that side.
    Tundra family likes this.
  5. Jan 15, 2025 at 7:27 PM
    Tundra9880
    Didn't have time to check today but I don't think so because my truck is power seat driver seat, manual seat passenger. The set up is a bit different as I checked when doing the seat jackers. I'm going by my local dealer tomorrow to see if its a quick fix. Was hoping someone here might have had the same issue and knew how to reattach them quick, hoping to save time and money.
  6. Jan 16, 2025 at 1:34 PM
    Tundra9880
    Just in case anyone else has issue with these....dealer tech said they were cosmetic only to cover the bolts on the seat tracks. Nothing affected by their absence so I removed them.
